Josvds
PulseAudio server latency
Sun Dec 06, 2015 3:14 pm
I have setup three devices with pulseaudio.
The goal is to send audio from one to two devices.
Only i can`t get the devices in sync, there is lot of latency.
Someone tips? Below my config.
Sender
From this device the audio go`s to the two receivers.
/etc/pulse/default.pa
# Audio-server
load-module module-native-protocol-unix
load-module module-suspend-on-idle timeout=1
load-module module-null-sink sink_name=rtp1 format=s16be channels=1 rate=44100 sink_properties="device.description='rtp1'"
load-module module-rtp-send source=rtp1.monitor loop=0
Receivers
Those two devices have the same configuration. The audio is received but far from sync (4 seconds).
# Audio-Client
load-module module-rtp-recv sap_address=10.10.10.51
/etc/pulse/daemon.conf
# Audio-Client
log-level = info
exit-idle-time = -1
resample-method = src-sinc-fastest
default-sample-rate = 44100
Josvds
Re: PulseAudio server latency
Wed Dec 09, 2015 10:00 pm
I now have tested three methods and all of the have some latency.
One more then the other.
Option A and B are much like each other.
- Two clients (in virtualbox) on desktop is very small latency echo
- One client in virtualbox and one rasberry pi is latency about 1~2 seconds
Option C
- Depending on what client is starting first latency about 2~4 seconds.
///// OPTION A \\\\\
# Client
apt-get install pulseaudio pulseaudio-module-zeroconf alsa-utils avahi-daemon
#load-module module-suspend-on-idle
/etc/pulse/daemon.pa
log-level = info
exit-idle-time = -1
# Server
load-module module-null-sink sink_name=rtp1 format=s16be channels=2 rate=44100 sink_properties="device.description='rtp1'"
load-module module-rtp-send source=rtp1.monitor loop=0 destination=10.10.10.51
load-module module-null-sink sink_name=rtp2 format=s16be channels=2 rate=44100 sink_properties="device.description='rtp2'"
load-module module-rtp-send source=rtp2.monitor loop=0 destination=10.10.10.52
load-module module-combine-sink sink_name=combined slaves=rtp1,rtp2 channels=4
set-default-sink combined
log-level = info
exit-idle-time = -1
///// OPTION B \\\\\
# Client
# Server
load-module module-rtp-send source=rtp.monitor rate=48000 channels=2 format=s16be
///// OPTION C \\\\\
# Client
apt-get install pulseaudio pulseaudio-module-zeroconf avahi-daemon dbus-x11
load-module module-udev-detect tsched=0
load-module module-native-protocol-tcp auth-ip-acl=127.0.0.1;10.10.10.0/24 auth-anonymous=1
load-module module-zeroconf-publish
# Server
load-module module-tunnel-sink server=10.10.10.51 sink_name=a
load-module module-tunnel-sink server=10.10.10.52 sink_name=b
load-module module-combine-sink sink_name=combined slaves=a,b
Josvds
Sun Dec 20, 2015 4:26 pm
I downloaded and installed Logitech Media Server.
http://www.mysqueezebox.com/download
Configured two folders on my disk with audio files.
I did download the RPI version (1 and 2) for my two PI`s.
https://sites.google.com/site/picoreplayer/home
In the web page of logitech media server i selected synchronize in the right top corner. The music is comming synced out of the speakers..
Now i`m going to look for a way to send audio from the desktop device trough the speakers without logitech media server because at the end i would like t use it for the sound on my PC as well for the movies.
Return to “Advanced users”
