roboneo
raspberry pi zero dont read openelec
Thu Jan 28, 2016 11:49 pm
Hi, i got my pi zero today exited to use it with openelec as my entretainment center, i already have a B+ with openelec so i just put the card on the Zero pi but it didnt work, the zero didnt read the card but it works perfectly with other B+ i have, any idea whats the problem? Thank you guys
topguy
Re: raspberry pi zero dont read openelec
Fri Jan 29, 2016 12:41 am
You couldn't use Raspian either (afaik) until you had an updated firmware/kernel.
So it could be that the image you are using dont have the updated firmware.
More Info here: http://openelec.tv/forum/124-raspberry- ... =15#153868
roboneo
Fri Jan 29, 2016 1:15 am
topguy wrote:You couldn't use Raspian either (afaik) until you had an updated firmware/kernel.
the thing is i dont want to install the new openelec because any of the movie and tv streamers like genesis and pulsar work, so i wanted to use the sd card that its already configured with openelec 1.4.2, is there a way to solve this? can you explain me how?
topguy
Fri Jan 29, 2016 11:27 am
roboneo wrote:can you explain me how?
Its mentioned in exactly the forum post I linked to. You will have to update the firmware manually by copying the relevant files either from a newer openelec image ( or raspbian ).
Return to “Advanced users”
