run rpi 2 on sd
Posted: Thu Mar 12, 2015 5:12 pm
by johnlee
Did I miss something. I'd assumed that my rpi 2 would be same as my rpi 1 ie use SD, but find it doesn't - needs microsd, so can't use my SDs. I've been looking on ebay/amazon etc for an adapter but find there are lots of them, but they are all adapters to plug a microsd into a SD slot. Did I miss something - why no suitable adapters? Would someone pls point me at an adapter so I can use SDs in my rpi 2 or tell me that thy don't exist?
TIA John
Re: run rpi 2 on sd
Posted: Thu Mar 12, 2015 5:19 pm
by jamesh
They don't exist.
uSD are pretty cheap now - best bet is to buy a new one.
The Pi went uSD when the B+ was launched, some while ago!
Re: run rpi 2 on sd
Posted: Thu Mar 12, 2015 5:53 pm
by DougieLawson
Re: run rpi 2 on sd
Posted: Thu Mar 12, 2015 6:42 pm
by davidcoton
johnlee wrote:Did I miss something. I'd assumed that my rpi 2 would be same as my rpi 1 ie use SD, but find it doesn't - needs microsd, so can't use my SDs.
Are you sure the older cards are actually SD, and not microSD in an SD adapter?
Re: run rpi 2 on sd
Posted: Fri Mar 13, 2015 12:05 am
by johnlee
DougieLawson wrote:
jamesh wrote:They don't exist.
http://www.zeitech.de/Zeroplus-Micro-SD-Karte-Adapter
Thanks - tho not 100% sure where it accomodates the SD. Also it is v expensive - the microsd- sd adapters that are so plentiful can be less that £1 including postage. Still think there should be market - lots of usable SDs out there! j
Re: run rpi 2 on sd
Posted: Fri Mar 13, 2015 12:06 am
by johnlee
Yes, I can see them here! J
Re: run rpi 2 on sd
Posted: Fri Mar 13, 2015 12:09 am
by johnlee
But why not? - there must be a lot of newish 4-8G or even bigger SDs out there. J
Re: run rpi 2 on sd
Posted: Fri Mar 13, 2015 6:47 am
by ghans
MicroSDs are smaller on purpose. There is often no
space to use an adaptor - contrary to the
adaptors which work the other way round.
<sarcasm>
Furthermore MicroSD cards have to be more expensive
than regular ones ( they're smaller , right ?) and how
are the manufacturers going to make money if
everybody just uses their old SD cards in adaptors ??
Solution : make adaptors more expensive </sarcasm>
To be honest , i think you are just overstimating demand/supply for
such an adaptor - they DO indeed exist for those people who
can quantify their needs in hard cash (commercial clients ?).
ghans
