Timestamp multiple photos.
Posted: Sun Aug 07, 2016 4:22 pm
by TheNerdyTeacher
I've been putting together a code to create a photo booth for a school events, but I have run into one small problem that I cannot overcome. Each new photo created has the same name and overwrites the old one when it gets uploaded to Dropbox. Below is the code.
from os import system
import picamera
import time
from gpiozero import Button
camera = picamera.PiCamera()
button = Button(18)
camera.start_preview()
while True:
    try:
        button.wait_for_press()
        camera.annotate_text='5'
        time.sleep(1)
        camera.annotate_text='4'
        time.sleep(1)
        camera.annotate_text='3'
        time.sleep(1)
        camera.annotate_text='2'
        time.sleep(1)
        camera.annotate_text='1'
        time.sleep(1)
        camera.annotate_text=' '
        camera.capture("aaa.jpg")
        time.sleep(1)
        time.sleep(1)
        time.sleep(1)
        camera.capture("bbb.jpg")
        time.sleep(1)
        time.sleep(1)
        time.sleep(1)
        camera.capture("ccc.jpg")
        camera.stop_preview()
        camera.close
        print "Cropping photo1"
        system("convert aaa.jpg -resize x400 -gravity center -crop 400x400+0+0 =repage aaa_crop.jpg")
        print "Croppinng photo2"
        system("convert bbb.jpg -resize x400 -gravity center -crop 400x400+0+0 =repage bbb_crop.jpg")
        print "Croppinng photo3"
        system("convert ccc.jpg -resize x400 -gravity center -crop 400x400+0+0 =repage ccc_crop.jpg")
        print "resizing photo1"
        system("convert aaa_crop.jpg -extent 1200x1800-100-100 photo_strip.jpg")
        print "top right"
        system("composite -compose atop -geometry +700+100 aaa_crop.jpg photo_strip.jpg photo_strip.jpg")
        print "middle left"
        system("composite -compose atop -geometry +100+700 bbb_crop.jpg photo_strip.jpg photo_strip.jpg")
        print "middle right"
        system("composite -compose atop -geometry +700+700 bbb_crop.jpg photo_strip.jpg photo_strip.jpg")
        print "bottom left"
        system("composite -compose atop -geometry +100+1300 ccc_crop.jpg photo_strip.jpg photo_strip.jpg")
        print "bottom right"
        system("composite -compose atop -geometry +700+1300 ccc_crop.jpg photo_strip.jpg photo_strip.jpg")
        print "Uploading to Dropbox"
        system ("dropbox_uploader upload photo_strip.jpg 'Nerdy Booth'/")
    except KeyboardInterrupt:
        break
I'm not sure how to get the file to change names each time. Maybe my code is overly complex and the problem is simpler than I realize. Any help would be appreciated.
Thanks!
Re: HOW TO: Timestamp multiple photos.
Posted: Sun Aug 07, 2016 9:02 pm
by DougieLawson
Why not change those camera.capture lines to write a unique filename at that point, then pass the filename variable to the system calls that convert them, etc.
It's very easy to use current date/time as a filename.
#!/usr/bin/python
import time, datetime, picamera
tstamp = datetime.datetime.now()
filename = tstamp.strftime(tformat)
camera.capture(filename+'.jpg')
