Hello.
Sounds strange. But is there a way how to slow down the Rpi 2 (cpu frequency, disable quad cores, get rid of 512mb of ram) to work at speed similar to Rpi B+.
I have project playing several video files and switching between them and Rpi 2 is visibly faster in that than old Rpi B+.
In some cases I need all Rpi (Pi 2 and B+) to work at the same speed.
Thanks for any help.
- DougieLawson
- Contact: Website Twitter
Re: Slow down Rpi 2 to work at same speed as Rpi B+
Try in /boot/cmdline.txt
Top shows:
top - 00:00:49 up 0 min, 1 user, load average: 0.60, 0.18, 0.06
Tasks: 93 total, 1 running, 92 sleeping, 0 stopped, 0 zombie
%Cpu0 : 0.7 us, 0.3 sy, 0.0 ni, 99.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu1 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu2 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu3 : 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 884388 total, 108212 used, 776176 free, 13244 buffers
KiB Swap: 511996 total, 0 used, 511996 free, 56356 cached
It's still 900/700 times quicker than a A/B/B+/A+ (because of the increased CPU frequency) but closer to what you want.
isolcpus=1,2,3
Top shows:
Why not just get another B+? They're not only available, but several companies have started discounting them since the Pi2B came out.
That'll save a bit of hardware unplugging and pluggin during testing :0
Is there a similar setting to restrict RAM that can easily be altered as well?
I have try isolcpus=1,2,3 in config.txt do the reboot and no change
top says:
top - 08:45:08 up 10 min, 1 user, load average: 0.71, 0.38, 0.19
Tasks: 83 total, 1 running, 82 sleeping, 0 stopped, 0 zombie
%Cpu0 : 1.0 us, 4.5 sy, 0.0 ni, 81.7 id, 12.8 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu1 : 1.0 us, 17.6 sy, 0.0 ni, 81.4 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu2 : 8.1 us, 4.4 sy, 0.0 ni, 78.7 id, 8.8 wa, 0.0 hi, 0.0 si, 0.0 st
%Cpu3 : 0.3 us, 2.0 sy, 0.0 ni, 97.6 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 234660 total, 135652 used, 99008 free, 6148 buffers
KiB Swap: 0 total, 0 used, 0 free, 78916 cached
I also reserved 768M for GPU to have the same amount for the system as in Raspi B+
top says:
DougieLawson wrote: in /boot/cmdline.txt
It is my mistake. Sorry for misreading. When I put it into the cmdline.txt it works now.
It is better now. But processor speed is still quicker than Rpi B and this is still visible.
Is there a way how to underclock the 900Mhz cpu to 700Mhz.
I even tried to setup on Rpi 2 in /boot/config.txt
arm_freq=600
sdram_freq=400
but Rpi2 is still faster than Rpi.
I notice first difference in cache reading from SD card (same SDcards):
On Rpi2 and Rpi is emmc clock same :
vcgencmd measure_clock emmc
frequency(47)=250000000
On Rpi2:
hdparm -t /dev/mmcblk0
/dev/mmcblk0:
Timing buffered disk reads: 54 MB in 3.03 seconds = 17.81 MB/sec
hdparm -T /dev/mmcblk0
/dev/mmcblk0:
Timing cached reads: 554 MB in 2.00 seconds = 276.80 MB/sec
On RpiB+:
/dev/mmcblk0:
Timing buffered disk reads: 52 MB in 3.00 seconds = 17.32 MB/sec
/dev/mmcblk0:
Timing cached reads: 376 MB in 2.01 seconds = 187.11 MB/sec
Why there is so such difference in cache reads?
arm_freq=600
sdram_freq=400
On Rpi2:
/dev/mmcblk0:
/dev/mmcblk0:
On RpiB+:
/dev/mmcblk0:
/dev/mmcblk0:
The bcm2836 has cache which wasn't present in the bcm2835.
In particular the new 512kB L2 cache dedicated to the core.
See http://makezine.com/2015/02/02/eben-upt ... erry-pi-2/ (search for cache).
- DougieLawson
Could that be crippled by massively over specifying GPU memory?joan wrote:The bcm2836 has cache which wasn't present in the bcm2835.
gpu_mem=528 # or bigger
- Raspberry Pi Engineer & Forum Moderator
"total_mem=512" will hide half the memory.
"arm_freq=700", "sdram_freq=400" will remove the higher frequencies.
However Pi2 will still be a lot faster than Pi1. The large/fast L2 cache is a lot quicker, and clock-for-clock, then newer arm architecture gets more work done each cycle.
That is true. After slowdown frequency, restricted process to only one core, use the same amount of memory, the new raspi 2 is still more powerfull than old Raspi.(especially in video/image decoding). It is really with help of 512kb L2 cache and use of NEON instructions. I compared it when switching between several video files. The new video file is decoded and showed to user more faster than in previous Raspi.
