I am trying to use the --lavfdopts feature in OMXPlayer.
My line that works:
The line I am trying to use:omxplayer --lavfdopts 'probesize:250000' test.h264
The original post, found here: https://github.com/popcornmix/omxplayer/pull/429 says you should be able to use any option found in the options_table.h file found here: https://www.ffmpeg.org/doxygen/3.2/liba ... ource.htmlomxplayer --lavfdopts 'probesize:250000,fastseek,direct' test.h264
The command line format for OMXPlayer is slightly different than that found in MPlayer but in theory, it should work.
Can anyone tell me how to format the command line or what options are supported?
Thanks in advance.
