asandford
Re: Linux kernel is now 4.4
Tue May 17, 2016 4:44 pm
dom wrote: Are you trying to boot from remote SCSI device? If /lib/modules are on the remote device then the modules won't help you.
If you are just mounting the remote SCSI device after booting, then the module should be fine. Did you add it to /etc/modules?
The /root partition is on a remote device attached via iscsi, the pi boots from the sdcard but has nothing apart from /boot partition.
On a brand new install of jessie, i've put the (i think) required modules in /etc/modules, installed open-iscsi and rebooted:
[email protected]:~# lsmod | grep -i scsi
iscsi_tcp               9263  0
libiscsi_tcp           12716  1 iscsi_tcp
libiscsi               35610  2 libiscsi_tcp,iscsi_tcp
I defined a disk on the NAS, but it can't see it:
[email protected]:~# iscsiadm --mode discovery --type sendtargets --portal 192.168.0.30
iscsiadm: No portals found
dmesg shows it isn't fully up before open-iscsi is kicked off:
[email protected]:~# dmesg | grep -i scsi
[    0.144655] SCSI subsystem initialized
[    0.260800] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.183420] Loading iSCSI transport class v2.0-870.
[    2.465570] systemd-sysv-generator[98]: Ignoring creation of an alias umountiscsi.service for itself
[    2.647682] systemd[1]: Found dependency on open-iscsi.service/start
[    2.668901] systemd[1]: Breaking ordering cycle by deleting job open-iscsi.service/start
[    2.673193] systemd[1]: Job open-iscsi.service/start deleted to break ordering cycle starting with basic.target/start
[    3.213170] iscsi: registered transport (tcp)
So, the service is dead, but binary is still running:
[email protected]:~# service open-iscsi status
● open-iscsi.service - LSB: Starts and stops the iSCSI initiator services and logs in to default targets
   Loaded: loaded (/etc/init.d/open-iscsi)
  Drop-In: /lib/systemd/system/open-iscsi.service.d
           └─fix-systemd-deps.conf
   Active: inactive (dead)
Warning: Unit file changed on disk, 'systemctl daemon-reload' recommended.
[email protected]:~# ps -ef | grep iscsi
root        74     2  0 16:27 ?        00:00:00 [iscsi_eh]
root      1057  1047  0 16:30 pts/0    00:00:00 grep iscsi
dom
Tue May 17, 2016 5:45 pm
asandford wrote: The /root partition is on a remote device attached via iscsi, the pi boots from the sdcard but has nothing apart from /boot partition.
So the module for supporting iscsi is on the iscsi device. That's not going to work.
I'm afraid a custom kernel build with the module is the best option for you.
Unfortunately there are dozen of devices and file systems that could potentially be useful for booting from,
but as you have seen, these are often quite large, so building them all into kernel is not a good option.
asandford
Tue May 17, 2016 6:20 pm
dom wrote:[
OK, thanks - I'll have to wait for pxe boot then.
Got iscsi working now (it is confirmed broken on systemd, but works with the init scripts):
[email protected]:~#  /etc/init.d/open-iscsi start
[....] Starting open-iscsi (via systemctl): open-iscsi.service
. ok
   Active: active (running) since Tue 2016-05-17 17:57:39 UTC; 10s ago
  Process: 1195 ExecStop=/etc/init.d/open-iscsi stop (code=exited, status=0/SUCCESS)
  Process: 1188 ExecStop=/etc/init.d/umountiscsi.sh stop (code=exited, status=0/SUCCESS)
  Process: 1260 ExecStart=/etc/init.d/open-iscsi start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/open-iscsi.service
           ├─1272 /usr/sbin/iscsid
           └─1273 /usr/sbin/iscsid
May 17 17:57:39 raspberrypi iscsid[1271]: iSCSI logger with pid=1272 started!
May 17 17:57:39 raspberrypi open-iscsi[1260]: Starting iSCSI initiator service: iscsidln: failed to create symbolic link ‘/run/sendsigs.omi…ile exists
May 17 17:57:39 raspberrypi open-iscsi[1260]: .
May 17 17:57:39 raspberrypi open-iscsi[1260]: Setting up iSCSI targets:
May 17 17:57:39 raspberrypi open-iscsi[1260]: iscsiadm: No records found
May 17 17:57:39 raspberrypi open-iscsi[1260]: Mounting network filesystems:.
May 17 17:57:39 raspberrypi open-iscsi[1260]: Enabling network swap devices:.
May 17 17:57:39 raspberrypi systemd[1]: Started LSB: Starts and stops the iSCSI initiator services and logs in to default targets.
May 17 17:57:40 raspberrypi iscsid[1272]: iSCSI daemon with pid=1273 started!
Hint: Some lines were ellipsized, use -l to show in full.
192.168.0.30:3260,1 iqn.1991-05.com.microsoft:winnas-tt1-target
192.168.134.1:3260,1 iqn.1991-05.com.microsoft:winnas-tt1-target
192.168.235.1:3260,1 iqn.1991-05.com.microsoft:winnas-tt1-target
AikonCWD
Tue May 17, 2016 10:03 pm
It is posible to overclock the SD card with the new firmware? I found 2 different commands:
dtoverlay=sdhost,overclock_50=100
dtparam=sd_overclock=100
Which command should I use? Thanks
My e-mail = [email protected]
dom
Tue May 17, 2016 10:20 pm
AikonCWD wrote:It is posible to overclock the SD card with the new firmware? I found 2 different commands:
The latter is the recommended one. The former shouldn't be used.
Duncb82
Wed May 18, 2016 8:31 am
To expand on my wifi issue a bit, it seems it can connect but the connection only holds for around 10 seconds
If I do an ifup --force wlan0 then ping google, it will run for around 10 seconds before the network becomes unreachable
I tried an edimax dongle I had lying around (Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]) and it worked perfectly, so it seems its just an issue with the official adapter
I dont thinks it's a hardware fault, as dropping back to 4.1 it works perfectly
I've tried turning power management off, and also tried the 2 cmdline.txt additions mentioned at the start of the thread here:
viewtopic.php?f=29&t=130429
Neither made a difference
Aydan
Wed May 18, 2016 11:19 am
Have you tried putting the module into an initramsf?
I did that on one of my SD cards for lvm.
You just have to be careful with kernel updates, or copy kernel.img to e.g. kernel-4.1.19-456.img and specify this kernel + the corresponding initramfs in config.txt so apt can't screw up booting by replacing the kernel.
Regards
Aydan
humke
Mon May 23, 2016 8:40 am
The first line of hash-signs should have one # added ;)
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
This update bumps to rpi-4.4.y linux tree
Be aware there could be compatibility issues with some drivers
Discussion here:
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=144087
asandford
Tue May 24, 2016 12:33 am
Aydan wrote: Have you tried putting the module into an initramsf?
Regards
Aydan
Yes I have, and it only works if the iscsi modules are 'baked' into the kernel. As you say, any update to the kernel then breaks it all. I didn't know that a specific img could by loaded in the config.txt though - thanks for the 'heads-up' and I'll look into that.
gardar
Wed May 25, 2016 2:02 pm
After updating the kernel I see that TXD0 has been mapped on GPIO 32 where as previously it was mapped at GPIO 14.
Is this expected?
cjan
Sun May 29, 2016 1:18 am
4.4.11-v7+ #888, what is drm-vc4-next improve?
dom
Sun May 29, 2016 3:59 pm
cjan wrote:4.4.11-v7+ #888, what is drm-vc4-next improve?
You can see the changes here: https://github.com/raspberrypi/linux/pull/1463
Basically bringing raspberry pi kernel closer to the upstream kernel branch where the experimental graphics driver work occurs.
I can't give you details, but it should have no effect if you are not using the experimental graphics driver.
If you are, then I guess it's stability and performance improvements...
algorithm
Mon May 30, 2016 7:44 pm
dom wrote:
lbog wrote: Because in the kernel 4.4, those modules (ipv6, sit) are built-in:
That wasn't intentional. I've pushed an update where IPV6 is a module again.
@MrEngman does that make a difference to the behaviour you see?
Has this been re-reversed in the latest kernel(s)? I just burned a new image from the newest download at raspberrypi.org, did dist-upgrade and rpi-update. This is on a RPi3. So firmware is 2b9c0bfacfc11ee8bb9b30dc9cdb36289698f8a8 from 7 days ago, vcgencmd version is faf071dd4885c5ac1a89483d35a5326e7f69495f, kernel 4.4.11-v7+ #888. There's no "ipv6" in /etc/modules but ipv6 is enabled & functional. So it's built-in?
Mon May 30, 2016 9:31 pm
It's back as a module on 4.4.11+ & 4.4.11-v7+ #888
[email protected] /lib/modules # find . -name "*ipv6*"
./4.4.11+/kernel/net/6lowpan/nhc_ipv6.ko
./4.4.11+/kernel/net/ipv6
./4.4.11+/kernel/net/ipv6/ipv6.ko
./4.4.11+/kernel/net/ipv6/netfilter/nf_nat_ipv6.ko
./4.4.11+/kernel/net/ipv6/netfilter/nf_dup_ipv6.ko
./4.4.11+/kernel/net/ipv6/netfilter/ip6t_ipv6header.ko
./4.4.11+/kernel/net/ipv6/netfilter/nf_defrag_ipv6.ko
./4.4.11+/kernel/net/ipv6/netfilter/nf_conntrack_ipv6.ko
./4.4.11+/kernel/net/ipv6/netfilter/nf_nat_masquerade_ipv6.ko
./4.4.11+/kernel/net/ipv6/netfilter/nf_reject_ipv6.ko
./4.4.11+/kernel/net/ipv6/netfilter/nf_log_ipv6.ko
./4.4.11-v7+/kernel/net/6lowpan/nhc_ipv6.ko
./4.4.11-v7+/kernel/net/ipv6
./4.4.11-v7+/kernel/net/ipv6/ipv6.ko
./4.4.11-v7+/kernel/net/ipv6/netfilter/nf_nat_ipv6.ko
./4.4.11-v7+/kernel/net/ipv6/netfilter/nf_dup_ipv6.ko
./4.4.11-v7+/kernel/net/ipv6/netfilter/ip6t_ipv6header.ko
./4.4.11-v7+/kernel/net/ipv6/netfilter/nf_defrag_ipv6.ko
./4.4.11-v7+/kernel/net/ipv6/netfilter/nf_conntrack_ipv6.ko
./4.4.11-v7+/kernel/net/ipv6/netfilter/nf_nat_masquerade_ipv6.ko
./4.4.11-v7+/kernel/net/ipv6/netfilter/nf_reject_ipv6.ko
./4.4.11-v7+/kernel/net/ipv6/netfilter/nf_log_ipv6.ko
This is a doctor free zone.
algorithm
Tue May 31, 2016 12:03 pm
DougieLawson wrote:It's back as a module on 4.4.11+ & 4.4.11-v7+ #888
OK, great, but somehow it is also loaded by default and enabled on the network interfaces, except it's not in /etc/modules. So now I don't know where to disable it if I want that. Is use of /etc/modules deprecated? But "i2c-dev" is still in it.
Edit: so according to https://wiki.debian.org/DebianIPv6 the way to disable ipv6 is to add these lines to /etc/sysctl.conf
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
net.ipv6.conf.eth0.disable_ipv6 = 1
net.ipv6.conf.wlan0.disable_ipv6 = 1
That's not at all easy to remember (or find without googling) and does not seem to me like an improvement from using /etc/modules :-(
dom
Tue May 31, 2016 2:11 pm
Open /etc/modprobe.d/ipv6.conf (or create it) and add:
blacklist ipv6
algorithm
Tue May 31, 2016 6:06 pm
dom wrote:Open /etc/modprobe.d/ipv6.conf (or create it) and add:
blacklist ipv6
Thanks. On a fresh install (dist-upgraded) it exists and contains:
# Don't load ipv6 by default
alias net-pf-10 off
#alias ipv6 off
I don't get it :/ but I fear this is out of scope of the Advanced forum ... I mean, doesn't "alias net-pf-10 off" already mean to disable ipv6? What would "alias ipv6 off" add, or how does it differ from "blacklist ipv6"?
For me personally, this is all academic as usually the first thing I do is ENable ipv6 :) but I do wish to understand the changes. Thanks for your patience.
ShiftPlusOne
Tue May 31, 2016 6:56 pm
blacklist ipv6
alias net-pf-10 off
#alias ipv6 off
I believe it is baggage from the wheezy days. From what I gather, it used to disable ipv6 on wheezy, but doesn't do anything on jessie. I am reluctant to touch it until that's confirmed and I understand what it's meant to do and why it doesn't.
Tue May 31, 2016 7:14 pm
Good, great choice of default action for those of us who want to embrace the twenty year old improvements to IP networks that should have been rolled out Worldwide at least ten years ago. IPv4 needs to die.
bstrobl
Tue May 31, 2016 7:30 pm
DougieLawson wrote: Good, great choice of default action for those of us who want to embrace the twenty year old improvements to IP networks that should have been rolled out Worldwide at least ten years ago. IPv4 needs to die.
Going to have to agree here, the default should be enabled unless explicitly disabled. IPv4 is heavily broken at this stage with all the CGNAT and lack of addresses complicating things.
It's important to have and document a clean way of disabling it though for those who really don't want it.
algorithm
Tue May 31, 2016 10:08 pm
I'm not disagreeing! Just wondering, if not in /etc/modules, where it IS enabled. And what the "official" way to disable it is (probably what Dom wrote, except then what are those other directives in that file..)
Massi
Wed Jun 01, 2016 10:03 am
DougieLawson wrote:Good, great choice of default action for those of us who want to embrace the twenty year old improvements to IP networks that should have been rolled out Worldwide at least ten years ago. IPv4 needs to die.
:lol:
i NEED the possibility of putting a like to Dougie's posts
Aydan
Sun Jun 12, 2016 5:13 pm
OffTopic, but for clarification:
Regards
Aydan
Short story: Pi3 can boot from iSCSI with stock kernel (tried with 4.1.19 & 4.4.9) by using initramfs-tools
Long story here
asandford
Sun Jun 12, 2016 5:45 pm
Aydan wrote: Short story: Pi3 can boot from iSCSI with stock kernel (tried with 4.1.19 & 4.4.9) by using initramfs-tools
Long story here
Interesting, thanks. FWIW, here is the way that I and another forum member hacked a solution.
Will be great once the pxe boot gets sorted out (heard in the Pi Podcast (~24:50 - 26:35, but the whole thing is worth a listen) that it should be just around the corner).
tony power
Wed Jul 06, 2016 4:47 am
my rpi 3.
raspistill stopped working after kernel upgrade
but raspivid still works
sudo rpi-update
reboot
here is error message.
raspistill: error while loading shared libraries: libbrcmGLESv2.so: cannot open shared object file: No such file or directory
I want to fix this issue please.
Return to “Advanced users”
