Cowardlydoomsday
pi to pi screen sharing
Tue Nov 01, 2016 7:24 pm
w
Last edited by Cowardlydoomsday on Thu Feb 16, 2017 7:51 pm, edited 1 time in total.
klricks
Re: pi to pi screen sharing
Tue Nov 01, 2016 11:44 pm
Cowardlydoomsday wrote:Can anyone help me with this? I'd like to screen share through a VNC from one pi to another. I've done it with a windows machine. RealVNC's website says that version 5.3.2 is already loaded on Jessie. I can't find it.
RealVNC is installed on the latest image of Raspbian Jessie with PIXEL. If you have not recently downloaded and installed the latest version then you can update Jessie following instructions found here: https://www.raspberrypi.org/blog/introducing-pixel/
The RVNC server must be enabled using the RPi config utility in [Menu] --> [Preferences] or by the sudo raspi-config utility.
Do the above on the remote RPi only then reboot.
On the local RPi run VNC Viewer found in [Menu] --> [Internet]
Cowardlydoomsday
Wed Nov 02, 2016 9:51 pm
Some other docs I read online said to go to
Menu > Preferences > Raspberry Pi Configuration > Interfaces. Ensure VNC is Enabled
to enable the vnc. This path does not exist on my pi.
wildfire
Wed Nov 02, 2016 11:27 pm
Try...
sudo raspi-config
Advanced options, VNC.
E8 85 A2 64 C9 64 81 94 64 81 95 64 89 84 89 96 A3
Still NF Shirls
Cowardlydoomsday
Thu Nov 03, 2016 2:37 pm
Its not there
klricks
Thu Nov 03, 2016 5:05 pm
Cowardlydoomsday wrote:Some other docs I read online said to go to
If the option does not appear in the GUI configuration or in sudo raspi-config, then you have not updated to the latest Raspbian Jessie with Pixel.
Return to “Advanced users”
