unkzo
Get the UART PL011 without PULL-UP on TX
Wed Mar 09, 2016 11:03 pm
If for some reason i want to use a external pull-up on TX and disable the internal pull-up for UART (PL011), there is a easy way after boot or i need to try use the Device Tree blob ? I know it's possible change de pull-up of RX after booting, but i can't do it on TX pin with ALT0 active even writing directly to registers.
lb
Re: Get the UART PL011 without PULL-UP on TX
Wed Mar 09, 2016 11:15 pm
The interal pull-up is quite weak. If you want to add a (stronger) external pull-up, you can probably ignore the internal one. It doesn't matter.
Return to “Advanced users”
