vzex
Problem with 2k hdmi output(half screen blank)
Mon Nov 14, 2016 2:58 am
I have a lcd printer controled by pi,and the host server is Photonic3D(https://github.com/area515/Photonic3D), the lcd is 5.5inch (2560*1440 resolution) connected to pi through the hdmi port.After many times' tests, finally i got image showed on the lcd screen.
but it's looks not right,please look at the pic below
the above half screen doesn't show anything, and the below...has been divided into two partsImage
Here' my config.txt
hdmi_force_hotplug=1
disable_overscan=1
framebuffer_depth=24
gpu_mem=192
framebuffer_ignore_alpha=1
hdmi_ignore_edid=0xa5000080
#hdmi_cvt 2560 1440 50 3 0 0 1
hdmi_group=2
hdmi_mode=87
hdmi_pixel_freq_limit=500000000
hvs_priority=0x32ff
config_hdmi_boost=4
framebuffer_width=2560
framebuffer_height=1440
and the tvservice -s is :
tvservice -s
state 0x120006 [DVI DMT (87) RGB full 16:9], 2560x1440 @ 50.00Hz, progressive
tvservice -m DMT
Group DMT has 20 modes:
           mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
           mode 5: 640x480 @ 72Hz 4:3, clock:31MHz progressive
           mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
           mode 8: 800x600 @ 56Hz 4:3, clock:36MHz progressive
           mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
           mode 10: 800x600 @ 72Hz 4:3, clock:50MHz progressive
           mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
           mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
           mode 17: 1024x768 @ 70Hz 4:3, clock:75MHz progressive
           mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
           mode 21: 1152x864 @ 75Hz 4:3, clock:108MHz progressive
           mode 28: 1280x800 @ 60Hz 16:10, clock:83MHz progressive
           mode 32: 1280x960 @ 60Hz 4:3, clock:108MHz progressive
           mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
           mode 36: 1280x1024 @ 75Hz 5:4, clock:135MHz progressive
           mode 47: 1440x900 @ 60Hz 16:10, clock:106MHz progressive
           mode 48: 1440x900 @ 75Hz 16:10, clock:136MHz progressive
           mode 51: 1600x1200 @ 60Hz 4:3, clock:162MHz progressive
           mode 58: 1680x1050 @ 60Hz 16:10, clock:146MHz progressive
  (prefer) mode 87: 2560x1440 @ 50Hz 16:9, clock:256MHz progressive
fbset -s
mode "1920x1200"
    geometry 1920 1200 1920 1200 24
    timings 0 0 0 0 0 0 0
    rgba 8/16,8/8,8/0,0/24
endmode
btw:I don't know why the fbset -s 's result is different from my real resolution
I guess this maybe a rotate problem, but i always fail with [email protected](usb wifi crash,and can't operate it with ssh), when I change it to [email protected], the rotation success(just looks like success, but shows the same image), So I can't find anyway to fix it now, Does anyone can solve this? Thanks!
aBUGSworstnightmare
Re: Problem with 2k hdmi output(half screen blank)
Mon Nov 14, 2016 8:49 am
1.) what TFT do you use? Paneloook doens't list any 5.5in display with 2560x1440pixels.
2.) I think you will have to use a custom HDMI timing instead of hdmi_cvt --> refer to viewtopic.php?f=29&t=24679
Joerg
vzex
Mon Nov 14, 2016 9:07 am
the tft is jdi's:https://www.aliexpress.com/store/produc ... 03471.html
I'll have a try later, thank you
6by9
Mon Nov 14, 2016 10:12 am
Maximum specified resolution is 1920x1080 @ 60Hz, so 2560x1440 @ 50Hz is almost 50% more pixels being processed a second and likely to fail (the composition hardware block is unlikely to be able to retrieve all the pixels from SDRAM in realtime, and the image tears or otherwise underflows resulting in corrupted images).
2560x1440 @ 24Hz is back within pixel rate limits hence likely to work.
I don't quite get your comment on rotation as I don't see anything in your configuration that specifies a rotation.
Seeing as you have
hvs_priority=0x32ff
in there I assume you have read through viewtopic.php?f=38&t=79330 where 3840 x 2160 @ 15Hz has been achieved, and 24Hz with overclocking.
Please don't send PMs asking for support - use the forum.
vzex
Mon Nov 14, 2016 1:28 pm
hdmi_timings=2560 0 16 11 16 1440 0 16 2 16 0 0 0 24 0 88473600 3
after I add this, the result doesn't change, just look the same :cry:
aBUGSworstnightmare
Mon Nov 14, 2016 1:34 pm
vzex wrote:hdmi_timings=2560 0 16 11 16 1440 0 16 2 16 0 0 0 24 0 88473600 3
And were did you get the timing details from? Display data sheet? Guessing around??
One question: this is a display coming from a mobile phone, isn't it? So your resolution should be 1440x2560 and not 2560x1440
So turn it to hdmi_timings=1440 0 16 2 16 2560 0 16 11 16 0 0 0 24 0 88473600 3
and try this
Last edited by aBUGSworstnightmare on Mon Nov 14, 2016 1:49 pm, edited 1 time in total.
aBUGSworstnightmare
Mon Nov 14, 2016 1:48 pm
6by9 wrote:...
hvs_priority=0x32ff
Hi 6by9,
is there any documentation for this parameter? Is using the hdmi_pixel_freq_limit=xx (in MHz) possible for DPI as well (since the timing data when using DPI is in hdmi_timings= ... too).
Joerg
6by9
Mon Nov 14, 2016 2:10 pm
aBUGSworstnightmare wrote:
6by9 wrote:...
hvs_priority=0x32ff
Hi 6by9,
You really need dom or PhilE to comment. This is altering the AXI bus arbiters to vary the access priority for the HVS to the AXI bus, so about as low level as you can get. Random messing could seriously impact system behaviour.
It is setting the HVS (Hardware Video Scaler) normal priority (lowest nibble - 0xf), panic priority (next nibble - 0xf0), transposer normal priority (3rd nibble - 0x200), and panic priority (4th nibble- 0x3000). 0=lowest priority, 0xF=highest priority.
hdmi_pixel_freq_limit appears to be altering the HDMI EDID parsing and will filter out any modes that exceed the defined value. Seeing as AFAIK DPI isn't using an EDID at all, then it shouldn't make any difference.
vzex
Mon Nov 14, 2016 2:25 pm
The arguments are not all right, I made some references from viewtopic.php?p=952843#p952843 , but still have somthing to guess, here is the data file:https://drive.google.com/open?id=0B_f34 ... kxPRnJUelU , just a second ago, after I changed the hz to 60, my pi dead...I have to re-write the flash now.
vzex
Mon Nov 14, 2016 2:27 pm
I've tested 1440*2560, it's not right either, 1/4 left and 1/4 right screen are blank,and the middle has the image.
aBUGSworstnightmare
Mon Nov 14, 2016 2:38 pm
Get rid of 'framebuffer_depth=24' statment and post your full config.txt
Asking again: Where did you get the timing details from? Are these valid or just 'edjucated guesses'.
What if setting front_/backp_porch = 1 and sync pulse to 2. Double the pixel frequency to see what happens.
Problem is that you don't know what your converter board is doing...
vzex
Mon Nov 14, 2016 4:01 pm
yeah,just"edjucated guesses"....
here is the new config.txt
dtparam=audio=on
disable_overscan=1
#framebuffer_depth=24
gpu_mem=192
#start_x=1
#hdmi_cvt=2560 1080 50 7 0 0 1
hdmi_group=2
hdmi_mode=87
hdmi_pixel_freq_limit=400000000
hvs_priority=0x32ff
max_framebuffer_width=2560
max_framebuffer_height=1080
config_hdmi_boost=4
hdmi_timings=2560 0 1 2 1 1440 0 1 2 1 0 0 0 24 0 176947200 3
Here is my newest config.txt,right now i have to reinstall the system,so i will tell you the result tomorrow
aBUGSworstnightmare
Mon Nov 14, 2016 5:48 pm
Your native display resolution is in portrait mode --> your timing MUST be portrait mode as well :!: NO WAY TO ROTATE A DISPLAY BY REVERSING THE TIMING!
So:
1. set your frame buffer right (orientation and resolution is wrong!)
2. set display timing to the right resolution
You can rotate the display later by using
#set display orientation
display_rotate=3
#framebuffer for landscape
This will rotate to landscape. Nevertheless your timings need to be portrait.
I.e. here's the timing for a Nexus 7 screen with 800x1280pixel resolution
hdmi_timings=800 0 16 16 64 1280 0 5 1 2 0 0 0 60 0 66800000 5
This is connected to DPI and not HDMI!
BTW: TC358870XBG has no scaler, so your seller should have implemented correct timings for the screen with correct EDID data. Can't your seller support with settings? Is the screen working on another host (i.e. PC able to give the correct resolution)
Last edited by aBUGSworstnightmare on Mon Nov 14, 2016 6:03 pm, edited 3 times in total.
6by9
Mon Nov 14, 2016 5:53 pm
Working backwards, do you really need to disable the EDID in the first place, or does the EDID correctly reflect the display?
The output from tvservice sort of implies that the EDID is correct (I think). You will need to set hdmi_pixel_freq_limit in config.txt to avoid 2560x1440 being ignored due to being out of spec.
vzex
Tue Nov 15, 2016 2:02 am
6by9 wrote:Working backwards, do you really need to disable the EDID in the first place, or does the EDID correctly reflect the display?
yes, the screen works well with pc,and when i parse the edid file, the result shows something like "guess 2560*[email protected]". I've not tried to disable the ignore_edid line yet,I'll try it after work
SimonHu
Sun Nov 27, 2016 8:46 pm
If you find out a working configuration, would you mind posting it here?
I happen to own the same printer, and am therefore very interested in the results of your research! And I suppose, there will be many others, I guess.
vzex
Mon Nov 28, 2016 2:19 am
SimonHu wrote:If you find out a working configuration, would you mind posting it here?
#hdmi_ignore_edid=0xa5000080
disable_overscan=1
gpu_mem=192
#start_x=1
hdmi_cvt=1440 2560 48
hdmi_group=2
hdmi_mode=87
hvs_priority=0x32ff
max_framebuffer_width=1440
max_framebuffer_height=2560
config_hdmi_boost=4
#hdmi_timings=1440 0 16 16 64 2560 0 5 2 1 0 0 0 50 0 176947200 3
the screen is 1440*2560, not 2560*1440!
So all the widths should be 1440,and heights be 2560.
@24hz the screen is half,@50hz the screen has a deformation,and @48hz the screen just works well now。
Thanks for all the people helping me!
SimonHu
Mon Nov 28, 2016 9:31 pm
Thank you very much! It works now, but the screen is flickering (short random flashes every couple of seconds). Has anyone an idea what could be the problem here? Your screen doesn't flicker at all, I guess?
SimonHu
Mon Nov 28, 2016 9:43 pm
Found it. It was just a bad HDMI cable (the one that was included with the printer, actually)
Again: THANK YOU VERY MUCH!
cambiaso87
Wed May 31, 2017 8:05 am
I follow the setting which mentioned by vzex. It work fine in potrait mode. However when i am using display_rotate=3. It does not fit the full screen in landscape mode. 2 big black border on the side. How can 2 solve the problems?
alrahimkhan
Sat Jul 22, 2017 6:34 pm
I have a raspberrypi connected to topfoison 1440p display https://www.alibaba.com/product-detail/ ... 5388Nep58E
I'm running windows 10 IOT
I need my pi to run this display, can anyone help me?
This is my config
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# GPU Firmware SHA256 checksum: 7CE2EF13CDD77F1782FFFF98533572503DF4B46765966CC7E18F6C6455B9623A
# kernel.img SHA256 checksum: 6C82C8720BE4EFB2951BDC01FA187B0B659227033EB7D7DB5ACA6324FD644D7F
# kernel.img git commit ID: f6706f4bd3b10c8294589f45082c8bdc4c50be59
# Boot
init_uart_clock=16000000    # Set UART clock to 16Mhz
kernel_old=1                # Load kernel.img at physical memory address 0x0
safe_mode_gpio=8            # A temp firmware limitation workaround
max_usb_current=1           # Enable maximum usb current
# Memory
gpu_mem=32                  # Set VC to 32MB, ARM DRAM to (1008-32)MB
hdmi_force_hotplug=1        # Enable HDMI display even if it is not connected (640x480)
# Overclocking
core_freq=250               # Frequency of GPU processor core in MHz
# Video
framebuffer_ignore_alpha=1  # Ignore the alpha channel for Windows.
framebuffer_swap=1          # Set the frame buffer to be Windows BGR compatible.
disable_overscan=1          # Disable overscan
hdmi_group=2                # Use VESA Display Mode Timing over CEA
hdmi_cvt 800 480 60 6 0 0 0 # Add custom 800x480 resolution (group 2 mode 87)
vstepanov
Mon Jun 25, 2018 5:47 am
I have the same problem as cambiaso87 has.
My 5.5 LCD has native resolution 1440*2560 and native portrait mode. It works only with 49Hz. With 50Hz image tremble and blank. With 48 Hz I see only half of screen (as in 1st post). With 49Hz lcd works fine. String in config.txt:
hdmi_cvt=1440 2560 49 3 0 0 1
When I use display_rotate (or display_hdmi_rotate) = 3, screen rotated but cutted from left and right. System resolutuion is 1440x1440!
I has tried all combinations in max_framebuffer_width, max_framebuffer_height, framebuffer_width, framebuffer_height, increased hdmi_pixel_freq_limit, but either RPi did not loaded, or maximum width was 1440.
I use last Jessie, tried previous versions, tried OpenElec and OSMC.
What is problem can be?
nosrev
Thu Aug 16, 2018 7:54 am
Hey guys,
just want to push this a bit.
In general i have two problems:
My screen is shifted to the bottom by approx 200px when using basic settings:
hdmi_group=2
hdmi_mode=87
(using over-scan does not help)
If i try to rotate the screen i have the same problem as my predecessors, it only displays a 1440*1440 square, necessary settings:
display_rotate=3
When trying to use the above provided timing i get half but no shifted image:
This half image also gets a half square if apply:
display_rotate=3
All images: https://imgur.com/a/MrfFZ0M
So i guess the shifted display problem i have is related to a timing issue and the rotate square thing is actually related to the frame buffer (since it is required to set it when rotating, otherwise the pi gets stuck at boot). :?:
Would be great if somebody who has knowledge in this could bring some light into the darkness. :idea:
nosrev
Mon Sep 17, 2018 8:30 am
Have been able to solve this problem by trail and error!
hdmi_timings=1440 0 16 16 64 2560 0 5 2 1 0 0 0 50 0 200000000 3
Did the trick for me. (changing the pixel_freq made the image fullscreen)
Still having problems with "DISPLAY_HDMI_ROTATE" (can not get rid of the square)
I read something at the official doc https://www.raspberrypi.org/documentati ... t/video.md that this requires additional memory, but even splitting to 256MB does not make a change.
Return to “Advanced users”
Who is online
Users browsing this forum: No registered users and 21 guests
