n8klayko
Issue with Python on Jessie
Wed Feb 17, 2016 2:43 pm
Good morning all. I am looking for some help figuring out what exactly is going on with an error I am receiving. I recently upgraded from a Pi B+ to a Pi 2 running on Debian Jessie. I am using my Pi as a web-based kiosk and web-based internet radio server. At startup, I am running the following script:
	#!/bin/sh
	# launcher.sh
	# navigate to home directory, then to this directory, then execute python script, then back home
	cd /
	cd /home/pi/Desktop/Pianobar-Web
	python pianobar_web.py
	cd /
This script worked on Wheezy and is even working on Jessie to start my application. However, when trying to start part of the application I am now getting an error related to Python. I am not very experienced with Debian and seem to be missing a file or dependency needed to run my application. Please see the error message below for information:
Error: 500 Internal Server Error
Sorry, the requested URL 'http://192.168.0.125:8080/auth' caused an error:
Exception:
OSError(2, 'No such file or directory')
Traceback:
File "/home/pi/Pianobar-Web/bottle.py", line 845, in _handle
return route.call(**args)
File "/home/pi/Pianobar-Web/bottle.py", line 1709, in wrapper
rv = callback(*a, **ka)
File "pianobar_web.py", line 67, in authenticate
proc = subprocess.Popen("pianobar", stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1335, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
I have tried making sure that python 2.7 is installed and up-to-date by using the command "apt-get install python2.7", but I already have the most recent version installed. Any help would be greatly appreciated.
Thank you!
Aydan
Re: Issue with Python on Jessie
Wed Feb 17, 2016 4:33 pm
You should specify the whole path to pianobar here. $PATH is probably different because the context of where the script is started is different.
Regards
Aydan
n8klayko
Wed Feb 17, 2016 6:42 pm
If I run the script manually from terminal the script works fine though. Are you thinking I should change the "pianobar" app path to the full path? Why would it work when run manually, but not when it is run at startup from crontab?
ghans
Wed Feb 17, 2016 6:44 pm
Because a crontab has a different $PATH than an interactive shell ? It's a well-known "feature" of crontabs.
ghans
n8klayko
Wed Feb 17, 2016 7:05 pm
That did it! Thank you!!! :D
Return to “Advanced users”
