PalaniKasi
How to controll DS2413 two GPIOS
Thu Jun 23, 2016 9:15 am
Hey guys,
I'm interfacing DS2413 chip for controlling two GPIOs through one wire...I was struggling with writing data and getting output.since it has a family code 3A.In the /sys/bus/w1/devices/3a-0000000181f8b folder there are four files are available.
driver
id
name
power
rw
subsystem
uevent
my question is where to write instruction and how to get output....Thanks in advance...
Regards,
Palanikasi
PalaniKasi
Re: How to controll DS2413 two GPIOS
Fri Jun 24, 2016 4:46 am
This is my simple code for setting PIOA pin in 2413..But when i check with multimeter the pin voltage is zero only...
import os
import time
os.system('modprobe w1-gpio)
os.system('modprobe w1-therm')
temp_sensor="/sys/bus/w1/devices/3a-000000181f8b/rw"
def data():
      f=open(temp_sensor,'w')
      f.wite("/x5A")
      f.write("/x01")
      f.close()
data()
SonOfAMotherlessGoat
Fri Jun 24, 2016 4:50 am
Do you have more code that you reference? You've assigned 'f' to an object opening another object named 'temp_sensor' but it doesn't look like you've specified what 'temp_sensor' is.
Edit: Ah, Stealth Edit! Now it's there.
Account Inactive
Fri Jun 24, 2016 4:56 am
I would suggest following Dougie's advice over on the thread at viewtopic.php?f=44&t=92700
Account Inactive
PalaniKasi
Fri Jun 24, 2016 5:02 am
That temp_sensor define the path of my rw file which is present inside the driver.i'm writing FE followed by FA for setting pin to high based on the datasheet....But its not at all showing any voltage at the PIO pins
Fri Jun 24, 2016 5:11 am
Can you post a link to the datasheet, the one from Max has a different set of hex codes?
Account Inactive
Fri Jun 24, 2016 5:25 am
Thanks, just looking over the code, you're missing a terminating apostrophe:
os.system('modprobe w1-gpio')
but that's probably not the problem.
Account Inactive
PalaniKasi
Fri Jun 24, 2016 5:29 am
Actually those two lines are not required...
Fri Jun 24, 2016 6:12 am
I'm assuming that the code you posted isn't the code you are running then, as Python wouldn't get past that closing apostrophe.
Sorry, got sidetracked, reading the PDF.
Account Inactive
Return to “Advanced users”
