drmacro
Raspbian SD card image
Mon Apr 24, 2017 11:21 pm
I use the following on ubuntu to get a raspbian image to an sd card:
sudo dd bs=4M if=2017-04-10-raspbian-jessie.img of=/dev/sdc
Works fine unless I'm using a new sd card. In that case, it works the second time.
After the first time there the usual 4G root partition with home, bin, etc, root, ... and a partition with the rest of the sd card, but no boot partition.
The second time there is a ~20M boot and a 4G root partition, and the rest of the drive is not partitioned until after raspbian boots and expands root.
What's up with the first dd command?
Regards,
Mac
ghans
Re: Raspbian SD card image
Tue Apr 25, 2017 6:56 am
Did you try physically ejecting the card after each dd invocation ?
ghans
jahboater
Tue Apr 25, 2017 7:24 am
Also try typing "sync" before ejecting the card.
drmacro
Tue Apr 25, 2017 2:32 pm
I use sync after the write by default. Doesn't make any difference.
And physically ejecting makes no difference.
I suspect it has something to do with the partition table before the dd command. But it is whatever Sandisk ships from the factory.
Tue Apr 25, 2017 2:45 pm
drmacro wrote:I use the following on ubuntu to get a raspbian image to an sd card:
Regards,
Mac
Maybe try Etcher: https://etcher.io
FYI DD erases all partitions & existing data on SD Card.
Retired disgracefully.....
Return to “Advanced users”
