The first of all, I want to say "Hello" to all of you, because Ihave been using RPi for two years, but it's my first post on this forum.
I have some questions about powering and OC of RPi3. I was using RPi2 previously, but I unfortunatelly damaged it, so I decicded that it's time to try some newer.
I'm using RPi as on-board computer in very extreme conditions with very big accelerates, like 50g, on big altitude.
It isn't simple to power this device in that condition, because the max weight of all devices (RPi and other) is 200-250g.
I created simple powering system, but it's max current is 1,2..1,5A.
To RPi I have connected camera and more devices using SPI, UART and I2C.
RPi2 was working properly on that current, but the RPi3 has bigger current requirements.
I haven't any periferals via USB connected to it, excluding one device with external powering.
I also don't use any displays, connecting to RPi by signals on GPIO pins.
So, my question is: did anyone try to use RPi with as small current?
My second question is overclocking. Did anyone try 1,7GHz? My problem isn't heating, I'm interested in voltage of it.
On RPi, I'm using modified Raspbian, the current of devices on GPIO (from 5V pins) is maximum 100mA.
Thanks for replies,
DP
