Pulseaudio does not automatically discover bluetooth sink
Posted: Tue Jan 31, 2017 7:12 pm
by pwalden
I have pulseaudio working on my headless Pi3 with a bluetooth speaker.
However, if the speaker is powered off and then on, although it automatically reconnects through bluetooth (as seen by bluetoothctl), the pulseaudio no longer lists it as a sink.
I have to use bluetoothctl to disconnect and (re)connect the device. Only then will pulseaudio (re)list the bluetooth speaker as a sink.
Am I missing some set up or configuration?
$ uname -a
Linux walden0 4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l GNU/Linux
$ pactl list short modules
0	module-device-restore
1	module-stream-restore
2	module-card-restore
3	module-augment-properties
4	module-switch-on-port-available
5	module-udev-detect
6	module-alsa-card	device_id="0" name="0" card_name="alsa_card.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1"
7	module-bluetooth-policy
8	module-bluetooth-discover
9	module-bluez5-discover
10	module-bluez4-discover
11	module-native-protocol-unix
12	module-native-protocol-tcp	auth-anonymous=1
13	module-zeroconf-publish
14	module-gconf
15	module-default-device-restore
16	module-rescue-streams
17	module-always-sink
18	module-intended-roles
19	module-suspend-on-idle
20	module-console-kit
21	module-systemd-login
22	module-position-event-sounds
23	module-role-cork
24	module-filter-heuristics
25	module-filter-apply
27	module-cli-protocol-unix
28	module-bluez5-device	path=/org/bluez/hci0/dev_FC_58_FA_B8_1D_46
Re: Pulseaudio does not automatically discover bluetooth sin
Posted: Wed Mar 01, 2017 4:33 pm
by pwalden
I have not solved my problem, but I use the script below to reconnect the device to pulseaudio.
#! /bin/bash
if ! pactl list sinks short | grep bluez >/dev/null;
then
    echo bluez sink not found, attempting to disconnect-reconnect;
    while ! pactl list sinks short | grep bluez >/dev/null;
    do
        echo loop begin
        bluetoothctl <<EOF
disconnect FC:58:FA:B8:1D:46
quit
EOF
        sleep 10
        bluetoothctl <<EOF
quit
EOF
        sleep 10
    done
    pactl set-default-sink bluez_sink.FC_58_FA_B8_1D_46
    pactl set-sink-volume bluez_sink.FC_58_FA_B8_1D_46 32000
else
    echo bluez sink found
fi
