How to make Raspberry Pi2 Raspbian to talk with Festival.
Install festival.
sudo apt-get -y install festivalCode: Select all
amixer cset numid=3 1Code: Select all
echo "Hi dude, how can I help you?" | festival --ttsCode: Select all
hostname | festival --ttsCode: Select all
festival --tts "file"Code: Select all
date "+%H:%M %P %A %d %B %Y"| festival --ttsWe need an application to aloud us pipe the text from Internet to festival 'xsel'
sudo apt-get install xselCode: Select all
cat << eof > talk.sh
#!/bin/bash
xsel | festival --tts --pipe
eofCode: Select all
chmod +x talk.shCode: Select all
~/.config/openbox/lxde-pi-rc.xmlCode: Select all
nano ~/.config/openbox/lxde-pi-rc.xmlCode: Select all
<keybind key= "Name of key">
<action name= "Execute">
<execute>Command name</execute>
</action>
</keybind>Code: Select all
<!--Keybindings for Festival -->
<keybind key= "C-Menu">
<execute>/home/pi/talk.sh</execute>
</action>
</keybind>If you are wondering what happens when you push a button use the command 'xev' in terminal when you press a key, the shell will tell his name then you can use it to make the shortcuts.
Of course you can run festival with 'festival' command an read things.
Run festival.
festival Code: Select all
(Saytext "Hello world")Code: Select all
(tts "file" nil)Code: Select all
(quit)I take this opportunity to ask you to share your progress with festival, let's make this topic a great post.
I'm working on handling the raspberry with voice commands, and answer me via julius. I'm sure many people would like the idea, let's work together.
see you!!
source: My place (with pics)
