Best Method to Test OC on Pi 2 - Raspian?
Posted: Sat Mar 14, 2015 7:42 pm
by Bananaguns
I am trying to see what the max stable over clock configuration is, but right now I'm doing this the obvious way,
nano /boot/config
And changing frequency that way, which is fine... When it works. However if it doesn't then I have to go back to the computer and re-burn the raspbian image and start over.
I know on the banana pi you cab echo the values you want to test then if they cause a freeze or are otherwise unstable the values reset when you reboot but I can't find the equivalent files on raspbian. Any ideas?
Right now I'm pretty content with
 arm_freq=1120
core_freq=500
sdram_freq=500
over_voltage=6
gpu_mem=128
temp_limit=70
But I'm still curious how far I can push it :twisted:
Re: Best Method to Test OC on Pi 2 - Raspian?
Posted: Sat Mar 14, 2015 8:06 pm
by jamesh
That's pretty fast TBH, doubt you will get much more than that given the chips rating at 900.
Posted: Sat Mar 14, 2015 10:37 pm
by xoopha
Mine doesn't like to go over 1050MHz, it starts misbehaving pretty quickly.
Posted: Sun Mar 15, 2015 7:02 pm
by eriktheitalian
Can u start process load for all SOC departments at same time. Full cpu load. Full gpu. Full hardware video accelerator. U can test SOC heat with this.
