K.Kong
Is there a built-in firewall?
Fri Sep 18, 2015 5:39 am
Does the Pi have a built-in firewall?
Are all ports for incoming traffic open by default on the LAN interface?
RobHenry
Re: Is there a built-in firewall?
Fri Sep 18, 2015 6:45 am
A network port is only open if a software application opens it. There's nothing 'built-in' that will prevent a port from being opened and made available to anything that can address it.
Fri Sep 18, 2015 7:05 am
K.Kong wrote:Does the Pi have a built-in firewall?
AFAIAA the Operating Systems available for the Raspberry Pi SBC do not come pre-configured with a Firewall
If you wish to implement a Firewall in a Linux Distro then install ufw from its repository..
The Uncomplicated FireWall is a front-end for iptables, to make managing a Netfilter firewall easier. It provides a command line interface with syntax similar to OpenBSD's Packet Filter. It is particularly well-suited as a host-based firewall.
Retired disgracefully.....
ghans
Fri Sep 18, 2015 7:19 am
netfliter is part of the Linux kernel. So i would say yes , every Linux-based Raspberry Pi OS like Raspbian comes with a firewall.
The problem is of course that it is not configured according to your needs (it's propably not even enabled).
Only you know how to do that , since you know your needs the best.
ghans
K.Kong
Fri Sep 18, 2015 8:34 am
Sorry, forgot to mention that mine is the Raspbian.
I was installing pptpd and this iptables thing came up. I then looked up iptables and wikipedia says "iptables is a user-space application program that allows a system administrator to configure the tables provided by the Linux kernel firewall "
That got me confused whether certain things were blocked by default as I was experiencing some network difficulties in another application in another Pi.
rpdom
Fri Sep 18, 2015 12:45 pm
Nothing is blocked on a default Raspbian installation.
You can check that with the iptables command. It should show that all three standard chains are set to ACCEPT all packets, with no other rules in place.
[email protected] ~ $ sudo iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Fri Sep 18, 2015 9:02 pm
K.Kong wrote: Are all ports for incoming traffic open by default on the LAN interface?
Ports are only open if you're running a listener.
If you're new to iptables then you will find configuring it is much easier with Fruity's UFW (user-friendly fire wall) package.
This is a doctor free zone.
Woll
Sat Sep 19, 2015 12:25 am
This link has info about a Raspi firewall.
http://www.makeuseof.com/tag/securing-r ... firewalls/
Who ate all the Pi's? Who ate all the Pi's?
Boris Johnson, Boris Johnson,
Return to “Advanced users”
