fkbreitl
Information about kernel versions in Raspbian stable
Fri Apr 14, 2017 9:52 pm
Where can I find information about which kernel versions have been and will be when in Raspbian stable?
I know that the development takes place at https://github.com/raspberrypi/linux but I could not find this information with respect to the stable repository.
ShiftPlusOne
Re: Information about kernel versions in Raspbian stable
Fri Apr 14, 2017 10:40 pm
The tags correspond to the containing raspberrypi-kernel raspbian package.
https://github.com/raspberrypi/linux/releases
Fri Apr 14, 2017 10:50 pm
The stable kernel is installed with apt-get. Current stable kernel is 4.4.50.
fkbreitl
Fri Apr 14, 2017 11:00 pm
The information there is quite confusing. For example, I it says
on 20 Feb raspberrypi-kernel_1.20170405-1
on 20 Feb raspberrypi-kernel_1.20170303-1
Clicking on raspberrypi-kernel_1.20170405-1 shows
popcornmix tagged this on 20 Feb · 75404 commits to rpi-4.9.y since this tag
Merge remote-tracking branch 'stable/linux-4.4.y' into rpi-4.4.y
So there is the date of Feb. 20th but the package suggests the date Apr. 5th.
And rpi-4.9.y suggests it is a 4.9.x kernel while the next line mentions linux-4.4.x.
Can you explain a bit more how to read this?
ShiftPlusOne
Fri Apr 14, 2017 11:45 pm
That's a bit open ended. Is there some specific bit of information you're after? What was the reason for the original question?
fkbreitl
Sat Apr 15, 2017 10:34 am
I would like to know the release history and schedule about which kernels made it and are going to make it when into stable.
One needs this information for many reasons but my particular one is that I bought a Geniatech T230C USB TV stick and I heard it should be supported by kernel 4.11. How long do I have to wait?
ShiftPlusOne
Sat Apr 15, 2017 12:43 pm
There's no easy answer. We will be on 4.11 when it's ready, tested and deemed stable. Not this month, likely not within the next few months.
You can see the log of releases into the apt repo here:
https://github.com/RPi-Distro/firmware/ ... /changelog
The kernel is taken from https://github.com/raspberrypi/firmware
The version numbers in the changelog correspond to the date that the firmware+kernel was released into the git repo above.
raspberrypi-firmware (1.20170405-1) jessie; urgency=medium
The date at the bottom of the entry is the date the package was built, which may be a day before it goes into apt.
Wed, 05 Apr 2017 15:21:59 +0100
fkbreitl
Sat Apr 15, 2017 1:43 pm
This makes things a bit clearer.
But I am still confused about the kernel versions since https://github.com/raspberrypi/firmware say
`popcornmix kernel: Bump to 4.9.22`
But uname for the stable kernel reports 4.4.50.
So which numbers are correct and what do they mean?
ShiftPlusOne
Sat Apr 15, 2017 2:32 pm
It means that since that tag, the rpi-4.9.y branch has had 75404 commits. It's just how github chooses to display information. I'ts not relevant.
That's the latest commit to rpi-4.9.y and has nothing to do with the tags.
6by9
Sat Apr 15, 2017 2:39 pm
If you use rpi-update you will get the 4.9 kernel, but also need to be prepared for potential issues as it is effectively a development branch.
The apt-get kernel package hasn't been bumped to 4.9 as there are still a few niggles to resolve first.
In addition to what Shift PlusOne has written, generally we only release kernel which have long term support, hence 4.4 and 4.9. I don't believe 4.11 will be an lts release, so whilst there is a branch for it in the raspberrypi kernel repo it may not be released.
Sat Apr 15, 2017 3:04 pm
6by9 wrote:If you use rpi-update you will get the 4.9 kernel, but also need to be prepared for potential issues as it is effectively a development branch.
Is there anywhere a list of release dates of the Kernel both current and previous ??
RPi 4B 4GB (SSD Boot)..
Sat Apr 15, 2017 6:17 pm
https://github.com/Hexxeh/rpi-firmware/commits/master
https://github.com/Hexxeh/rpi-firmware/commits/next
https://github.com/Hexxeh/rpi-firmware/commits/stable
Sat Apr 15, 2017 6:19 pm
TYVM
fkbreitl
Sun Apr 16, 2017 9:45 am
Thank you.
But to help me understand, what is the difference between
on 20 Feb raspberrypi-kernel_1.20170405-1 and
on 20 Feb raspberrypi-kernel_1.20170303-1?
And what will be the next kernel minor version in RPi?
Will it be 4.9? How can one tell?
ShiftPlusOne
Sun Apr 16, 2017 10:04 am
fkbreitl wrote:on 20 Feb raspberrypi-kernel_1.20170405-1 and
Nothing. raspberrypi-kernel binary package comes from the raspberrypi-firmware source package. The version gets bumped any time the source package is updated. In this case, a raspberrypi-bootloader update was needed, but the kernel stayed the same.
fkbreitl wrote:And what will be the next kernel minor version in RPi?
Will it be 4.9?
Most likely, unless there is something keeping us on 4.4 (I don't think there is anymore).
levelcrow
Sun Apr 16, 2017 6:55 pm
Is there any chance of feature backports? 4.10 got F2FS multiple device support which I'd like to use however it looks like we're a ways off before next LTS release.
Return to “Advanced users”
