fulburncams
Yeird, has anyone tried saving power
Tue Jul 24, 2012 10:33 pm
Hi
I am building an embedded product and for the prototype/initial production phases want to use the Raspi. Has anyone here got any advice on how to reduce power consumption, e.g. slowing clocks , reducing voltages whatever ?
Many thanks
Steve
johnbeetem
Re: Yeird, has anyone tried saving power
Tue Jul 24, 2012 10:48 pm
There is a study of RasPi heat profiles by "Remy" at http://www.geektopia.es/es/technology/2 ... iento.html (Is the Raspberry Pi computer getting hot? A study of its operational temperature.) The Spanish article has numerous color temperature images of RasPi in various operational modes, which gives a good picture of what parts are using the most power.
Replacing 3.3V linear regulator RG2 with a switching regulator should help a lot, as will bypassing polyfuse F3 (a little). The LAN9512 generates the most heat, so if you don't need USB or Ethernet you might be able to get it into a low-power mode or use a Model A when it becomes available.
AndrewS
Tue Jul 24, 2012 11:30 pm
Return to “Advanced users”
