2 32x64 LED matrices connected via GPIO
Posted: Wed Mar 11, 2015 9:50 am
Hello there,
For a work project (I work for a web development agency) we've decided to do some experiments with the Raspberry Pi2. One of these experiments which I've gotten the green light to do is a little project involving a 64x64 LED Matrices which can be found here:
http://www.led-card.com/product_info.ph ... cts_id=243
Unfortunately they only do a maximum of 32 x 64, so my hope is to set up two of these running in unison from a Raspberry Pi, controlling them with the GPIO pins.
I'm at a bit of a loss where to begin, I've found tutorials that show how to hook two 32x32 matrices together, and there are some libraries out there to handle the IO, for example: https://github.com/hzeller/rpi-rgb-led-matrix, but they only seem to go up to a certain size.
I believe this type of matrix can be daisy chained together, but I've read a lot of stuff about having to use level shifters (which I admittedly don't understand).
My question to you all is: have you ever done something similar? How best to wire these? Am I out of my mind?
Many thanks!
Many thanks!
