Canedje
Overview of users login in the past
Fri Dec 04, 2015 1:21 pm
hello everybody.
Is there a method to show a list of users logged in at the RPI in the past including date and time?
I like to know this because my crontab commands where suddenly emptied without an explanation???
The header was stil there, the commands where gone.
Thanks for the answers
Re: Overview of users login in the past
Fri Dec 04, 2015 1:36 pm
You could try the "last" command which will show you all the logins since the log file was last cleared. The usual man page will show you the available options.
Canedje
Fri Dec 04, 2015 1:52 pm
rpdom wrote:You could try the "last" command which will show you all the logins since the log file was last cleared. The usual man page will show you the available options.
Thanks for the answer.
After using last command I only see:
wtmp begins Thu Jan  1 01:00:03 1970
It looks like this list is empty.
Do I need tot turn it on somhow before?
If I look to /var/log directory I do see:
lrwxrwxrwx 1 root  root        9 dec  4 11:58 wtmp -> /dev/null
It looks like the wtmp file is ported to the /dev/null
Sat Dec 05, 2015 8:22 am
What OS/distro are you running, because wtmp works on my Wheezy system that got upgraded to Jessie.
Canedje
Sat Dec 05, 2015 8:42 am
I'm using NOOBS
Sat Dec 05, 2015 9:01 am
Canedje wrote:I'm using NOOBS
Noobs is not an Operating System it is an installer / chooser :?
Canedje
Sat Dec 05, 2015 1:42 pm
This is the link I ever used in the far past:
https://www.raspberrypi.org/downloads/noobs/
So it looks like it is Raspbian
Return to “Advanced users”
