hiddenotebook
Make Raspberry to talk with Festival [tutorial] NEW VOICE
Mon Oct 05, 2015 9:36 am
THE NEW VOICE IS THE LAST MESSAGE
How to make Raspberry Pi2 Raspbian to talk with Festival.
Install festival.
sudo apt-get -y install festival
To tell our Raspi to use 3,5 Jack audio output.
amixer cset numid=3 1
Plug in speakers or headphones and type: 'echo "Hi dude, how can I help you?" | festival --tts' This will make festival to say everything between “” thingies.
You can pipe other things to festival if you end your lines with | festival -–tts example your computer hostname:
hostname | festival --tts
To read the contents of a text document in /home/pi for example 'file' just type.
festival --tts "file"
Tell the date:
date "+%H:%M %P %A %d %B %Y"| festival --tts
Read some selected text with a shortcut.
We need an application to aloud us pipe the text from Internet to festival 'xsel'
sudo apt-get install xsel
Make a bash script to do the job with cat
cat << eof > talk.sh
#!/bin/bash
xsel | festival --tts --pipe
eof
Permissions to execute for the file talk.sh
chmod +x talk.sh
Now we need to manage the shortcuts. In Raspian this is done by editing:
~/.config/openbox/lxde-pi-rc.xml
From command line type:
nano ~/.config/openbox/lxde-pi-rc.xml
Under the <keyboard> tag add:
<keybind key= "Name of key">
    <action name= "Execute">
        <execute>Command name</execute>
    </action>
</keybind>
Then you can complete the fields like this:
<!--Keybindings for Festival -->
<keybind key= "C-Menu">
        <execute>/home/pi/talk.sh</execute>
    </action>
</keybind>
That's all, from now you can read text with festival just selecting some text and puss the combo Control+Menu, you may need to reboot.
If you are wondering what happens when you push a button use the command 'xev' in terminal when you press a key, the shell will tell his name then you can use it to make the shortcuts.
Of course you can run festival with 'festival' command an read things.
Run festival.
festival
Say something.
(Saytext "Hello world")
Read a file.
(tts "file" nil)
Get out of festival.
(quit)
Sorry for my English I still learning your great language! have fun and talk with your raspy :)
I take this opportunity to ask you to share your progress with festival, let's make this topic a great post.
I'm working on handling the raspberry with voice commands, and answer me via julius. I'm sure many people would like the idea, let's work together.
see you!!
source: My place (with pics)
Last edited by hiddenotebook on Sat Sep 10, 2016 11:26 pm, edited 4 times in total.
hiddenotebook
Re: Make Raspberry to talk with Festival [tutorial]
Sun Oct 11, 2015 10:19 pm
A few days playing with festival and I bring my progress.
Install some voices us1_mbrola famale voice included!
sudo apt-get install festival festival-freebsoft-utils festlex-oald
sudo apt-get install festvox-kallpc16k festvox-kdlpc16k festvox-rablpc16k
mkdir /tmp/mbrola
cd /tmp/mbrola
wget http://www.tcts.fpms.ac.be/synthesis/mb ... mbrola.tgz
wget http://tcts.fpms.ac.be/synthesis/mbrola ... 980512.zip
wget http://tcts.fpms.ac.be/synthesis/mbrola ... 980910.zip
tar -xzvf mbrola.tgz
sudo mv mbrola /usr/bin
rm mbrola.tgz
unzip us1-980512.zip
unzip en1-980910.zip
sudo mkdir -p /usr/share/festival/voices/english/us1_mbrola/
sudo mkdir -p /usr/share/festival/voices/english/en1_mbrola/
sudo mv us1 /usr/share/festival/voices/english/us1_mbrola/
sudo mv en1 /usr/share/festival/voices/english/en1_mbrola/
wget http://www.festvox.org/packed/festival/ ... us1.tar.gz
tar -xzvf festvox_us1.tar.gz
sudo mv festival/lib/voices/english/us1_mbrola/* /usr/share/festival/voices/english/us1_mbrola/
wget http://www.festvox.org/packed/festival/ ... en1.tar.gz
tar -xzvf festvox_en1.tar.gz
sudo mv festival/lib/voices/english/en1_mbrola/* /usr/share/festival/voices/english/en1_mbrola/
rm festvox_en1.tar.gz
rm -rf festival
To set a dafault voice type:
sudo nano /etc/festival.scm
add this line:
(set! voice_default 'voice_us1_mbrola)
enjoy :)
hiddenotebook
great and clear famale voice for festival
Sat Sep 10, 2016 11:14 pm
I update this post today because I find a great female voice. I have more so if you like I can share :arrow:
Make a directory to do the job:
mkdir myvoice
cd myvoice
Download this great and clear voice:
wget http://www.speech.cs.cmu.edu/cmu_arctic/packed/cmu_us_slt_arctic-0.95-release.tar.bz2
Extract it:
tar xf cmu_us_slt_arctic-0.95-release.tar.bz2
Now move it to festival. Beware, we need to change the name here add _clunits suffix ok:
sudo mv cmu_us_slt_arctic /usr/share/festival/voices/english/cmu_us_slt_arctic_clunits
Make it the default voice : edit festival config file add this to a new line (/etc/festival*.scm)
(set! voice_default 'voice_cmu_us_slt_arctic_clunits)
Now start festival:
festival
Test it:
(SayText "Hello I am Alice, and i'm nice. This is a short introduction test.")
Your Welcome guys for this great girl
masterkenobi
Re: Make Raspberry to talk with Festival [tutorial] NEW VOICE
Tue Apr 17, 2018 10:12 am
after i set this...
I see this error.
-=-=-=-=-=- EST Error -=-=-=-=-=-
{FND} Feature Token_Method not defined
hiddenotebook
Tue Apr 17, 2018 12:09 pm
Check the folder voice name sould be cmu_us_slt_arctic_clunits if doesn't work there are 2 possibility one the name of the folder or the incompatibility with other voices
Good luck!
Return to “Advanced users”
