10robinho
RPI3: Wireless and Bluetooth antenna
Mon Feb 29, 2016 12:14 pm
We all saw new RPI3 announcement.
I was wondering if anyone knows if it will have an option for having external antenna?
I'm not an expert in this field but I know that RPI can't have metal case in case of antenna on board (if you want usable wireless).
It's a question for us who make industrial applications and have metal boxes.
chrisoh
Re: RPI3: Wireless and Bluetooth antenna
Mon Feb 29, 2016 12:24 pm
Any idea which pads?
Looking at this, I can't see the appropriate pads on the underside of the Pi 3?
Raspberry Pi 3 model B Idle @ 250mA
  • HDMI +200mA
  • Minecraft 1.9 Server +100mA
  • 2.4Ghz dongle +20mA
10robinho
Mon Feb 29, 2016 12:54 pm
chrisoh wrote:Any idea which pads?
I've found it on FCC photos. On bottom side besides GPIO 2 pin. Pads are on 45° angle (they were probably thigh with space).
Mon Feb 29, 2016 12:57 pm
Looking at my Pi3, there is a tiny pad underneath what I think is the aerial chip. Would be a bugger to solder to. There are some copper pads close by which would be easier.
chrisoh
Mon Feb 29, 2016 1:01 pm
Can you point them out, I don't see the (3?) accessible endpoints?
  • HDMI +200mA
10robinho
Mon Feb 29, 2016 1:41 pm
chrisoh wrote:Can you point them out, I don't see the (3?) accessible endpoints?
That is good place but photo is bad. It looks like missing upper pad. Just below GPIO 2.
If you look at last photo from FCC it's much more clear.
EDIT: I tried not to be lazy and show my GIMP skills :) Here it is:
chrisoh
Mon Feb 29, 2016 1:46 pm
Good catch! Looks like the first and last photos are different boards.
Certainly looks doable, hard part is finding a u.FL connector in my parts box :lol:
  • HDMI +200mA
10robinho
Mon Feb 29, 2016 1:58 pm
Now it would be super-cool if someone makes cheap sticker-like antenna.
Maybe it already exists, but I'm not informed.
mahjongg
Mon Feb 29, 2016 11:07 pm
the built in ceramic antenna will probably give better performance than most external antenna's you can connect, really the only reason I could imagine to add an external antenna is when you stick the PI into a metal box, but the FLIRC enclosure, the principal metal box made as a passive heatsink for the PI already has a plastic opening to let the WiFi signals through.
specs of the ceramic antenna can be found here: http://www.2j-antennae.com/images/products/2JE07d.pdf
chrisoh
Wed Mar 02, 2016 11:48 am
Not possible, only two pads are present on the production boards.
  • HDMI +200mA
lb
Wed Mar 02, 2016 12:04 pm
Uhm, just scrape away a bit of the soldermask? Looks like a PCB design error, but it's not a big deal.
chrisoh
Wed Mar 02, 2016 8:59 pm
lb wrote:Uhm, just scrape away a bit of the soldermask? Looks like a PCB design error, but it's not a big deal.
I'll let someone else try that first :D
  • HDMI +200mA
Wortelsoft
Fri Mar 04, 2016 2:15 pm
Would it be possible to have a plastic "window" in the case the same as mobile phone manufacturers do? E.g. like the back of the Nexus 6P.
mahjongg
Wed Nov 21, 2018 10:03 am
There is NO legal way to add an external antenna!
The FL connector footpad you see near the WiFi chip is incomplete on purpose, to prevent naive users to add their own FL connector for an external antenna.
It is only there to assist in testing with test equipment.
Using it for an antenna will break FCC (and other similar) regulations.
Also, you need to do more than just adding the FL connector, just adding it, and an antenna will NOT work, as it was never meant to be an antenna connector.
Return to “Advanced users”
