alfista2600
I'm in the twilight zone.... using dd to create SD failing
Wed Aug 03, 2016 6:03 pm
So,
since 2013 I've always refreshed SD cards using dd and a fresh RPi image.
Today, I've done this with three micro SD cards, and each time, after taking 55 seconds to transfer 1.3gb of Jessie Light Raspbian, I boot back into the exact same install that was on the Pi prior to applying the image. I've done this on a mac and on a linux box.
sudo dd if=/Users/me/Downloads/2016-05-27-raspbian-jessie-lite.img of=/dev/rdisk4 bs=1m
I can't modify the partitions on the Mac or the linux box either, so something weird is up.
what happened to my brain?
fruit-uk
Wed Aug 03, 2016 6:10 pm
Did you sync before unmounting?
Otherwise you may have three dead cards, unlikely but...
B.Goode
Re: I'm in the twilight zone.... using dd to create SD faili
Wed Aug 03, 2016 7:01 pm
When this question arose recently the poster eventually realised that the image being flashed was actually a backup of the previous configuration of the RPi. Might be worth double-checking... ?
kusti8
Wed Aug 03, 2016 8:34 pm
Is it the right disk and did you unmount it first?
alfista2600
Thu Aug 04, 2016 1:16 pm
I pulled another disk from a working, test pi and was able to execute my dd process successfully. I think it was a mix of a couple bad flash drives, bad record keeping, and frustration in unmounting/powering off. I cannot partition any of the bad drives with a mac or linux box, or my DSLR (it only formats the boot partition). It just seemed to be one of those bad technology days.
Now if I could figure out why 'motion' crashes with the PiCam...
Thanks for everyone's tips!
Return to “Advanced users”
