DaHai8
Cannot Access Pi from another Subnet
Sun Nov 27, 2016 7:31 am
I have a raspberry Pi connected to my pfSense Router at 192.168.1.4
My Laptop is connected to my pfSense Router at 192.168.2.124
I cannot Ping or SSH or otherwise connect to my Pi from my Laptop.
I can, however, Ping my Pi from my Router's built-in Ping utility.
I have these set in iptables-save on the Pi:
-A INPUT -m iprange --src-range 192.168.3.0-192.168.3.255 -j ACCEPT
-A INPUT -m iprange --src-range 192.168.2.0-192.168.2.255 -j ACCEPT
-A INPUT -m iprange --src-range 192.168.1.0-192.168.1.255 -j ACCEPT
And I have dhcpcd.conf set on the Pi:
interface eth0
static ip_address=192.168.1.4/24
static routers=192.168.1.1
static domain_servers=192.168.1.1 8.8.8.8
I should also mention that I have a WiFi AP on another Subnet: 192.168.3.2, and I can ping it from my Laptop and from the Router.
Any help/suggestions/ideas/pointers are greatly appreciated!!!
Spit
Re: Cannot Access Pi from another Subnet
Sun Nov 27, 2016 8:00 am
What are the subnet masks on each of them?
DaHai8
Sun Nov 27, 2016 8:40 am
Each subnet mask is /24
B.Goode
Sun Nov 27, 2016 8:51 am
Maybe the router does not have a route from 192.168.2.x to 192.168.1.x ?
For comparison, how does the Router know how to route from 192.168.2.124 (laptop) to 192.168.3.2 (ap)?
Can you ping the router from the RPi?
DaHai8
Sun Nov 27, 2016 9:00 am
All the routes on all the subnets are the same: Generic and open.
The "Anti-Lockout Rule" only exists on the Sif LAN, everything else is the same on the two other Lans.
I can't Ping the Router from the RPi because I can't SSH into it :P
I have to pull it off the Lan, plug it into a monitor/keyboard, make changes and pop it back on again, sigh.
I know the Pi is alive and working as it sends me emails. So I know it can't get out onto the Internet.
Spit
Sun Nov 27, 2016 9:28 am
Try changing the masks to 255.255.0.0
Sun Nov 27, 2016 12:03 pm
Spit wrote:Try changing the masks to 255.255.0.0
That isn't valid for a 192.168.xxx.xxx network, too many things are going to assume a /24 mask and it will break.
Use a 172.[16-31].xxx.xxx/16 network or a subnet from the 10.xxx.xxx.xxx/8 private range.
DaHai8
Mon Nov 28, 2016 2:27 am
yeah, can't really renumber my whole intranet. Thanks for the suggestion anyway.
I'm going to rebuild the Pi with a new/untouched Rasbian Lite image and see if it can be accessed across subnets - probably/hopefully something I've mucked up in the original config.
Thanks.
DaHai8
Mon Nov 28, 2016 4:12 am
Ok, found the culprit: OpenVPN Client.
If that's running, the Pi won't respond to requests from any other subnet.
When I stop it, I can Ping and SSH into from anywhere.
So.....
How do I set OpenVPN client to accept requests from other subnets?
Thanks!!
IanS
Wed Nov 30, 2016 3:31 pm
At a guess you have OpenVPN configured to send any traffic outside the local subnet into the VPN tunnel. This is normally ok, but you have more than just a single subnet in your local environment. You need to look how to exclude a specific network from being tunneled.
Return to “Advanced users”
