batence
mysql database failed ... [SOLVED]
Sat Aug 29, 2015 12:31 pm
Hello guys,
jut because I want to use my RPi as hosting only for my blog I have remove X from it to free a space.
I have read some comments in the internet and what I do ....
### removing X
apt-get --purge remove x11-* && apt-get --purge autoremove && reboot
# after that
apt-get update && apt-get -y upgrade
### installing web server software
apt-get install nginx php5-fpm php-apc
### installing database software
apt-get install mysql-client mysql-server php5-mysql phpmyadmin
--> and after that my mysql fails ...
Reading package lists... Done
Building dependency tree
mysql-server is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]?
Setting up mysql-server-5.5 (5.5.44-0+deb7u1) ...
[ ok ] Stopping MySQL database server: mysqld.
[FAIL] Starting MySQL database server: mysqld . . . . . . . . . . . . . . failed!
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing mysql-server-5.5 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.5; however:
  Package mysql-server-5.5 is not configured yet.
dpkg: error processing mysql-server (--configure):
 dependency problems - leaving unconfigured
 mysql-server-5.5
 mysql-server
### so I am searching for error logs of mysql
root@soleil:~# ls /var/log/mysql
root@soleil:~#
Nothing.
### Looking in /var/log
alternatives.log  auth.log       btmp        dbconfig-common  dmesg    dmesg.1.gz  dmesg.3.gz  faillog  kern.log  lpr.log   mail.info  mail.warn  mysql    mysql.log  nginx     php5-fpm.log        samba   user.log
apt               bootstrap.log  daemon.log  debug            dmesg.0  dmesg.2.gz  dpkg.log    fsck     lastlog   mail.err  mail.log   messages   mysql.err  news       ntpstats  regen_ssh_keys.log  syslog  wtmp
### Yes there, some log files
root@soleil:~# cat /var/log/mysql
mysql/     mysql.err  mysql.log
root@soleil:~# cat /var/log/mysql.err
root@soleil:~# cat /var/log/mysql.log
They're empty.
So I believe there I have remove some liberties which mysql depending on them with
But I don't know which are they, also when I tried to install MySQL there's no additional dependencies installing.
Any advise?
Thanks!
Re: mysql database failed ...
Sat Aug 29, 2015 12:36 pm
X11 and MySQL are entirely unrelated.
To discover why your database is not starting run mysqld from the command line.
sudo mysqld --verbose
batence
Sat Aug 29, 2015 12:52 pm
Hello DougieLawson,
Thank you for your fast reply!
Yes I know there's nothing related between MySQL and X but there's a strange issue that comes after removing X.
So I have checked MySQL as you suggest me ...
root@soleil:~#  mysqld --verbose
150829 12:44:25 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
150829 12:44:25 [Note] mysqld (mysqld 5.5.44-0+deb7u1) starting as process 8491 ...
150829 12:44:25 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead.
150829 12:44:25 [Note] Plugin 'FEDERATED' is disabled.
150829 12:44:25 InnoDB: The InnoDB memory heap is disabled
150829 12:44:25 InnoDB: Mutexes and rw_locks use GCC atomic builtins
150829 12:44:25 InnoDB: Compressed tables use zlib 1.2.7
150829 12:44:25 InnoDB: Using Linux native AIO
150829 12:44:25 InnoDB: Initializing buffer pool, size = 128.0M
150829 12:44:25 InnoDB: Completed initialization of buffer pool
150829 12:44:25 InnoDB: highest supported file format is Barracuda.
150829 12:44:27  InnoDB: Waiting for the background threads to start
150829 12:44:28 InnoDB: 5.5.44 started; log sequence number 1595675
150829 12:44:28 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
150829 12:44:28 [Note]   - '127.0.0.1' resolves to '127.0.0.1';
150829 12:44:28 [Note] Server socket created on IP: '127.0.0.1'.
150829 12:44:28 [ERROR] Can't start server: Bind on TCP/IP port: Cannot assign requested address
150829 12:44:28 [ERROR] Do you already have another mysqld server running on port: 3306 ?
150829 12:44:28 [ERROR] Aborting
150829 12:44:28  InnoDB: Starting shutdown...
150829 12:44:29  InnoDB: Shutdown completed; log sequence number 1595675
150829 12:44:29 [Note] mysqld: Shutdown complete
It seems MySQL can't bind port 3306, that is good news because confirm that the liberties of X are unrelated with MySQL.
So it is a port issue.
I have checked ports ...
root@soleil:~# netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      2153/sshd
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           2065/avahi-daemon:
udp        0      0 0.0.0.0:32778           0.0.0.0:*                           2065/avahi-daemon:
udp        0      0 0.0.0.0:68              0.0.0.0:*                           1878/dhcpcd
udp        0      0 192.168.1.131:123       0.0.0.0:*                           2106/ntpd
udp        0      0 0.0.0.0:123             0.0.0.0:*                           2106/ntpd
root@soleil:~# netstat -lptu
tcp        0      0 *:ssh                   *:*                     LISTEN      2153/sshd
udp        0      0 *:mdns                  *:*                                 2065/avahi-daemon:
udp        0      0 *:32778                 *:*                                 2065/avahi-daemon:
udp        0      0 *:bootpc                *:*                                 1878/dhcpcd
udp        0      0 soleil.local:ntp        *:*                                 2106/ntpd
udp        0      0 *:ntp                   *:*                                 2106/ntpd
root@soleil:~# netstat --listen
udp        0      0 *:mdns                  *:*
udp        0      0 *:32778                 *:*
udp        0      0 *:ntp                   *:*
Active UNIX domain sockets (only servers)
Proto RefCnt Flags       Type       State         I-Node   Path
unix  2      [ ACC ]     SEQPACKET  LISTENING     4136     /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     7215     /var/run/avahi-daemon/socket
unix  2      [ ACC ]     STREAM     LISTENING     17305    /var/run/php5-fpm.sock
unix  2      [ ACC ]     STREAM     LISTENING     6125     /var/run/dhcpcd.sock
unix  2      [ ACC ]     STREAM     LISTENING     6127     /var/run/dhcpcd.unpriv.sock
unix  2      [ ACC ]     STREAM     LISTENING     7160     /var/run/dbus/system_bus_socket
And strange again ... I am confused.
Thanks!
Sat Aug 29, 2015 2:24 pm
What do you get from
ifconfig -a
sudo netstat -tlnp | grep 3306
batence
Sat Aug 29, 2015 2:36 pm
root@soleil:~# ifconfig -a
eth0      Link encap:Ethernet  HWaddr b8:27:eb:da:c4:e7
          inet addr:192.168.1.131  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1492  Metric:1
          RX packets:25375 errors:0 dropped:1 overruns:0 frame:0
          TX packets:12166 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:26427247 (25.2 MiB)  TX bytes:1522201 (1.4 MiB)
lo        Link encap:Local Loopback
          LOOPBACK  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
root@soleil:~# sudo netstat -tlnp | grep 3306
root@soleil:~#
### Update 2: I have also commented mysql service in /etc/services
root@soleil:~# nano /etc/services
#mysql 3306/tcp
#mysql 3306/udp
Rebooted and still can't bind the port :/
### Update 3: Changing value 127.0.0.1 to my local IP of eth0 (192.168.1.131) in configuration file of MySQL in /etc/my.conf solved my issue!
root@soleil:~# nano /etc/mysql/my.cnf
And change 127.0.0.1 to your local or real ip.\
note: I have tried with "localhost" but don't work. localhost may can use only when you have bind your local ip to localhost in /etc/hosts.conf but this doesn't make any sense.
root@soleil:~# service mysql restart
[ ok] Stopping MySQL database server: mysqld.
[ ok ] Starting MySQL database server: mysqld . . . ..
[info] Checking for tables which need an upgrade, are corrupt or were not closed cleanly..
root@soleil:~#
I found the solution here: http://stackoverflow.com/questions/1873 ... onnections
Re: mysql database failed ... [SOLVED]
Sat Aug 29, 2015 3:19 pm
Your localhost "lo" interface isn't working. It isn't showing an IP address. Have you got "auto lo" in /etc/network/interfaces?
batence
Sat Aug 29, 2015 3:24 pm
root@soleil:~# cat /etc/network/interfaces
cat: /etc/network/interfaces: No such file or directory
I get nothing but commented line with bind_address helps too too much.
As I have already remember there in other linux and unix distributions that I have stuffing before in my.cnf there no forced option for "bind-address" variable.
Sat Aug 29, 2015 5:16 pm
batence wrote: ### Update 3: Changing value 127.0.0.1 to my local IP of eth0 (192.168.1.131) in configuration file of MySQL in /etc/my.conf solved my issue!
Wrong answer. That will fail if your DHCP lease expires and your RPi gets a new IP address.
You need to fix your loopback interface, because other things will fail (unexpectedly) without it.
Or update /etc/mysql/my.cnf with
bind-address            = 0.0.0.0
batence
Sat Aug 29, 2015 6:47 pm
My router is applied to give ip's by mac.
But comment the line is the best solution for me.
Return to “Advanced users”
