RonR
Re: Linux kernel is now 4.4
Wed Apr 13, 2016 12:08 am
dom wrote:
RonR wrote:Anyone know why the bcm2708_rng module is not included in the new 4.4 kernel?
We use the upstream driver and it's built in, so loading the modules isn't required (/dev/hwrng exists by default):
CONFIG_HW_RANDOM_BCM2835=y
Thanks dom.
Does this mean that all we need to do is install rng-tools (apt-get -y install rng-tools) in order to be able to be able to regenerate SSH keys?:
rm /etc/ssh/ssh_host_*
dpkg-reconfigure openssh-server
service ssh restart
MaxK1
Wed Apr 13, 2016 10:05 am
Dom - I'm running overclocked at 1350 and force_turbo and it still runs a good couple of degrees cooler. Nice! I probably still need to tweak some things though.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
lb
Wed Apr 13, 2016 8:57 pm
dom wrote:
lbog wrote: Because in the kernel 4.4, those modules (ipv6, sit) are built-in:
That wasn't intentional. I've pushed an update where IPV6 is a module again.
@MrEngman does that make a difference to the behaviour you see?
And I thought you'd finally do the sane thing and bake IPv6 support directly into the kernel. :(
The original reason for making it a module ("bloat" or lack of memory on Pi 1) certainly doesn't exist at least on Pi 2/3. The 'sit' device probably is better off as a module, though.
If you need it (but I wonder why), the proper way to disable IPv6 is to pass "ipv6.disable=1" to the kernel on the kernel commandline. That will disable all IPv6 functionality even with IPv6 built in.
rapularaimo
Sun Apr 17, 2016 1:56 pm
Hi, I get dead Raspberry B (Raspbian Jessie) after 4.1 -> 4.4 update.
Only one red led lights and nice rainbow colors in screen, no any boot messages at all.
Luckilly I have fresh backup image of SD-card, so no any harm to get it back to work with old and good 4.1.
Can't debug more cause of it won't boot at all.
dom
Sun Apr 17, 2016 3:04 pm
rapularaimo wrote:Hi, I get dead Raspberry B (Raspbian Jessie) after 4.1 -> 4.4 update.
Can you post your config.txt? Settings like "dtoverlay=" will stop 4.4 kernel from booting (which only supports device tree).
rapularaimo
Sun Apr 17, 2016 3:19 pm
Here it is (/boot/config.txt)
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
gpu_mem=16
dtparam=spi=off
device_tree=
dom
Sun Apr 17, 2016 3:21 pm
rapularaimo wrote:Here it is (/boot/config.txt)
device_tree=
So remove that line and try again. You can't disable device tree with the 4.4 kernel.
rapularaimo
Sun Apr 17, 2016 3:37 pm
device_tree=
Yes it helps, clean boot. Thanks dom!
edit: but no sound = going back to 4.1
Seems like this update is too huge to handle for nomal user, but thanks anyway. ;)
tpfkanep
Sun Apr 17, 2016 4:56 pm
For the sound issue, try adding dtparam=audio=on to your config.txt. Ref
DirkS
Sun Apr 17, 2016 5:20 pm
tpfkanep wrote:For the sound issue, try adding dtparam=audio=on to your config.txt. Ref
It's also on the first page of this topic viewtopic.php?f=29&t=144087#p951316
rapularaimo
Sun Apr 17, 2016 7:10 pm
Thank You, now I have the sound.
edu2016
Mon Apr 18, 2016 2:07 pm
Hi all.
I have just upgraded the kernel on 2 Pi's, 2 B and 3 B using rpi-update.
After update I have sound but moc (music on console player) wasn't able to pause and go.
Shutdown the system in red display this:
[FAILED] Failed to start Store Sound Card State.
See 'systemctl status alsa-restore.service' for details
Run systemctl -l status alsa-store.service
and sudo journalctl -xn
● alsa-store.service - Store Sound Card State
Loaded: loaded (/lib/systemd/system/alsa-store.service; static)
Active: failed (Result: exit-code) since lun 2016-04-18 11:43:48 CEST; 15min ago
Process: 2898 ExecStart=/usr/sbin/alsactl -E HOME=/var/run/alsa store (code=exited, status=19)
Main PID: 2898 (code=exited, status=19)
Any solution? What will I do?
orxa
Tue Apr 19, 2016 7:30 am
PhilE wrote:
atkjoin wrote:Alsamixer stops working after upgrading.
Do you have "dtparam=audio=on" in your config.txt? The board support code in the 4.4 kernel is minimal, so we have to rely on Device Tree much more.
Thanks * 1000
dom
Tue Apr 19, 2016 6:30 pm
edu2016 wrote:[FAILED] Failed to start Store Sound Card State.
Can you rpi-update and test again? We've added a commit that fixes "alsactl store" for me.
edu2016
Tue Apr 19, 2016 11:44 pm
To Dom
Thanks a lot.
I update rpi and the [FAILED] goes away.
...but
if I play music on ncurses mp3 player moc (music on console) (mocp command)
when I pause the music, moc freeze.
I have to run taskmanager to kill the process mocp. And begin again.
When I reboot, the console stops 30s on
[...] stopped dhcpcd on all interfaces
and then reboots.
Other ncurses player as CMus or mp3blaster haven't this problem.
only moc aggg!!!
Thanks for your support.
fsr
Thu Apr 21, 2016 5:49 am
dom wrote:The newer kernel tree does support more devices (e.g. USB devices like wifi and dvb)
Just wanted to mention that the 4.4 kernel also supports the broadcom auxiliary SPI hardware too. SPI1 is available to 40pin header rPis on GPIO 16-21 and SPI2 is available to the compute module on GPIO 40-45.
Also unlike SPI0 the amount and GPIO # of the CS lines are configurable. Check the /boot/overlays/README for details.
/boot/config.txt
#enable spi0
dtparam=spi=on
#enable spi1 - all three cs lines
dtoverlay=spi1-3cs
[email protected]:~ $ ls -l /dev/spi*
crw-rw---- 1 root spi 153, 0 Apr 21 05:34 /dev/spidev0.0
crw-rw---- 1 root spi 153, 1 Apr 21 05:34 /dev/spidev0.1
crw-rw---- 1 root spi 153, 4 Apr 21 05:34 /dev/spidev1.0
crw-rw---- 1 root spi 153, 3 Apr 21 05:34 /dev/spidev1.1
crw-rw---- 1 root spi 153, 2 Apr 21 05:34 /dev/spidev1.2
driff
Sun Apr 24, 2016 12:59 am
After successfully updating to 4.4.8 on a raspberry pi 2 running Raspbian Jessie (latest release), I had issues that escalated quickly:
LXpanel was crash-looping in xterm and wifi dungle (set as a host) was not broadcasting (ifconfig was still showing it though).
After that I rebooted in terminal mode (by changing raspi-config), ssh was down but was able to restart it.
After that whole OS failed to boot properly stopping at nonblocking pool is initialized..
I can still boot but not much is working, I have no host name, it display (none) and I can't run ifconfig (gives an error).
emilfr
Fri Apr 29, 2016 2:45 pm
I just update to 4.4 using rpi-update, and after reboot, my raspberry 2 B+ stuck on boot:
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.8-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #880 SMP Fri Apr 22 21:55:04 BST 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 13 pages/cpu @b9f64000 s22592 r8192 d22464 u53248
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa21041 bcm2709.serial=0x7b462691 smsc95xx.macaddr=B8:27:EB:46:26:91 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939100K/966656K available (6336K kernel code, 432K rwdata, 1712K rodata, 476K init, 764K bss, 19364K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
[    0.000000]     lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
[    0.000000]     modules : 0x7f000000 - 0x80000000   (  16 MB)
[    0.000000]       .text : 0x80008000 - 0x807e4308   (8049 kB)
[    0.000000]       .init : 0x807e5000 - 0x8085c000   ( 476 kB)
[    0.000000]       .data : 0x8085c000 - 0x808c8088   ( 433 kB)
[    0.000000]        .bss : 0x808cb000 - 0x8098a1ac   ( 765 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000032] Switching to timer-based delay loop, resolution 52ns
[    0.000350] Console: colour dummy device 80x30
[    0.001529] console [tty1] enabled
[    0.001581] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001660] pid_max: default: 32768 minimum: 301
[    0.002077] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002129] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003368] Disabling cpuset control group subsystem
[    0.003454] Initializing cgroup subsys io
[    0.003516] Initializing cgroup subsys memory
[    0.003596] Initializing cgroup subsys devices
[    0.003648] Initializing cgroup subsys freezer
[    0.003702] Initializing cgroup subsys net_cls
[    0.003803] CPU: Testing write buffer coherency: ok
[    0.003918] ftrace: allocating 21191 entries in 63 pages
[    0.056189] CPU0: update cpu_capacity 1024
[    0.056269] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.056308] [bcm2709_smp_prepare_cpus] enter
[    0.056462] Setting up static identity map for 0x8240 - 0x8274
[    0.058879] [bcm2709_boot_secondary] cpu:1 started (0) 17
[    0.059310] [bcm2709_secondary_init] enter cpu:1
[    0.059368] CPU1: update cpu_capacity 1024
[    0.059376] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.059957] [bcm2709_boot_secondary] cpu:2 started (0) 16
[    0.060308] [bcm2709_secondary_init] enter cpu:2
[    0.060337] CPU2: update cpu_capacity 1024
[    0.060345] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.060896] [bcm2709_boot_secondary] cpu:3 started (0) 16
[    0.061151] [bcm2709_secondary_init] enter cpu:3
[    0.061182] CPU3: update cpu_capacity 1024
[    0.061190] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.061277] Brought up 4 CPUs
[    0.061389] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.061423] CPU: All CPU(s) started in HYP mode.
[    0.061452] CPU: Virtualization extensions available.
[    0.062388] devtmpfs: initialized
[    0.074354] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.074864] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.075920] pinctrl core: initialized pinctrl subsystem
[    0.076725] NET: Registered protocol family 16
[    0.082542] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.090689] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.090751] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.090980] Serial: AMBA PL011 UART driver
[    0.091327] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    0.594039] console [ttyAMA0] enabled
[    0.598345] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.675854] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[    0.685921] SCSI subsystem initialized
[    0.689917] usbcore: registered new interface driver usbfs
[    0.695561] usbcore: registered new interface driver hub
[    0.701033] usbcore: registered new device driver usb
[    0.716197] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-04-27 11:06
[    0.751957] clocksource: Switched to clocksource arch_sys_counter
[    0.811295] FS-Cache: Loaded
[    0.814683] CacheFiles: Loaded
[    0.834295] NET: Registered protocol family 2
[    0.839925] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.847191] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.853860] TCP: Hash tables configured (established 8192 bind 8192)
[    0.860384] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.866407] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.873137] NET: Registered protocol family 1
[    0.877986] RPC: Registered named UNIX socket transport module.
[    0.883977] RPC: Registered udp transport module.
[    0.888697] RPC: Registered tcp transport module.
[    0.893435] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.901289] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.911300] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.933336] VFS: Disk quotas dquot_6.6.0
[    0.937653] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.947599] FS-Cache: Netfs 'nfs' registered for caching
[    0.954111] NFS: Registering the id_resolver key type
[    0.959236] Key type id_resolver registered
[    0.963471] Key type id_legacy registered
[    0.970549] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.978267] io scheduler noop registered
[    0.982260] io scheduler deadline registered (default)
[    0.987479] io scheduler cfq registered
[    0.994295] BCM2708FB: allocated DMA memory fac00000
[    0.999314] BCM2708FB: allocated DMA channel 0 @ f3007000
[    1.010627] Console: switching to colour frame buffer device 82x26
[    1.939014] bcm2835-rng 3f104000.rng: hwrng registered
[    1.946000] vc-cma: Videocore CMA driver
[    1.951575] vc-cma: vc_cma_base      = 0x00000000
[    1.957943] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.964940] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.972171] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    2.003646] brd: module loaded
[    2.019369] loop: module loaded
[    2.025131] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[    2.035275] Loading iSCSI transport class v2.0-870.
[    2.042623] usbcore: registered new interface driver smsc95xx
[    2.049961] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.257642] Core Release: 2.80a
[    2.262270] Setting default values for core params
[    2.268545] Finished setting default values for core params
[    2.476041] Using Buffer DMA mode
[    2.480835] Periodic Transfer Interrupt Enhancement - disabled
[    2.488212] Multiprocessor Interrupt Enhancement - disabled
[    2.495363] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.501249] Dedicated Tx FIFOs mode
[    2.506639] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[    2.519658] FIQ FSM acceleration enabled for :
[    2.519658] Non-periodic Split Transactions
[    2.519658] Periodic Split Transactions
[    2.519658] High-Speed Isochronous Endpoints
[    2.519658] Interrupt/Control Split Transaction hack enabled
[    2.550083] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x804455cc
[    2.557644] WARN::hcd_init_fiq:414: FIQ ASM at 0x8044593c length 36
[    2.565506] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb87e000
[    2.573133] dwc_otg 3f980000.usb: DWC OTG Controller
[    2.579680] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    2.588632] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    2.595816] Init: Port Power? op_state=1
[    2.601265] Init: Power Port (0)
[    2.606275] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.614657] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.623452] usb usb1: Product: DWC OTG Controller
[    2.629679] usb usb1: Manufacturer: Linux 4.4.8-v7+ dwc_otg_hcd
[    2.637149] usb usb1: SerialNumber: 3f980000.usb
[    2.644338] hub 1-0:1.0: USB hub found
[    2.649613] hub 1-0:1.0: 1 port detected
[    2.656139] usbcore: registered new interface driver usb-storage
[    2.663987] mousedev: PS/2 mouse device common for all mice
[    2.671903] bcm2835-cpufreq: min=600000 max=900000
[    2.678557] sdhci: Secure Digital Host Controller Interface driver
[    2.686293] sdhci: Copyright(c) Pierre Ossman
[    2.692552] sdhost: log_buf @ bac13000 (fac13000)
[    2.772001] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    2.779312] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.787269] ledtrig-cpu: registered to indicate activity on CPUs
[    2.795065] hidraw: raw HID events driver (C) Jiri Kosina
[    2.802296] usbcore: registered new interface driver usbhid
[    2.809420] usbhid: USB HID core driver
[    2.815477] Initializing XFRM netlink socket
[    2.821335] NET: Registered protocol family 17
[    2.827485] Key type dns_resolver registered
[    2.833856] Registering SWP/SWPB emulation handler
[    2.841320] registered taskstats version 1
[    2.847183] vc-sm: Videocore shared memory driver
[    2.853551] Indeed it is in host mode hprt0 = 00021501
[    2.862058] [vc_sm_connected_init]: start
[    2.870013] [vc_sm_connected_init]: end - returning 0
[    2.877107] of_cfs_init
[    2.881139] of_cfs_init: OK
[    2.886572] Waiting for root device /dev/mmcblk0p2...
[    2.893252] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.907142] mmc0: new high speed SDHC card at address aaaa
[    2.915137] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    2.922771]  mmcblk0: p1 p2
[    3.007285] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    3.016179] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    3.032002] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    3.040153] Indeed it is in host mode hprt0 = 00001101
[    3.191706] EXT4-fs (mmcblk0p2): recovery complete
[    3.206886] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.218252] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.235173] devtmpfs: mounted
[    3.240672] Freeing unused kernel memory: 476K (807e5000 - 8085c000)
[    3.249167] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    3.257687] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.267638] hub 1-1:1.0: USB hub found
[    3.273330] hub 1-1:1.0: 5 ports detected
[    3.528645] random: systemd urandom read with 58 bits of entropy available
[    3.542909] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    3.552032] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.569069] systemd[1]: Detected architecture 'arm'.
[    3.652566] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.661378] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.667557] NET: Registered protocol family 10
[    3.673088] systemd[1]: Inserted module 'ipv6'
[    3.676807] systemd[1]: Set hostname to <keitaro-raspi2>.
[    3.693735] smsc95xx v1.0.4
[    3.757896] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:46:26:91
[    3.780193] uart-pl011 3f201000.uart: no DMA platform data
[    4.218115] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    4.243518] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.255701] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.267336] systemd[1]: Expecting device dev-ttyAMA0.device...
[    4.277899] systemd[1]: Starting Remote File Systems (Pre).
[    4.288086] systemd[1]: Reached target Remote File Systems (Pre).
[    4.296425] systemd[1]: Starting Encrypted Volumes.
[    4.305835] systemd[1]: Reached target Encrypted Volumes.
[    4.313516] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.329601] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.343424] systemd[1]: Starting Swap.
[    4.351704] systemd[1]: Reached target Swap.
[    4.358126] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    4.368461] systemd[1]: Expecting device dev-sda1.device...
[    4.378206] systemd[1]: Starting Root Slice.
[    4.386681] systemd[1]: Created slice Root Slice.
[    4.393337] systemd[1]: Starting User and Session Slice.
[    4.402975] systemd[1]: Created slice User and Session Slice.
[    4.410588] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    4.421538] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.430515] systemd[1]: Starting Delayed Shutdown Socket.
[    4.440113] systemd[1]: Listening on Delayed Shutdown Socket.
[    4.447763] systemd[1]: Starting Journal Socket (/dev/log).
[    4.457409] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.465305] systemd[1]: Starting udev Control Socket.
[    4.474497] systemd[1]: Listening on udev Control Socket.
[    4.481745] systemd[1]: Starting udev Kernel Socket.
[    4.490741] systemd[1]: Listening on udev Kernel Socket.
[    4.497985] systemd[1]: Starting Journal Socket.
[    4.506762] systemd[1]: Listening on Journal Socket.
[    4.513711] systemd[1]: Starting System Slice.
[    4.522356] systemd[1]: Created slice System Slice.
[    4.529101] systemd[1]: Starting File System Check on Root Device...
[    4.572865] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    4.583788] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    4.592085] systemd[1]: Starting system-getty.slice.
[    4.601879] systemd[1]: Created slice system-getty.slice.
[    4.609379] systemd[1]: Starting system-serial\x2dgetty.slice.
[    4.619763] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.628269] systemd[1]: Starting Increase datagram queue length...
[    4.642670] systemd[1]: Starting Restore / save the current clock...
[    4.662383] systemd[1]: Mounting POSIX Message Queue File System...
[    4.677227] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    4.710068] systemd[1]: Started Set Up Additional Binary Formats.
[    4.719311] systemd[1]: Mounted Huge Pages File System.
[    4.727303] systemd[1]: Starting udev Coldplug all Devices...
[    4.767110] systemd[1]: Starting Load Kernel Modules...
[    4.782490] systemd[1]: Mounting Debug File System...
[    4.796572] systemd[1]: Starting Slices.
[    4.812419] systemd[1]: Reached target Slices.
[    4.827703] systemd[1]: Mounted Debug File System.
[    4.837878] systemd[1]: Mounted POSIX Message Queue File System.
[    4.853726] systemd[1]: Started Increase datagram queue length.
[    4.867145] fuse init (API version 7.23)
[    4.875310] systemd[1]: Started Restore / save the current clock.
[    4.887956] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    4.905593] systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE
[    4.925772] systemd[1]: Failed to start Load Kernel Modules.
[    4.934657] systemd[1]: Unit systemd-modules-load.service entered failed state.
[    4.948616] systemd[1]: Started File System Check on Root Device.
[    4.978725] systemd[1]: Started udev Coldplug all Devices.
[    4.989024] systemd[1]: Time has been changed
[    5.182085] systemd[1]: Mounting FUSE Control File System...
[    5.232538] systemd[1]: Starting Apply Kernel Variables...
[    5.247653] systemd[1]: Mounting Configuration File System...
[    5.262986] systemd[1]: Starting Create Static Device Nodes in /dev...
is this related with device_tree?
RPI Zero W || RPI 2B || 2x RPI 3B || 2x RPI 4B4G
DirkS
Fri Apr 29, 2016 3:08 pm
emilfr wrote:is this related with device_tree?
Deactivating device tree is not an option with this kernel.
You will have to activate it to use the RPF kernel / firmware v4.4+
PhilE
Fri Apr 29, 2016 3:21 pm
From that log you can tell that Device Tree is enabled (Machine model is a nice string for starters) - I'd say you're probably long past the point where DT would be the likely culprit.
These lines are suspicious:
So it looks like your filing system started out in need of a repair, was mounted read-only, then subsequently remounted read-only even though the message said it should be writeable.
What happened to your card? Did rpi-update appear to complete without errors? Do you reboot cleanly or just power off?
emilfr
Fri Apr 29, 2016 4:23 pm
it was a clean update and clean reboot
sudo rpi-update
 *** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
 *** Performing self-update
 *** Relaunching after update
WARNING: This update bumps to rpi-4.4.y linux tree
Be aware there could be compatibility issues with some drivers
Discussion here:
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=144087
Would you like to proceed? (y/N)
 *** Downloading specific firmware revision (this will take a few minutes)
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100   168    0   168    0     0    365      0 --:--:-- --:--:-- --:--:--   366
  4 50.4M    4 2453k    0     0  1499k      0  0:00:34  0:00:01  0:00:33 2615k
 16 50.4M   16 8540k    0     0  3241k      0  0:00:15  0:00:02  0:00:13 4409k
 27 50.4M   27 13.9M    0     0  3920k      0  0:00:13  0:00:03  0:00:10 4851k
 35 50.4M   35 17.6M    0     0  3692k      0  0:00:13  0:00:04  0:00:09 4307k
 43 50.4M   43 22.1M    0     0  4027k      0  0:00:12  0:00:05  0:00:07 4596k
 54 50.4M   54 27.7M    0     0  4282k      0  0:00:12  0:00:06  0:00:06 5192k
 65 50.4M   65 32.8M    0     0  4412k      0  0:00:11  0:00:07  0:00:04 5029k
 74 50.4M   74 37.4M    0     0  4445k      0  0:00:11  0:00:08  0:00:03 4827k
 74 50.4M   74 37.8M    0     0  2645k      0  0:00:19  0:00:14  0:00:05 2119k
 85 50.4M   85 43.2M    0     0  2832k      0  0:00:18  0:00:15  0:00:03 2158k
 96 50.4M   96 48.6M    0     0  2997k      0  0:00:17  0:00:16  0:00:01 2144k
 96 50.4M   96 48.7M    0     0  2697k      0  0:00:19  0:00:18  0:00:01 1493k
 96 50.4M   96 48.8M    0     0  2045k      0  0:00:25  0:00:24  0:00:01  733k
 98 50.4M   98 49.6M    0     0  2062k      0  0:00:25  0:00:24  0:00:01 1205k
100 50.4M  100 50.4M    0     0  2083k      0  0:00:24  0:00:24 --:--:--  807k
 *** Updating firmware
 *** Updating kernel modules
 *** depmod 4.4.8+
 *** depmod 4.4.8-v7+
 *** Updating VideoCore libraries
 *** Using HardFP libraries
 *** Updating SDK
 *** Running ldconfig
 *** Storing current firmware revision
 *** Deleting downloaded files
 *** Syncing changes to disk
 *** If no errors appeared, your firmware was successfully updated to 384626a4e08d49262fd0ebb799b82f330ca7a0df
 *** A reboot is needed to activate the new firmware
raspi2~ $ sudo reboot
dukla2000
Mon May 02, 2016 12:58 am
Did an rpi-update 2 days ago. No problems with the update, no problems with 4.4.
Thank you
ps
[email protected]:~ $ uname -a
Linux dukla 4.4.8-v7+ #880 SMP Fri Apr 22 21:55:04 BST 2016 armv7l GNU/Linux
Daily driver: Pi3B, 64GB Samsung Evo+ @100MHz, DVB-T, onboard WiFi for internet, BT/USB dongle for KB/mouse, 250GB HDD via USB for media, Raspbian Jessie Lite with Openbox desktop.
Museum: Pi B
MaxK1
Wed May 04, 2016 6:28 am
dukla2000 - what is the longest uptime you have had with it? Reason I'm asking is I think there is a problem with the Broadcom wi-fi driver that eats ram at an alarming rate and I can't reproduce the problem with an external (ralink chipset) wi-fi dongle. The result of leaving it running, without X nothing else up except a couple of active VT's was every time I walked by it and checked another BIG chunk of ram was "missing" ie no process was "claiming" it, (ps alx) but free was showing less and less free memory that wasn't accounted for by cache or buffers. Pfhht - just gone. It takes a little over 12-16 hours to exhaust all of ram before the dreaded OOM-killer strikes and then all kinds of bad things can happen. Has anyone else seen this with 4.4.8-v7+ #880 SMP Fri Apr 22 21:55:04 BST 2016 armv7l GNU/Linux?
dukla2000
Thu May 05, 2016 1:28 am
MaxK1 wrote:dukla2000 - what is the longest uptime you have had with it?
Currently been running 40 hours, in theory it runs 24/7 but one way and another have had reboots every couple of days while getting things the way I like (hard and software). Last reboot was sorting a UK to US keyboard did think about just restarting X but didn't.
I run X fulltime, have never noticed any memory problems (except midori after lots of pages open with pictures triggered swap once) and do have gkrellm monitor all the time. Not sure what I should look for on ps alx but pretty sure I don't have your symptoms.
ps now 46 hours since last reboot, gkrellm showing 781M free, FWIW my ps alx output
[email protected]:~ $ ps alx
F   UID   PID  PPID PRI  NI    VSZ   RSS WCHAN  STAT TTY        TIME COMMAND
4     0     1     0  20   0  22852  4052 -      Ss   ?          0:08 /sbin/init
1     0     2     0  20   0      0     0 -      S    ?          0:00 [kthreadd]
1     0     3     2  20   0      0     0 -      S    ?          0:01 [ksoftirqd/0]
1     0     5     2   0 -20      0     0 -      S<   ?          0:00 [kworker/0:0H]
1     0     7     2  20   0      0     0 -      S    ?          2:53 [rcu_sched]
1     0     8     2  20   0      0     0 -      S    ?          0:00 [rcu_bh]
1     0     9     2 -100  -      0     0 -      S    ?          0:00 [migration/0]
1     0    10     2 -100  -      0     0 -      S    ?          0:00 [migration/1]
1     0    11     2  20   0      0     0 -      S    ?          0:03 [ksoftirqd/1]
1     0    13     2   0 -20      0     0 -      S<   ?          0:00 [kworker/1:0H]
1     0    14     2 -100  -      0     0 -      S    ?          0:00 [migration/2]
1     0    15     2  20   0      0     0 -      S    ?          0:01 [ksoftirqd/2]
1     0    17     2   0 -20      0     0 -      S<   ?          0:00 [kworker/2:0H]
1     0    18     2 -100  -      0     0 -      S    ?          0:00 [migration/3]
1     0    19     2  20   0      0     0 -      S    ?          0:00 [ksoftirqd/3]
1     0    21     2   0 -20      0     0 -      S<   ?          0:00 [kworker/3:0H]
5     0    22     2  20   0      0     0 -      S    ?          0:00 [kdevtmpfs]
1     0    23     2   0 -20      0     0 -      S<   ?          0:00 [netns]
1     0    24     2   0 -20      0     0 -      S<   ?          0:00 [perf]
1     0    25     2  20   0      0     0 -      S    ?          0:00 [khungtaskd]
1     0    26     2   0 -20      0     0 -      S<   ?          0:00 [writeback]
1     0    27     2   0 -20      0     0 -      S<   ?          0:00 [crypto]
1     0    28     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    29     2   0 -20      0     0 -      S<   ?          0:00 [kblockd]
1     0    31     2   0 -20      0     0 -      S<   ?          0:00 [rpciod]
1     0    32     2  20   0      0     0 -      S    ?          0:00 [kswapd0]
1     0    33     2   0 -20      0     0 -      S<   ?          0:00 [vmstat]
1     0    34     2  20   0      0     0 -      S    ?          0:00 [fsnotify_mark]
1     0    35     2   0 -20      0     0 -      S<   ?          0:00 [nfsiod]
1     0    44     2   0 -20      0     0 -      S<   ?          0:00 [kthrotld]
1     0    47     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    48     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    49     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    50     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    51     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    52     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    53     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    54     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    55     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    56     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    57     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    58     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    59     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    60     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    61     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    62     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    63     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    64     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    65     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    66     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    67     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    68     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    69     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    70     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    71     2   1 -19      0     0 -      S<   ?          0:08 [VCHIQ-0]
1     0    72     2   1 -19      0     0 -      S<   ?          0:00 [VCHIQr-0]
1     0    73     2   0 -20      0     0 -      S<   ?          0:00 [VCHIQs-0]
1     0    74     2   0 -20      0     0 -      S<   ?          0:00 [iscsi_eh]
1     0    75     2   0 -20      0     0 -      S<   ?          0:00 [dwc_otg]
1     0    76     2   0 -20      0     0 -      S<   ?          0:00 [DWC Notificatio]
1     0    78     2 -51   -      0     0 -      S    ?          0:07 [irq/92-mmc1]
1     0    79     2  20   0      0     0 -      S    ?          0:00 [VCHIQka-0]
1     0    80     2  10 -10      0     0 -      S<   ?          0:00 [SMIO]
1     0    81     2   0 -20      0     0 -      S<   ?          0:00 [deferwq]
1     0    83     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
1     0    84     2  20   0      0     0 -      S    ?          0:02 [mmcqd/0]
1     0    87     2  20   0      0     0 -      S    ?          0:00 [jbd2/mmcblk0p2-]
1     0    88     2   0 -20      0     0 -      S<   ?          0:00 [ext4-rsv-conver]
1     0    89     2   0 -20      0     0 -      S<   ?          0:00 [ipv6_addrconf]
1     0   103     2   0 -20      0     0 -      S<   ?          0:00 [kworker/1:1H]
4     0   135     1  20   0   9944  3292 -      Ss   ?          0:02 /lib/systemd/systemd-journald
4     0   137     1  20   0  11912  2904 -      Ss   ?          0:00 /lib/systemd/systemd-udevd
1     0   212     2   0 -20      0     0 -      S<   ?          0:00 [cfg80211]
1     0   215     2   0 -20      0     0 -      S<   ?          0:00 [brcmf_wq/mmc1:0]
1     0   216     2  20   0      0     0 -      S    ?          0:02 [brcmf_wdog/mmc1]
1     0   219     2   0 -20      0     0 -      S<   ?          0:28 [kworker/u9:0]
1     0   220     2   0 -20      0     0 -      S<   ?          0:00 [hci0]
1     0   221     2   0 -20      0     0 -      S<   ?          0:00 [hci0]
1     0   225     2   0 -20      0     0 -      S<   ?          0:06 [kworker/u9:2]
1     0   255     2  20   0      0     0 -      S    ?          0:00 [scsi_eh_0]
1     0   256     2   0 -20      0     0 -      S<   ?          0:00 [scsi_tmf_0]
1     0   257     2  20   0      0     0 -      S    ?          0:00 [usb-storage]
1     0   309     2  20   0      0     0 -      S    ?          0:00 [kworker/1:1]
1     0   346     2   0 -20      0     0 -      S<   ?          0:00 [bioset]
5     0   423     1  20   0   7148  3868 -      Ss   ?          0:02 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D n
1     0   451     2   0 -20      0     0 -      S<   ?          0:00 [kworker/0:1H]
4     0   479     1  20   0  41220  6956 -      Ssl  ?          0:00 /usr/sbin/ModemManager
4     0   480     1  20   0   5072  2056 -      Ss   ?          0:00 /usr/sbin/cron -f
4     0   482     1  20   0   3852  2452 -      Ss   ?          0:00 /lib/systemd/systemd-logind
4   105   486     1  20   0   3876  2596 -      Ss   ?          0:00 avahi-daemon: running [dukla.local]
4   104   489     1  20   0   5692  3164 -      Ss   ?          0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --s
5 65534   502     1  20   0   2292  1468 -      Ss   ?          0:32 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket
1   105   506   486  20   0   3876   240 -      S    ?          0:00 avahi-daemon: chroot helper
4     0   565     1  20   0  32144  2984 -      Ssl  ?          0:00 /usr/sbin/rsyslogd -n
4     0   580     1  20   0  36492  5740 -      Ssl  ?          0:00 /usr/lib/policykit-1/polkitd --no-debug
4     0   602     1  20   0  35932  5500 -      SLsl ?          0:00 /usr/sbin/lightdm
4     0   648   602  20   0 153100 49896 -      Ssl+ tty7      41:45 /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt
4   112   665     1  20   0   4976  3400 -      Ss   ?          0:00 /lib/systemd/systemd --user
5   112   668   665  20   0   6912  1252 -      S    ?          0:00 (sd-pam)
1   112   676     1  20   0   3692  1620 -      S    ?          0:00 /usr/bin/dbus-launch --autolaunch 2c9b9d45656b45afb58b1f0a4682f91a --bina
1   112   677     1  20   0   5492  1964 -      Ss   ?          0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
0   112   679     1  20   0  44456  4772 -      Sl   ?          0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
0   112   683   679  20   0   5492  2960 -      S    ?          0:03 /usr/bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofo
0   112   686     1  20   0  17616  5192 -      Sl   ?          0:12 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
1     0   722     2   0 -20      0     0 -      S<   ?          0:00 [kworker/2:1H]
5     0   771     1  20   0   2564  1904 -      Ss   ?          0:00 /sbin/dhcpcd -q -w
4     0   772     1  20   0   7860  4352 -      Ss   ?          0:00 /usr/sbin/sshd -D
4     0   788     1  20   0   4052  1588 -      Ss+  tty1       0:00 /sbin/agetty --noclear tty1 linux
4     0   789     1  20   0   3872  1528 -      Ss+  ?          0:00 /sbin/agetty --keep-baud 115200 38400 9600 ttyAMA0 vt102
5   106   790     1  20   0   5768  3856 -      Ss   ?          0:15 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:111
4     0   796     1  20   0   5008  3420 -      Ss   ?          0:00 /usr/lib/bluetooth/bluetoothd
4     0   825   602  20   0  28284  5796 -      Sl   ?          0:00 lightdm --session-child 13 22
4  1000   836     1  20   0   4976  3432 SyS_ep Ss   ?          0:00 /lib/systemd/systemd --user
5  1000   840   836  20   0   6904  1344 -      S    ?          0:00 (sd-pam)
4  1000   847   825  20   0  37544 17748 poll_s Ssl  ?          0:33 /usr/bin/openbox --startup /usr/lib/arm-linux-gnueabihf/openbox-autostart
1  1000   867   847  20   0   3696   220 -      Ss   ?          0:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session /usr/bin/open
1  1000   870     1  20   0   3692  1484 poll_s S    ?          0:00 /usr/bin/dbus-launch --exit-with-session /usr/bin/openbox-session
1  1000   871     1  20   0   5596  2240 SyS_ep Ss   ?          0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
0  1000   876     1  20   0  30852  5216 poll_s Sl   ?          0:00 /usr/lib/gvfs/gvfsd
0  1000   880     1  20   0  46224  4452 futex_ Sl   ?          0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
0  1000   894     1  20   0  45156 16860 poll_s S    ?         76:31 gkrellm
0  1000   902     1  20   0  49820 21124 poll_s Sl   ?          0:01 /usr/lib/notification-daemon/notification-daemon
0  1000   904     1  20   0  44460  4712 poll_s Sl   ?          0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
0  1000   908   904  20   0   5492  3008 SyS_ep S    ?          0:03 /usr/bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofo
0  1000   911     1  20   0  17616  5460 poll_s Sl   ?          0:12 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
0  1000   927   847  20   0  45976 17700 poll_s Sl   ?          0:05 lxterminal
0  1000   928   927  20   0   2348  1524 -      S    ?          0:00 gnome-pty-helper
0  1000   929   927  20   0   6008  3652 wait   Ss   pts/0      0:00 /bin/bash
0  1000   984   847  20   0  90268 54808 poll_s Sl   ?          7:09 /usr/games/sol
0  1000   986     1  20   0   9292  4220 poll_s S    ?          0:00 /usr/lib/arm-linux-gnueabihf/gconf/gconfd-2
0  1000  1613     1  20   0  60276  7812 poll_s Sl   ?          0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
4     0  1615     1  20   0  54576  6596 -      Ssl  ?          0:00 /usr/lib/udisks2/udisksd --no-debug
0  1000  1626     1  20   0  29904  5016 poll_s Sl   ?          0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
0  1000  1630     1  20   0  42412  6176 poll_s Sl   ?          0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
0  1000  1635     1  20   0  29928  5032 poll_s Sl   ?          0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
0  1000  1639     1  20   0  30948  5364 poll_s Sl   ?          0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
1     0  1654     2   0 -20      0     0 -      S<   ?          0:00 [kworker/3:1H]
1     0  1666     2  20   0      0     0 -      S    ?          0:00 [jbd2/sda1-8]
1     0  1667     2   0 -20      0     0 -      S<   ?          0:00 [ext4-rsv-conver]
0  1000  1690     1  20   0  20768  4992 poll_s Sl   ?          0:01 /usr/lib/gvfs/gvfsd-metadata
1     0  3659     2  20   0      0     0 -      S    ?          0:00 [kworker/3:1]
1     0  3687     2  20   0      0     0 -      S    ?          0:00 [kworker/u8:1]
1     0  6420     2  20   0      0     0 -      S    ?          0:02 [kworker/0:0]
1     0  6773     2  20   0      0     0 -      S    ?          0:00 [kworker/u8:0]
1     0  7436     2  20   0      0     0 -      S    ?          0:00 [kworker/0:1]
1     0  7463     2   5 -15      0     0 -      S<   ?          0:00 [khidpd_099a0500]
1     0  7470     2  20   0      0     0 -      S    ?          0:00 [kworker/2:2]
1     0  7514     2  20   0      0     0 -      S    ?          0:00 [kworker/0:2]
1     0  7553     2  20   0      0     0 -      S    ?          0:00 [kworker/u8:2]
1     0  7598     2   5 -15      0     0 -      S<   ?          0:00 [khidpd_05ac022c]
1     0  7602     2  20   0      0     0 -      S    ?          0:00 [kworker/2:0]
0  1000  7604   929  20   0   4284  1720 -      R+   pts/0      0:00 ps alx
1  1000 30675     1  20   0   5492  2144 SyS_ep Ss   ?          0:00 dbus-daemon --fork --print-address 5 --print-pid 6 --session
0  1000 30792   847  20   0  75528 20052 poll_s Sl   ?          0:02 pcmanfm
1     0 31853     2  20   0      0     0 -      S    ?          0:06 [kworker/3:2]
1     0 32303     2  20   0      0     0 -      S    ?          0:03 [kworker/1:2]
1     0 32522     2  20   0      0     0 -      S    ?          0:09 [kworker/2:1]
Museum: Pi B
MaxK1
Thu May 05, 2016 10:20 am
Nothing abnormal looking there... I'll try testing it some more and see if it can be reproduced in a controlled environment (fresh jessie install etc.)
Return to “Advanced users”
