insmod: ERROR: could not insert module modul.ko: Invalid mod
Posted: Sun Apr 24, 2016 12:52 pm
by mesutparis
hello all:
I am developping some hello world modules for my Raspberry PI 3.
i have this kernel on my Rpi : Linux raspberrypi 4.1.19+ #858 Tue Mar 15 15:52:03 GMT 2016 armv6l GNU/Linux
and i cross compile on my computer:
i use the kernel : linux-rpi-4.1.y and a hello world program:
#include <linux/module.h> // Needed by all modules
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Salah ABBAS, 2016");
MODULE_DESCRIPTION("Demo module for cross compiling");
int init_module(void)
// Print a message in the kernel log
printk("Hello world\n");
// A non 0 return means init_module failed; module can't be loaded.
return 0;
void cleanup_module(void)
printk("Goodbye world\n");
i use a makefile:
# My Module Makefile
obj-m := test1.o
KDIR := /home/salah/Projects/Test/Kernel/linux-rpi-4.1.y/
PWD := $(shell pwd)
all:
$(MAKE) -C $(KDIR) M=$(PWD) modules
clean:
$(MAKE) -C $(KDIR) M=$(PWD) clean
and my cross compilation finishes well, and i get the : test1.ko file whose properties are:
//////// $ modinfo test1.ko
filename: /home/pi/test1.ko
description: Demo module for cross compiling
author: xxxx YYYYY, 2016
license: GPL
srcversion: 6EFACA1B07E7CCC55078D48
depends:
vermagic: 4.1.21 mod_unload modversions ARMv7 p2v8
and when i run : sudo insmod test1.ko
i get the following error:
insmod: ERROR: could not insert module test1.ko: Invalid module format
do you have any idea where this is coming from ?
Thank you in advance.
Re: insmod: ERROR: could not insert module modul.ko: Invalid
Posted: Sun Apr 24, 2016 1:25 pm
by Dutch_Master
Kernel mismatch between the RPi and your work machine? Test bulding the program on the RPi itself, this way you can deduct if the error is related to the cross-compiling. It narrows down your search by 50%! :idea:
Posted: Tue Apr 26, 2016 7:44 pm
by mesutparis
Hello, and thank you for tour advices.
i compiled the kernel + my module on my Raspberry, and the insmod gives the same error message !
I cross compiled, on my computer, a simple .c file just printing "hello world", and cross compilation went well, and i executed it on my Raspberry successfully !
so, my conclusion is that: my cross compilation chain works well.
There is a problem when i try to insert a compiled "module + kernel" into my Raspberry.
Do you have any ideas to try ?
Thank you so much.
