ahri
PSU Recommendation (UK)?
Mon Aug 20, 2012 9:41 pm
Hi, I've been playing with my Pi and finding that I can crash it fairly easily, so I did a bit of research and noted that I had a very poor PSU (400mA) and swapped it for the largest alternative I have in the house (a Kindle PSU @ 850mA). I can still crash it fairly easily merely running: rtorrent, rsync & compiling for good measure ;)
Now, according to Farnel the max it should be pulling is 1.2A, so obviously I should go for 1.2A+, but having read a few reviews on Amazon it's not clear what I should go for exactly, as I find reviews like http://www.amazon.co.uk/review/R10KUWVY ... lectronics for a 2A where two people specifically call it out as being unable to power the Pi (er, what: it's Samsung, so presumably reputable and accurately specified, and 2A should be way more than required?!)
So I'm asking for specific recommendations. I don't have a USB hub, I do have an external (powered) drive array, and I will likely plug in a USB sound card at some point. I'm probably what most people would term a "power user" as I will be compiling on there (probably Gentoo at some point when I can be bothered) and I will be pushing it, and probably playing with overclocking it too.
What specific PSU do you power users/overclockers recommend? First and foremost I want the thing stable!
elatllat
Re: PSU Recommendation (UK)?
Mon Aug 20, 2012 9:52 pm
rtottent can make the rpi crash with any power suppy, unless you do this http://www.raspberrypi.org/phpBB3/viewt ... 24&t=14394
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
thunderbird1
Mon Aug 20, 2012 9:53 pm
Maplin mini USB power supply (product code N31FU), with mini USB 2.0 to micro USB adapter (product code N35JQ). Mains AC to 5V DC with up to 2.5A of current. Rock solid with Raspberry Pi.
No connection with Maplin -- just a satisfied customer.
TB1
ahri
Mon Aug 20, 2012 10:04 pm
elatllat wrote:rtottent can make the rpi crash with any power suppy, unless you do this http://www.raspberrypi.org/phpBB3/viewt ... 24&t=14394
Interesting, I'll ensure turbo mode is off. Thanks!
ahri
thunderbird1 wrote:Maplin mini USB power supply (product code N31FU), with mini USB 2.0 to micro USB adapter (product code N35JQ). Mains AC to 5V DC with up to 2.5A of current. Rock solid with Raspberry Pi.
TB1
Thanks for the tip, I'll check it out :)
geep999
Mon Aug 20, 2012 10:42 pm
I've been very happy with this surge protected PSU made by Masterplug supplying 2x1A.
http://www.screwfix.com/p/masterplug-su ... lack/28341
Actually bought mine in Sainsbury's post-Christmas sale @ £4.99, so shop around.
Masterplug also do one with a single 1A USB output too, also available at Screwfix @ £6.99
http://www.screwfix.com/p/masterplug-us ... lack/45307
Cheers,
Peter
Return to “Advanced users”
