wackazong
Power second hard drive via GPIO on Pi 3
Sun Nov 27, 2016 11:19 pm
Would it be possible to power a second hard drive via the GPIO 5V pin? I would connect the 5V of the HDD only to the 5V of the GPIO. If I try to power both from USB they will not spin up.
wildfire
Re: Power second hard drive via GPIO on Pi 3
Sun Nov 27, 2016 11:28 pm
If your PSU can't provide enough power to the USB ports it's not going to provide enough through the GPIO. Your best bet to get both working is by using a powered USB hub.
E8 85 A2 64 C9 64 81 94 64 81 95 64 89 84 89 96 A3
Still NF Shirls
davidcoton
Sun Nov 27, 2016 11:34 pm
How much power does each drive need? How much can your PSU provide?
No definitive answer is possible within the above data, but my (semi-informed) guess is no, you will still be overloading the Pi's polyfuse and possibly the microUSB power socket. Even if these are OK, the USB cable will be passing so much current that even a normally good cable will drop too much voltage. I would recommend a separate PSU for one of the HDDs. A powered USB hub for both HDDs is also a possibility.
Signature retired
wackazong
Mon Nov 28, 2016 12:59 am
The PSU can handle the current without problems. Using the 5V GPIO header would bypass the USB polyfuse. The Pi's polyfuse is rated 2.5A and should be able to handle two HDDs and the Pi, should it not?
wildfire
Mon Nov 28, 2016 2:04 am
wackazong wrote:The Pi's polyfuse is rated 2.5A and should be able to handle two HDDs and the Pi, should it not?
To quote David...
davidcoton wrote:How much power does each drive need?
Still NF Shirls
davidcoton
Mon Nov 28, 2016 9:54 am
wackazong wrote:The PSU can handle the current without problems. Using the 5V GPIO header would bypass the USB polyfuse. The Pi's polyfuse is rated 2.5A and should be able to handle two HDDs and the Pi, should it not?
Using the 5V pin of the GPIO header to power an HDD does NOT bypass the polyfuse. If you use the GPIO header to power the Pi, that does bypass it.
Signature retired
mfa298
Mon Nov 28, 2016 10:00 am
Based on unscientific testing the 2.5" drive I have (1TB Pi drive) takes greater than 0.6A to spin up (won't work on the Pi2 unless the high usb power setting is put in). From My own and others experience the Pi3 can use 1.3A when running (particularly when running the cores at their full speed).
0.6 + 0.6 + 1.3 = 2.5A and from my unscientific testing that's not enough.
Return to “Advanced users”
