Does the Raspberry Pi Zero W's wifi support monitor mode?
Posted: Tue Mar 28, 2017 2:07 pm
by daszorz
I want to do a few security based projects, so my question is "does the Raspberry Pi Zero W's wifi support monitor (promiscuous) mode?"
Re: Does the Raspberry Pi Zero W's wifi support monitor mode
Posted: Wed Mar 29, 2017 12:36 am
by dukla2000
My Pi3 doesn't so I guess the zero won't either as apparently the same chip.
Posted: Thu Jul 06, 2017 3:02 pm
by dezaF
Yes:
Either get the seemoo labs driver built :
https://github.com/seemoo-lab/nexmon
or just download a Kali Nethunter image from
https://build.nethunter.com/nexmon-pi-builds/ Rpi3 and Rpi0w images are available.
Regards
Re: Does the Raspberry Pi Zero W's wifi support monitor mode?
Posted: Sat Apr 28, 2018 7:32 pm
by Septell
I've tried mounting the images at
https://build.nethunter.com/nexmon-pi-builds, but they hang. Could it be that my Pi 0 W is a later version than what these were tested on? Mine has the wifi built into the board. Thanks
Posted: Sun Apr 29, 2018 12:43 pm
by drgeoff
Septell wrote: ↑Sat Apr 28, 2018 7:32 pm
What do you mean by "mounting the images"? What do you mean by "hang" - exactly what happens?
All RPi ZeroWs have Wi-Fi built into the board.
Posted: Sun Apr 29, 2018 3:43 pm
by Septell
I meant that I had flashed the image onto the sd card in the pi. And by "hang", I meant that that nothing happened after that. It is now working for some reason. Not sure what I did.. The wifi goes into monitor mode etc etc. Thank you anyway, for being kind enough to reply.
Posted: Sat May 05, 2018 4:26 am
by BharatNT2IE
I have a RPI 3B , do i have to install Kali Linux or can i do it from my noobs OS ?
