aBUGSworstnightmare
Pixel desktop is not using full screen resolution
Sun Oct 16, 2016 11:59 am
today I have a somehow special problem and don't know where to post it in the forum so I decided to use the 'advanced' thread.
My Raspberry is configured for using the 24bit DPI overlay (dpi24.dtbo). Basically, the display (CPT CLAA070WP03XG - Nexus 7 display) is working, but the PIXEL desktop is not using the full screen resolution.
I made a short test, running two OMXplayer instances and a picture slideshow (the images are 1280x800pixels)
!/bin/bash
screen -dmS pic1 sh -c 'feh -Y -x -q -D 3 -B black -F -Z -z /home/pi/Pictures; exec bash'
screen -dmS vid3 sh -c 'omxplayer --win "640 440 1280 800" /home/pi/Videos/trailer_1080p.mov; exec bash'
screen -dmS vid2 sh -c 'omxplayer --win "0 0 640 360" /home/pi/Videos/trailer_1080p.mov; exec bash'
Upper left OMXplayer window ("0 0 640 360") is perfectly aligned.
Note the gap on the left side of the screen with not PIXEL desktop.
OMXplayer window in lower right corner ("640 440 1280 800") is perfectly aligned too. Note the gap on the right side.
As you can see from the pictures PIXEL is not using the whole display. I've made a screenshot with 'scrot', capturing the entire screen. The resulting image is only 1200x800 pixels.
Since OMXplayer is able to use the entire display I need to know why PIXEL is not able doing the same!
Here is my config.txt file:
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# set display orientation
display_rotate=3
# uncomment to force a console size. By default it will be display's size minus
# overscan.
framebuffer_width=1280
framebuffer_height=800
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
gpu_mem=384
# Enable DPI
enable_dpi_lcd=1
# Make DPI default output
display_default_lcd=1
# custom HDMI mode
# https://www.raspberrypi.org/forums/viewtopic.php?p=613926#p613926
# https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=24679
dpi_group=2
dpi_mode=87
#additional config settings
gpu_mem=392
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
dtparam=spi=off
# Uncomment this to enable the lirc-rpi module
dtoverlay=dpi24.dtbo
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
# DPI output format definitions
# https://www.raspberrypi.org/forums/viewtopic.php?p=628061#p628061
# DPI structure: https://www.raspberrypi.org/forums/viewtopic.php?p=617719#p617719
# output_format:
#   1: DPI_OUTPUT_FORMAT_9BIT_666
#   2: DPI_OUTPUT_FORMAT_16BIT_565_CFG1
#   3: DPI_OUTPUT_FORMAT_16BIT_565_CFG2
#   4: DPI_OUTPUT_FORMAT_16BIT_565_CFG3
#   5: DPI_OUTPUT_FORMAT_18BIT_666_CFG1
#   6: DPI_OUTPUT_FORMAT_18BIT_666_CFG2
#   7: DPI_OUTPUT_FORMAT_24BIT_888
# rgb_order:
#   1: DPI_RGB_ORDER_RGB
#   2: DPI_RGB_ORDER_BGR
#   3: DPI_RGB_ORDER_GRB
#   4: DPI_RGB_ORDER_BRG
# output_enable_mode:
#   0: DPI_OUTPUT_ENABLE_MODE_DATA_VALID
#   1: DPI_OUTPUT_ENABLE_MODE_COMBINED_SYNCS
# invert_pixel_clock:
#   0: RGB Data changes on rising edge and is stable at falling edge
#   1: RGB Data changes on falling edge and is stable at rising edge
# hsync polarity:
#   0: default for HDMI mode
#   1: inverted
# vsync polarity:
#   1: inverted
# output_enable_polarity:
#   1: inverted
# hsync phase:
#   0: rising edge
#   1: falling edge
# vsync phase:
#   0: rising edge
#   1: falling edge
# output_enable phase:
#   0: rising edge
#   1: falling edge
dpi_output_format=458775
# HDMI timing definitions
#https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=24679
# hdmi_timings= <h_active_pixels>
#		  LCD module horizontal resolution
#               <h_sync_polarity>
# 		  0: active low
#		  1: active high
#               <h_front_porch>
#		<h_sync_pulse>
#		<h_back_porch>
#		<v_active_lines>
#		  LCD module vertical resolution
#		<v_sync_polarity>
# 		  0: active low
#		  1: active high
#		<v_front_porch>
#		<v_sync_pulse>
#		<v_back_porch>
#		<v_sync_offset_a>
#		<v_sync_offset_b>
#		<pixel_rep>
#		<frame_rate>
#		  screen refrech rate (50/60Hz supported only!)#
#		<interlaced>
#		<pixel_freq>
#		  calculates as: <h_active_pixels> * <v_active_lines> * <frame_rate>
#		<aspect_ratio>
#		  HDMI_ASPECT_4_3 = 1
#		  HDMI_ASPECT_14_9 = 2
#		  HDMI_ASPECT_16_9 = 3
#		  HDMI_ASPECT_5_4 = 4
#		  HDMI_ASPECT_16_10 = 5
#		  HDMI_ASPECT_15_9 = 6
#		  HDMI_ASPECT_21_9 = 7
#		  HDMI_ASPECT_64_27 = 8
hdmi_timings=800 1 0 16 64 1280 1 8 1 0 0 0 0 60 0 66800000 5
As you can see the display resolution I'm using is correct. I've configured a frame buffer of the same size (1280x800) in addition, but the effect: Borders left and right of PIXEL desktop, regardless is frame buffer is configured or not.
Any ideas/recommendations how to solve this?
By the way: made a clean install using latest image; update/upgrade/ etc. was all done before activating the overlay and custom dpi timing. Already using/tested a lot of displays using this approach but never saw this happen.
Rgds
Joerg
aBUGSworstnightmare
BUG in how Pixel handles the frame buffer / display resoluti
Mon Oct 17, 2016 7:18 pm
Hey there,
since nobody seems to be able to answer to this question I made some more tests this evening. To me it looks like there is a BUG in Pixel - handling of frame buffer is wrong! Every resolution that is bigger than 1200pixels gets truncated to 1200!
Here is how I tested this
Folder with full resolution picture: https://drive.google.com/drive/folders/ ... sp=sharing
In my config I'm using
framebuffer_height=760
This gives me a full screen image on my display. Testing the resolution with
xdpyinfo | grep dimensions
gives a strange result:
My reported desktop is only 1200x760pixel!
Systeminfo in Kodi tells me it's 1280x760 ... so: how to fix this? The native resolution of my screen is 1280x800 btw ...
aBUGSworstnightmare
Re: Pixel desktop is not using full screen resolution
Tue Oct 18, 2016 5:11 am
changing the frame buffer to
gives me 40 pixel wide black borders on left and right side.
now reports resolution to be 1200x800 pixel
aBUGSworstnightmare
Tue Oct 18, 2016 11:18 am
O.K. ... must be something else (and not Pixel related) since old Jessie image shows same result.
So ... I will stop further investigation on this topic (at least for now) and simply use the display as-is @ 1200x760pixel. Image quality of the Nexus 7 display is great (it's IPS technology) and resolution when using 'overlays' (OMXplayer/Kodi) 'switches' to WXGA anyhow, so who cares about some missing pixel at this PPI ratio :shock:
Return to “Advanced users”
