pigpio vs. wiringpi
Posted: Fri Jan 29, 2016 11:57 pm
by rzusman
Compare and contrast...
I will be writing software in C with needs to talk to I/O , read/write SPI and I2C.
Is there any advantage of one library over the other?
Re: pigpio vs. wiringpi
Posted: Sat Jan 30, 2016 8:46 am
by joan
Nothing you mention would drive a choice either way. There is also http://www.airspayce.com/mikem/bcm2835/
Posted: Sat Jan 30, 2016 4:22 pm
by rzusman
Joan -
You developed pigpio, correct?
Was this before wiringpi or after? There must be some advantage for using one over the other (speed, efficiency, memory footprint, etc.).
Posted: Sat Jan 30, 2016 4:31 pm
by FTrevorGowen
rzusman wrote:Compare and contrast...
Horses for courses ... I've used both but happened to "come across" wiringPi first. Their "philosophies" are different and if you have an "Arduino background" (which I don't - my, what is now called "physical computing", background/experience goes 'way back to the Z80 and before but "ended" around the time of the "Basic Stamp") Gordon's approach with wiringPi may be easier to follow. @joan's pigpio is somewhat more comprehensive and, with her help, enabled me to do a few things that are not supported by wiringPi.
Trev.
Posted: Sat Jan 30, 2016 4:45 pm
by rzusman
Well, I'm an embedded systems developer, generally working with 8051-based devices.
I'm used to talking directly to a port pin, and most comfortable that way, but I can learn...
This will be my first Embedded Linux project, and it's a big one - redesigning our current RabbitSemi-based system using the Compute module. I'll need both serial ports, SPI, I2C, and around 20 I/O.
Posted: Sun Jan 31, 2016 10:36 am
by jahboater
Why don't you just try all three libraries for something simple at first and see how you get on? Perhaps do some measurements.
Joan is a frequent, and obviously highly knowledgeable, contributor to these forums.
