fmouse
Change default X11 display resolution
Sat Sep 12, 2015 5:11 pm
I have a Pi2. I like to use X11vnc to make the X display available on another Linux box runing a VNC client. If I have plugged our HD TV set into the HDMI port on the Pi the resolution in display 0 is large and when I access the GUI via a VNC client it's quit adequate. On the other hand, if I have nothing connected to the HDMI port, the X server initiates a 656x416 display which I can still access using VNC, but it's too small for most purposes. Is there any way to to make the default X server display come up at a higher resolution when there's no physical display device connected?
mattmiller
Re: Change default X11 display resolution
Sat Sep 12, 2015 9:12 pm
alter config.txt and uncomment the framebuffer width and height lines and set them to what you want
e.g
framebuffer_width = 1024
framebuffer_height = 768
fmouse
Sun Sep 13, 2015 4:48 am
Thank you, mattmiller. The fqn of the file is actually /boot/config.txt. Making the change you suggested gave me exactly the result I wanted.
Sean5555
Wed Oct 05, 2016 4:16 am
mattmiller wrote:alter config.txt and uncomment the framebuffer width and height lines and set them to what you want
e.g
Thanks. Helped me out.
Sean
Return to “Advanced users”
