Silent Pi Boot
Posted: Thu Sep 13, 2012 3:18 pm
A few people have asked for a way to silence the Pi's boot & make it seem less scary/to add a splash screen & I thought I'd share my set up. If you download the attached zip & follow the instructions as to which files need their contents replacing you're halfway there
Note - I said replace the contents of and not replace the files. If you replace the files you'll break things, so just don't do it edit them instead
Then just add loglevel=1 to cmdline.txt in the /boot partition & you're good to go
You will have a very quiet boot
p.s. This turns off a lot of the standard Linux command line logging features so be warned, this quiet boot fix could cripple you later if you're getting invisible scripting problems
