__Plasma__
Mounting an SMB share at boot not working
Thu Apr 21, 2016 10:05 pm
So I have looked at a few guides at the following URL's:
http://geeks.noeit.com/mount-an-smb-net ... pberry-pi/
https://rasspberrypi.wordpress.com/2012 ... pberry-pi/
I have added it to /etc/fstab and also made a credentials file. Works fine but when I reboot the Pi I still have to issue a manual command get these to mount.:
sudo mount -a
I tried setting the "wait for network on boot" setting but still fails to auto mount. Is there something I am missing?
Plasma
DirkS
Re: Mounting an SMB share at boot not working
Fri Apr 22, 2016 12:35 am
Assuming you're running Raspbian Jessie...
Try adding
noauto,x-systemd.automount
to the options.
AIUI it delays mounting until it is accessed.
For more info on this search the forum for these options
__Plasma__
Sat Apr 23, 2016 3:47 pm
DirkS wrote:Assuming you're running Raspbian Jessie...
Try adding
to the options.
Thanks DirkS, that looks to have done the trick I simply added x-systemd.automount to the line in fstab and all looks to be working fine now.
//192.168.2.1/Multimedia /media/Plasmas-NAS/Multimedia cifs credentials=/home/pi/.smbcredentials,uid=1000,gid=1000,x-systemd.automount 0 0
Kind Regards
Plasma
JimmyN
Sat Apr 23, 2016 5:50 pm
Including the "noauto" option stops any automounting of the share by fstab. That includes using "sudo mount -a" which won't work if you've included the "noauto" option in the fstab line. You'll have to use a manual mount command.
By not including "noauto" you will get a failed mount error in the log every time it boots, since fstab will try to automount it and fail, even though systemd will be mounting it later. But you can ignore the failed mount message, and you can still use a "sudo mount -a" command.
__Plasma__
Sat Apr 23, 2016 6:35 pm
JimmyN wrote:By not including "noauto" you will get a failed mount error in the log every time it boots, since fstab will try to automount it and fail, even though systemd will be mounting it later. But you can ignore the failed mount message, and you can still use a "sudo mount -a" command.
Thanks for the extra info, I'll take those points in to consideration and will more than likely add the noauto option too.
Plasma
Return to “Advanced users”
