Page 2 of 2
Re: Google Chrome on Raspbian (Failed to open primary graphi
Posted: Mon Mar 06, 2017 1:45 am
by kusti8
knuxyl wrote:kusti8 wrote:BTW I've compiled the latest chromium into a package that has widevine libraries in it so Netflix now works on v56:
viewtopic.php?p=1125013#p1125013
thanks so much! I'm going to use this and mix with the latest libraries and an easy install script, the version i was using is like 45 or something. when I got into the 50's I started getting library version issues (not related to drm and such) and repos didn't have supported versions. have you tested this?
What libraries? This includes the widevine libraries so it works out of the box.
Posted: Mon Mar 06, 2017 2:11 am
by cjan
cjan wrote:how to uninstall? just in case.
ha, i knew it.
Posted: Mon Mar 06, 2017 3:00 am
by knuxyl
kusti8 wrote:knuxyl wrote:kusti8 wrote:BTW I've compiled the latest chromium into a package that has widevine libraries in it so Netflix now works on v56:
the libraries included with rpi-chromium-mods and some others I found in other packages. Turns out though that build isn't 100% so I'm just going to fix my package.
edit - seems as though it was on my side having ethernet and wifi hooked up at same time. Great job!!!!
by knuxyl
cjan wrote:cjan wrote:how to uninstall? just in case.
ha, i knew it.
to uninstall it, just do this (ill include these instructions on the first post)
sudo rm -R /usr/lib/chromium-browser
sudo apt-get install --reinstall chromium-browser rpi-chromium-mods
Posted: Mon Mar 06, 2017 4:00 am
by knuxyl
I have posted a thread in the Raspbian forum for installing Chromium with Netflix support. The package has been updated and thoroughly tested. Just follow the link on the first post at the top.
viewtopic.php?f=66&t=176413&p=1125067#p1125067
Posted: Mon Mar 06, 2017 10:44 am
by cjan
installed, chromium about is 51.0.2704.91 not 56.0.2924.110.
btw, does it compiled by armv7 ?
Posted: Mon Mar 06, 2017 11:00 am
by knuxyl
cjan wrote:installed, chromium about is 51.0.2704.91 not 56.0.2924.110.
the latest package is 56.0.2924.84
you must be installing the older package, or you didn't install it right.
I don't know anything about what goes on during compilation, kusti8 did that. It compiled for armhf which requires at least armv7.
Please post questions about the Chromium build on this page
Posted: Mon Mar 06, 2017 11:13 am
by kusti8
I have no idea what you're talking about. It doesn't need any extra libraries and because rpi-chromium-mods is still installed, no need to uninstall because it just overwrites itself.
It's also compiled for ARMv6, it's just that widevine only works on Armv7.
Posted: Mon Mar 06, 2017 11:17 am
by cjan
knuxyl wrote:cjan wrote:installed, chromium about is 51.0.2704.91 not 56.0.2924.110.
we are talking about your build not Kusti8's in your sub-forum, right?
and, just do ./install.sh.
