trn
Rpi vs A8, cpu compare
Sat Jul 07, 2012 12:27 pm
In %, how much is A8 at 1.5Ghz better vs rpi on 700Mhz?
kadamski
Re: Rpi vs A8, cpu compare
Sun Jul 08, 2012 9:37 pm
It depends on a workload. It will be probably about 3-4 times faster on general computation. Cortex-A8 has 2 DMIPS/Mhz while ARM11 has 1.25 DMIPS/Mhz, Cortex-A8 has NEON, usually has bigger caches, better branch prediction. I've seen some cases where floating point operations where slower on Cortex processors, though (VFP is optional there).
AndrewS
Thu Jul 12, 2012 12:26 am
...and if you're running a particularly memory-intensive program, your Cortex-A8 may be attached to much more memory than the 256MB available to the Raspi.
...and if you're running a particularly disk-intensive program, your A8 might be connected to a chipset containing a SATA controller, much better than the flaky USB-driver used by the Raspi.
...and if you're running a particularly network-intensive program, your A8 might be connected to a chipset containing a gigabit ethernet controller, much better than the USB-ethernet used by the Raspi.
...and if you're running a particularly graphics-intensive program, your A8 is unlikely to have something as fast as the VideoCore IV used by the Raspi :D
etc. etc. ;)
Return to “Advanced users”
