fableman
www-data /sys/class/gpio/gpio19/value: Permission denied
Fri Sep 18, 2015 4:09 pm
Hi
I read everything there is to read about making www-data able to access GPIO pins.
Nothing work anymore (worked on my old raspberry build 1 year ago, something changed)
I try to make my php script from a webpage to run a batch script that access a GPIO pin
I can't get it to work as www-data , only as root! :(
I set all my gpio's as user root when PI reboots.
my php script access myprogram
myprogram do this: echo 1 > /sys/class/gpio/gpio19/value
cat /var/log/apache2/error.log
/var/www/myprogram /sys/class/gpio/gpio19/value: Permission denied
(I tried to use sudo,visudo chmod 777,chown ..... about anything there is to try!!!)
I really need some help before I start pulling my hair :)
/Cheers...
joan
Re: www-data /sys/class/gpio/gpio19/value: Permission denied
Fri Sep 18, 2015 4:51 pm
You should be able to use the GPIOs if the user is a member of the gpio group.
Unfortunately the permissions of the exported GPIO is wrong with the latest kernels. It is set owner/group root/root, I think it should be root/gpio.
Fri Sep 18, 2015 9:26 pm
sudo useradd -g www-data gpio
joan
Fri Sep 18, 2015 9:29 pm
DougieLawson wrote:sudo useradd -g www-data gpio
Unfortunately that's not enough at the moment. The exported GPIOs are owner root, group root.
Fri Sep 18, 2015 9:30 pm
Ah, yes. I've just remembered there's that bug in the latest 4.1.xx kernels.
jojopi
Sat Sep 19, 2015 1:31 am
It is not a kernel bug. The true device path has changed at least twice, and varies by platform, including between Pi1 and Pi2 I assume. This is clearly intentional. It causes no problems for the user because the documented interface is via the symlinks in /sys/class/gpio/.
It is a bug in the existing udev rule that it ignores the device path—which udev knows—and instead hard codes various guesses. I believe it should also use RUN, rather than PROGRAM:
KERNEL=="gpio*", RUN="/bin/sh -c 'chgrp -R gpio /sys/%p /sys/class/gpio && chmod -R g+w /sys/%p /sys/class/gpio'"
(This is still pretty ugly. Essentially it changes the permissions on "export" when detecting "gpiochip0". I do not understand why that is necessary, since "udevadm test /class/gpio" suggests that it should trigger fine by itself. Also, is there really no way to get GROUP and MODE to apply to the files in a directory, without an external helper?)
I am not sure who maintains the udev rule. In the Foundation's wheezy repository, it is provided by packages python{3,}-pifacecommon. In jessie it appears to be gone.
fableman
Sat Sep 19, 2015 11:45 am
Sounds like all I can do, is to wait and hope it get fixed in the next release..
Guess I have a make a perl API running as root that will check for a web request to handle my GPIO's :(
fableman
Wed Oct 07, 2015 6:00 pm
Anyone got any news regarding this topic?
jojopi
Wed Oct 07, 2015 7:48 pm
fableman wrote:Anyone got any news regarding this topic?
The issue is fixed, in a way, in the Foundation's new jessie image.
If you want to run a new kernel on a wheezy image, or upgrade to jessie manually, try adding the line of code from my post above to a new file /etc/udev/rules.d/99-gpio.rules
Remember to add user www-data to group gpio
rpiuser2016
Thu Mar 28, 2019 12:40 pm
Hi!
I have execute
but it gives me an error:
useradd: user «gpio» already exicted
And I can not control GPIO as a www-data:
./water_off.sh: line 6: /sys/class/gpio/export: Permission denied
./water_off.sh: line 7: /sys/class/gpio/gpio19/direction: Permission denied
Help please
Thu Mar 28, 2019 12:43 pm
Hi!
I have execute
It will. You are trying to create a user called gpio with access to the www-data group, but you really want to add the www-data user to the gpio group. Also, you don't want to use useradd. That tries to create a new user. What you want is:
sudo usermod -G gpio www-data
Unreadable squiggle
rpiuser2016
Thu Mar 28, 2019 1:15 pm
Thanks for your fast reply!
This works! Now I am changing to www-data user and can execute this scripts, them works! But I am still cannot start them using RPi-CAM Webinterface buttons:
viewtopic.php?f=43&t=63276&p=1448295#p1448295
VLAD_CODER
Wed Jan 15, 2020 5:59 pm
I don't know any current solution to use the gpio as www-data but you can edit /etc/sudoers with the following command
sudo visudo /etc/sudoers
and add
www-data ALL=(ALL) NOPASSWD: ALL
on the last line and then use exec with sudo in front. It worked for me.
Wed Jan 15, 2020 6:11 pm
and add
DON'T DO THIS!
If you want you can add www-data user to the gpio group. That is safer. Otherwise your website user has unlimited access to your Pi and it is incredibly insecure.
Unreadable squiggle
Return to “Advanced users”
