schmitta
Circuit diagram
Sat Sep 03, 2016 7:19 am
Is there a circuit diagram for the PI Zero?
Re: Circuit diagram
Sat Sep 03, 2016 8:13 am
No.
However, the SoC connections will be similar to the Pi 1A, for which the diagrams are available (original Pi A/B). There will be some differences, such as the improved voltage regulator circuit, which is similar to that on the A/B+ and is available somewhere, just without the power LED and protective diode and fuse. The GPIO connector has the same pinout as all of the 40-pin Pi models.
bensimmo
Re: Circuit diagram
Sat Sep 03, 2016 11:09 am
The other option if you anything specific is to use the X-Ray thay Giles Read produced
Here is the original Pi Zero (v1.2) https://www.flickr.com/photos/ultrapurp ... otostream/
He also has the newer v1.3 and other Pi.
Can can try and follow the traces to find out what you need.
Return to “Advanced users”
