I'm sure most of you are going to roll your eyes because fans are not necessary for the pi, but I didn't intentionally start out with it in mind, OK?
Yeah, mine has got aluminium heatsinks stuck with thermal tape as well... 15 years of overclocking Intel/AMD CPU's has got me into bad habits
I was clearing out the garage at the weekend and had a lot of old computer stuff, which included various USB leads. I figured "what the heck" and stripped one back just to see what was actually inside.
Beyond the protective weave and foil, there are four wires - two for data, the red and black for power.
Rummaging around I found an old hard-drive cooler and remove one of it's fans - which was smaller than my pi case and therefore I figured might be mountable. It's rated at 12V, though I guessed it'd take much less due to it's size (USB is 5V I think, so assuming there was enough juice to start, it would - just not at 100% speed). That also had red and black wires.
I broke out the soldering iron and some insulation tape - then twisted and soldered the wires together (blue-black, red-red obviously) and just removed the USB data wires as best as I could.
Plugged the USB lead into my powered USB hub and bingo - I have airflow
Just need to get the dremel out, make a hole in my case, and secure the fan now.
It was an interesting experiment
I'm sure others have found a better way of getting power (GPIO pins presumably), but I amused myself for 25 minutes
