Help writing an overlay (dts / device tree) for an ssd1307
Posted: Sat Apr 04, 2015 2:44 pm
by zashi
I could use a little help / sanity check trying to get an overlay working.
I've got a ssd1306-based OLED screen wired up. It's uses i2c. i2cdetect -y 1 shows me the device on the i2c bus.
To use the in-kernel driver for the ssd1306 (which is ssd1307fb.ko), you have to add a device tree entry.
I wrote a dts by combining the rpi overlay example from here http://www.raspberrypi.org/documentatio ... ce-tree.md with the ssd1307fb example from here https://www.kernel.org/doc/Documentatio ... 1307fb.txt but it is no doubt wrong (see bottom of post).
I compiled the dts into a dtb via
dtc [email protected] -I dts -O dtb -o oled-overlay.dtb oled-overlay.dts
, stashed oled-overlay.dtb into /boot/overlays and then added these two lines to config.txt:
device_tree=bcm2708-rpi-b-plus.dtb
dtoverlay=oled
I know I got device-tree loaded and working as /proc/device-tree exists and is populated, plus I've got the human readable form of the Machine showing: [ 0.000000] Machine model: Raspberry Pi Model B+
But I am not getting a second framebuffer device like I would expect, nor is ssd1307fb loading automatically. If I load the module manually nothing happens--no output in dmesg. /proc/device-tree does not contain any references to oled or solomon.
Can anyone help me figure out what I'm doing wrong or what changes I need to make to my overlay? Perhaps if we can get this working we can included it by default like the other overlays, as these OLED screens are quite cheap (mine was less than USD$10 with shipping).
My oled-overlay.dts:
// Definitions for Rpi-Proto
/dts-v1/;
/plugin/;
	compatible = "brcm,bcm2708";
	[email protected] {
		target = <&i2c1>;
		__overlay__ {
			[email protected] {
					compatible = "solomon,ssd1306fb-i2c";
					reg = <0x3c>;
Re: Help writing an overlay (dts / device tree) for an ssd13
Posted: Sat Apr 04, 2015 8:18 pm
by notro
Does your device show up in /sys/bus/i2c/devices/ ?
Have you built your own kernel?
Because the module is not enabled in the official one:
$ zgrep SSD1307 /proc/config.gz
# CONFIG_FB_SSD1307 is not set
You can enable the i2c bus in the oled overlay as well:
		target = <&i2c1>;
		__overlay__ {
			status = "okay";
Posted: Sat Apr 04, 2015 10:40 pm
by zashi
I'm not running a stock kernel, and yes I have ssd1307fb.ko built.
Posted: Sun Apr 05, 2015 2:27 pm
by zashi
I'm not running a stock kernel, but yes, I of course have the ssd1307fb module compiled.
No, I do not see anything on the i2c bus in /sys/bus/i2c. If you're wondering if i2c is loaded and working, it clearly is, as you can see the oled driver on the i2c bus via i2cdetect.
Posted: Sun Apr 05, 2015 5:31 pm
by notro
The device must show up in /sys/bus/i2c/devices
This is an i2c driver I'm currently working on:
Device Tree
$ ls -l /proc/device-tree/soc/[email protected]/
total 0
-r--r--r-- 1 root root  4 Apr  5 17:04 #address-cells
-r--r--r-- 1 root root  4 Apr  5 17:04 clock-frequency
-r--r--r-- 1 root root  4 Apr  5 17:04 clocks
-r--r--r-- 1 root root 17 Apr  5 17:04 compatible
-r--r--r-- 1 root root  8 Apr  5 17:04 interrupts
-r--r--r-- 1 root root  4 Apr  5 17:04 linux,phandle
-r--r--r-- 1 root root  4 Apr  5 17:04 name
-r--r--r-- 1 root root  4 Apr  5 17:04 phandle
-r--r--r-- 1 root root  4 Apr  5 17:04 pinctrl-0
-r--r--r-- 1 root root  8 Apr  5 17:04 pinctrl-names
-r--r--r-- 1 root root  8 Apr  5 17:04 reg
-r--r--r-- 1 root root  4 Apr  5 17:04 #size-cells
drwxr-xr-x 2 root root  0 Apr  5 17:04 [email protected]
-r--r--r-- 1 root root  5 Apr  5 17:04 status
$ ls -l /proc/device-tree/soc/[email protected]/[email protected]/
total 0
-r--r--r-- 1 root root 19 Apr  5 17:07 compatible
-r--r--r-- 1 root root  4 Apr  5 17:07 linux,phandle
-r--r--r-- 1 root root  8 Apr  5 17:07 name
-r--r--r-- 1 root root  4 Apr  5 17:07 phandle
-r--r--r-- 1 root root  4 Apr  5 17:07 pinctrl-0
-r--r--r-- 1 root root  8 Apr  5 17:07 pinctrl-names
-r--r--r-- 1 root root  4 Apr  5 17:07 reg
-r--r--r-- 1 root root 12 Apr  5 17:07 reset-gpios
$ hexdump -C /proc/device-tree/soc/[email protected]/[email protected]/reg
00000000  00 00 00 3c                                       |...<|
00000004
i2c device
$ ls -l /sys/bus/i2c/devices/1-003c/
total 0
lrwxrwxrwx 1 root root    0 Apr  5 17:03 driver -> ../../../../../bus/i2c/drivers/ada-ssd1306fb
drwxr-xr-x 4 root root    0 Apr  5 17:03 drm
-r--r--r-- 1 root root 4096 Apr  5 17:03 modalias
-r--r--r-- 1 root root 4096 Apr  5 17:03 name
lrwxrwxrwx 1 root root    0 Apr  5 17:03 subsystem -> ../../../../../bus/i2c
-rw-r--r-- 1 root root 4096 Apr  5 17:03 uevent
Posted: Tue Jun 14, 2016 1:32 am
by Regex_Philbin
I know this thread is old, but did anyone make progress on this? I feel really close, I have things showing up in /sys/bus/i2c/devices/...
Posted: Tue Jun 14, 2016 11:55 am
by zashi
Nope, but if you get it working please post. I never could.
Posted: Wed Jun 15, 2016 12:02 am
by Regex_Philbin
Thanks, I will.. by the way, my display only has 4 pins, no reset pin, which I think could be a problem here but not sure.. also I'm using a Pi Zero but I don't think that matters..
Posted: Sun Mar 26, 2017 11:08 am
by fiveseven808
Hey, I know this thread is almost a year old, but I was wondering if anyone in here figured this out?
I want to use this SSD1307 driver in 1306 mode (since it supports it) but I'm not sure where to start.
If I had to guess, the ssd1307fb module needs to be loaded in /etc/modules so it runs on boot (i guess?).
Really curious about using an I2C SSD1306 as a frame buffer! fbtft unfortunately only supports SPI (and it works damn well!)
Re: Help writing an overlay (dts / device tree) for an ssd1307
Posted: Sun Feb 04, 2018 7:32 pm
by ighea
I'm sorry for rising a dead thread, but I have some sad results.
I also bought one of these 4-pin OLED displays with ssd1306 driver and wanted to get it to work as framebuffer device. Becouse of that I also ended up on this thread.
As somebody mentioned here the problem with original ssd1307fb driver is that it expects the screen to have a reset pin set and configured on the device tree settings file. After coursing through the source file the reset didn't seem to be used for much and just dirty removal for testing proved some successful results. I got the fb device to appear and work somewhat.
Well, i2c is slow. Really slow. Also, the image seems to be mirrored and rotated so it would require some additional tweaking. I also couldn't get any usefull results out from playing 1-bit video (didn't play, some initializen problems that didn't really help to solve the proble, I assumed too small screen size or buffers) or displaying images with fbi program. Console worked after some tweaking and playing around, but is mostly useless for anything at this moment.
Overall it would be better to just use Adafruit's python library to display stuff on the small monochrome screen.
Becouse the effort this took I wanted to document it loosely here for future reference.
After collecting bits from here and there I ended up with following puzzle pieces:
device tree file: oled.dts:
/dts-v1/;
/plugin/;
	compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
	[email protected] {
		target = <&i2c>;
		__overlay__ {
			status = "okay";
			#address-cells = <1>;
			#size-cells = <0>;
			ssd1306: [email protected] {
				reg = <0x3c>;
				solomon,width = <128>;
				solomon,height = <64>;
				solomon,page-offset = <0>;
Compile dtbo and move it to overlays:
dtc [email protected] -I dts -O dtb -o oled.dtbo oled.dts && mv oled.dtbo /boot/overlays/
Install kernel headers for stock kernel for compiling the modified driver:
sudo apt install raspberrypi-kernel-headers
Fetch appropriate driver source from Raspberry Pi kernel tree for ssd1307fb:
wget https://raw.githubusercontent.com/raspberrypi/linux/rpi-4.9.y/drivers/video/fbdev/ssd1307fb.c
Remove or comment out all lines related to reset, or just try to use this as long as it exists: http://w.igh.fi/ssd1307fb.c
Create following Makefile to same directory with the source code file and run make as root (yes, for some funny reasons even sudo does not work):
# Makefile
obj-m+=ssd1307fb.o
all:
	make -C /lib/modules/$(shell uname -r)/build M=$(shell pwd) modules
clean:
	make -C /lib/modules/$(shell uname -r)/build M=$(shell pwd) clean
modules_install: all
	$(MAKE) -C $(KERNEL_SRC) M=$(SRC) modules_install
	$(DEPMOD)
If all goes well copy the new ssd1307fb.ko to overwrite current module:
cp ssd1307fb.ko /lib/modules/$(uname -r)/kernel/drivers/video/fbdev/ssd1307fb.ko
Enable the overlay with
dtoverlay oled
This should load the new ssd1307fb driver and result the following in dmesg log:
Feb  4 18:42:50 raspberrypi kernel: [   73.626023] ssd1307fb: loading out-of-tree module taints kernel.
Feb  4 18:42:50 raspberrypi kernel: [   73.635531] ssd1307fb 1-003c: fb1: Solomon SSD1307 framebuffer device registered, using 1024 bytes of video memory
And /dev/fb1 should appear on devices.
I might have missed something I did, but this should highlight the important bits.
Edit: Fixed a typo.
Posted: Mon Mar 26, 2018 12:16 pm
by fraz
Thanks for posting your steps @ighea!
I have a SSD1306 128x64 monochrome OLED from ebay too.
I was getting s warning:
Warning (unit_address_vs_reg): Node /[email protected] has a unit name, but no reg property
while doing
"dtc [email protected] -I dts -O dtb -o oled.dtbo oled.dts && mv oled.dtbo /boot/overlays/"
It seems this is harmless according to viewtopic.php?t=140835:
The warning is just an annoying feature of the latest version of dtc. The usual rule for DTs is that nodes with @<n> at the end of their name also include a matching "reg = <n>" property within the node. Fragments of overlays don't obey this rule. [ There is an ongoing behind-the-scenes debate about making support for overlays part of the official dtc source tree, rather than a set of patches maintained by others. I hope the resolution of that will see and end to such niggles. ]
Also, a minor typo:
The command to enable overlays is
dtoverlay oled
and to test it: "dd if=/dev/urandom of=/dev/fb1" prints snow on the oled. Hooray!
Now to see it is faster than the adafruit python library.... I'm trying to display animated radar images without using 50-90% CPU like the python library does.
Posted: Mon Mar 26, 2018 1:26 pm
by fraz
And I can confirm this is woeful.
I get about 1 frame per second using mplayer:
mplayer -vo fbdev2:/dev/fb1 -x 128 -y 64 -bpp 1 -fs -zoom ../radar.gif
Using mp4, or GIF. Even using 1 bit 128x64 source material (the radar images I've processed to display:
https://imgur.com/KH5Y2G8 - radar MP4
https://imgur.com/E8LQ1OM - radar GIF
Plus the display is kind of sliced up in vertical bands that are out of place. I used your supplied file with the reset lines removed. I suspect it needs some work to fix the display corruption, but I think it's too slow for me to get anywhere with.
And here's here's a tiny video to show you how the output looks:
https://imgur.com/QZnF1p1
back to python libraries I think!
Posted: Mon Mar 26, 2018 11:24 pm
by fraz
One more post in case it helps the next person. The vertical garbled bands might be a clock issue?
https://www.freetronics.com.au/pages/ol ... spberry-pi
Troubleshooting
If the OLED128 display is appearing garbled or not reliably updating, you may need to lower the SPI clock speed (that controls the rate that data is sent to the display.) This can particularly be the case if you are using long (>10cm) cables from the Pi to the OLED128.
You can do this by passing an additional argument "speed" to the fbtft_device module. Instead of:
fbtft_device name=freetronicsoled128
Try:
fbtft_device name=freetronicsoled128 speed=16000000
The default speed is 20MHz (20000000), try values lower than this and see if the screen starts updating reliably.
To make this change permanent, you can add the equivalent arguments to the line in the /etc/modules file on the Pi:
Maybe one day I'll look at the ssd1307fb code and see if I can pass options for the clock speed.
Posted: Wed Jul 18, 2018 2:43 am
by BeauSlim
I tried this a while back with my Adafruit OLED Bonnet but I think the "reset" issue got in the way. ighea, thank you so much for sorting this all out! It works quite well now, at least for text consoles.
The latest kernel code removes the reset requirement, so there's no need to comment stuff out and worry about problems.
For the Adafruit OLED Bonnet, I needed to add solomon,com-invdir; to the dts because the screen was backwards.
Other than that, the instructions above worked like a charm.
I then simply added fbcon=map:1 to /boot/cmdline.txt for a text console on the OLED. A really tiny console font like that tom-thumb one can get you a 10x32 terminal. Enough to edit /etc/fstab or install packages with apt.
I don't think there's anything to change the data rate to the screen other than the dtparam=i2c_baudrate=1000000 parameter in /boot/config.txt. Maybe try 4000000 on a Pi3. Most of the information out there is for SPI, and I don't think it applies here.
Posted: Fri Oct 12, 2018 8:20 am
by Samcomeau
I did this and it worked wonderfully! Your instructions were spot on. Thank you. I had a small problem because my oled came out mirrored. I ended up adjusting the c file to flip the segment remap. I'm sure there is an easier way, but this works.
