haylocki
Howto auto pair bluetooth on headless Pi
Fri Jan 06, 2017 11:27 am
Finally I can pair my Raspberry Pi 3 with my Android phone without any user intervention on the Pi.
To do this you need to :
1) Create a file called "/usr/local/bin/auto-agent" containing the following code.
#!/usr/bin/python
from __future__ import absolute_import, print_function, unicode_literals
from optparse import OptionParser
import sys
import dbus
import dbus.service
import dbus.mainloop.glib
try:
  from gi.repository import GObject
except ImportError:
  import gobject as GObject
import bluezutils
BUS_NAME = 'org.bluez'
AGENT_INTERFACE = 'org.bluez.Agent1'
AGENT_PATH = "/test/agent"
bus = None
device_obj = None
dev_path = None
def ask(prompt):
	try:
		return raw_input(prompt)
	except:
		return input(prompt)
def set_trusted(path):
	props = dbus.Interface(bus.get_object("org.bluez", path),
					"org.freedesktop.DBus.Properties")
	props.Set("org.bluez.Device1", "Trusted", True)
def dev_connect(path):
	dev = dbus.Interface(bus.get_object("org.bluez", path),
							"org.bluez.Device1")
	dev.Connect()
class Rejected(dbus.DBusException):
	_dbus_error_name = "org.bluez.Error.Rejected"
class Agent(dbus.service.Object):
	exit_on_release = True
	def set_exit_on_release(self, exit_on_release):
		self.exit_on_release = exit_on_release
	@dbus.service.method(AGENT_INTERFACE,
					in_signature="", out_signature="")
	def Release(self):
		print("Release")
		if self.exit_on_release:
			mainloop.quit()
					in_signature="os", out_signature="")
	def AuthorizeService(self, device, uuid):
		print("AuthorizeService (%s, %s)" % (device, uuid))
		return # automatically authorize connection
		authorize = ask("Authorize connection (yes/no): ")
		if (authorize == "yes"):
			return
		raise Rejected("Connection rejected by user")
					in_signature="o", out_signature="s")
	def RequestPinCode(self, device):
		print("RequestPinCode (%s)" % (device))
		set_trusted(device)
		#return ask("Enter PIN Code: ")
		return "0000" # return default PIN Code of 0000
					in_signature="o", out_signature="u")
	def RequestPasskey(self, device):
		print("RequestPasskey (%s)" % (device))
		set_trusted(device)
		#passkey = ask("Enter passkey: ")
		passkey = "0000" # return default passkey of 0000
		return dbus.UInt32(passkey)
					in_signature="ouq", out_signature="")
	def DisplayPasskey(self, device, passkey, entered):
		print("DisplayPasskey (%s, %06u entered %u)" %
						(device, passkey, entered))
	def DisplayPinCode(self, device, pincode):
		print("DisplayPinCode (%s, %s)" % (device, pincode))
					in_signature="ou", out_signature="")
	def RequestConfirmation(self, device, passkey):
		print("RequestConfirmation (%s, %06d)" % (device, passkey))
		set_trusted(device)
		return # automatically trust
		confirm = ask("Confirm passkey (yes/no): ")
		if (confirm == "yes"):
			set_trusted(device)
			return
		raise Rejected("Passkey doesn't match")
					in_signature="o", out_signature="")
	def RequestAuthorization(self, device):
		print("RequestAuthorization (%s)" % (device))
		auth = ask("Authorize? (yes/no): ")
		if (auth == "yes"):
			return
		raise Rejected("Pairing rejected")
	def Cancel(self):
		print("Cancel")
def pair_reply():
	print("Device paired")
	set_trusted(dev_path)
	dev_connect(dev_path)
	mainloop.quit()
def pair_error(error):
	err_name = error.get_dbus_name()
	if err_name == "org.freedesktop.DBus.Error.NoReply" and device_obj:
		print("Timed out. Cancelling pairing")
		device_obj.CancelPairing()
	else:
		print("Creating device failed: %s" % (error))
	mainloop.quit()
if __name__ == '__main__':
	dbus.mainloop.glib.DBusGMainLoop(set_as_default=True)
	bus = dbus.SystemBus()
	capability = "KeyboardDisplay"
	parser = OptionParser()
	parser.add_option("-i", "--adapter", action="store",
					type="string",
					dest="adapter_pattern",
					default=None)
	parser.add_option("-c", "--capability", action="store",
					type="string", dest="capability")
	parser.add_option("-t", "--timeout", action="store",
					type="int", dest="timeout",
					default=60000)
	(options, args) = parser.parse_args()
	if options.capability:
		capability  = options.capability
	path = "/test/agent"
	agent = Agent(bus, path)
	mainloop = GObject.MainLoop()
	obj = bus.get_object(BUS_NAME, "/org/bluez");
	manager = dbus.Interface(obj, "org.bluez.AgentManager1")
	manager.RegisterAgent(path, capability)
	print("Agent registered")
	# Fix-up old style invocation (BlueZ 4)
	if len(args) > 0 and args[0].startswith("hci"):
		options.adapter_pattern = args[0]
		del args[:1]
	if len(args) > 0:
		device = bluezutils.find_device(args[0],
						options.adapter_pattern)
		dev_path = device.object_path
		agent.set_exit_on_release(False)
		device.Pair(reply_handler=pair_reply, error_handler=pair_error,
								timeout=60000)
		device_obj = device
	else:
		manager.RequestDefaultAgent(path)
	mainloop.run()
	#adapter.UnregisterAgent(path)
	#print("Agent unregistered")
2) Make file executable
sudo chmod +x /usr/local/bin/auto-agent
3) Create a file called "/usr/local/bin/bluezutils.py" containing the following code.
import dbus
SERVICE_NAME = "org.bluez"
ADAPTER_INTERFACE = SERVICE_NAME + ".Adapter1"
DEVICE_INTERFACE = SERVICE_NAME + ".Device1"
def get_managed_objects():
	manager = dbus.Interface(bus.get_object("org.bluez", "/"),
				"org.freedesktop.DBus.ObjectManager")
	return manager.GetManagedObjects()
def find_adapter(pattern=None):
	return find_adapter_in_objects(get_managed_objects(), pattern)
def find_adapter_in_objects(objects, pattern=None):
	for path, ifaces in objects.iteritems():
		adapter = ifaces.get(ADAPTER_INTERFACE)
		if adapter is None:
			continue
		if not pattern or pattern == adapter["Address"] or \
							path.endswith(pattern):
			obj = bus.get_object(SERVICE_NAME, path)
			return dbus.Interface(obj, ADAPTER_INTERFACE)
	raise Exception("Bluetooth adapter not found")
def find_device(device_address, adapter_pattern=None):
	return find_device_in_objects(get_managed_objects(), device_address,
								adapter_pattern)
def find_device_in_objects(objects, device_address, adapter_pattern=None):
	path_prefix = ""
	if adapter_pattern:
		adapter = find_adapter_in_objects(objects, adapter_pattern)
		path_prefix = adapter.object_path
		device = ifaces.get(DEVICE_INTERFACE)
		if device is None:
			continue
		if (device["Address"] == device_address and
						path.startswith(path_prefix)):
			return dbus.Interface(obj, DEVICE_INTERFACE)
	raise Exception("Bluetooth device not found")
4) Create a file called "BtAutoPair.py" (you can save this anywhere convenient) containing the following code.
#!/usr/bin/python
# encoding=utf8
import sys
import time
import pexpect
import subprocess
class BtAutoPair:
	"""Class to auto pair and trust with bluetooth."""
	def __init__(self):
		p = subprocess.Popen("/usr/local/bin/auto-agent", shell = False)
		out = subprocess.check_output("/usr/sbin/rfkill unblock bluetooth", shell = True)
		self.child = pexpect.spawn("bluetoothctl", echo = False)
	def get_output(self,command, pause = 0):
		"""Run a command in bluetoothctl prompt, return output as a list of lines."""
		self.child.send(command + "\n")
		time.sleep(pause)
		start_failed = self.child.expect(["bluetooth", pexpect.EOF])
		if start_failed:
			raise BluetoothctlError("Bluetoothctl failed after running " + command)
		return self.child.before.split("\r\n")
	def enable_pairing(self):
		"""Make device visible to scanning and enable pairing."""
		print "pairing enabled"
		try:
			out = self.get_output("power on")
			out = self.get_output("discoverable on")
			out = self.get_output("pairable on")
			out = self.get_output("agent off")
		except BluetoothctlError, e:
			print(e)
			return None
	def disable_pairing(self):
		"""Disable devices visibility and ability to pair."""
		try:
			out = self.get_output("discoverable off")
			out = self.get_output("pairable off")
			print(e)
			return None
5) Create a file called "testAutoPair.py (save this in the same directory as BtAutoPair.py) containing the following code.
#!/usr/bin/python
import BtAutoPair
autopair = BtAutoPair.BtAutoPair()
autopair.enable_pairing()
That's it!
To check if it's working just run testAutoPair.py. You should then be able to pair your Pi to your phone without entering anything on the Pi.
If you are using legacy pairing then the code to enter on the phone is "0000".
You will need to install python-pexpect if it's not already installed.
sudo apt install python-pexpect
You will need to install python-dbus if it's not already installed.
sudo apt install python-dbus
To make the Pi permanently discoverable edit "/etc/bluetooth/main.conf" and change the line :
#DiscoverableTimeout = 0
To :
Disclaimer:
A lot of the code for BtAutoPair.py was blatently ripped from https://gist.github.com/egorf/66d88056a9d703928f93
Cheers, Ian
ddmitry1973
Re: Howto auto pair bluetooth on headless Pi
Thu Apr 20, 2017 9:55 am
- unfortunately /etc/bluetooth/main.conf does nothing to actual bt configuration, even after service reload (found same problems while searching the web, for example
- just made needed setting regarding pair and discover modes in blueetothctl
- very straight and simple solution to same task can be found here, see end of post - works pefrectly!!!
- nevertheless thank you very much for your post, as it was starting point while looking for solution of same task
regards, D
Alana785
Thu Nov 01, 2018 6:35 am
I see. I could wire a push-button to the PI's GPIO and have it turn on the auto-pairing on for a given time. APKJunky
Phlip_
Mon Mar 09, 2020 1:39 pm
It seems BtAutoPair.py needs a tweak to coordinate with bluetoothctl in the 2020s...
Change
get_output()
to:
    def get_output(self,command, response = "succeeded"):
        pause = 0
        time.sleep(pause)
        start_failed = self.child.expect([response, pexpect.EOF])
        if start_failed:
Then change one of its callers to
out = self.get_output("agent off", "unregistered")
Return to “Advanced users”
