rpishoukdrunx86
Run ARM VM's directly on raspbian
Thu Jul 29, 2021 9:58 pm
Hello everyone..
I have an rpi4 and I would love to run Aan RM-VM directly on raspbian (don't want to install esxi).
is this possible anyhow? chrooting isn't an option as I would like to run windows10 (arm version)
cleverca22
Re: Run ARM VM's directly on raspbian
Fri Jul 30, 2021 12:24 am
root@pi400:~# ls -l /dev/kvm
crw-rw----+ 1 root kvm 10, 232 Jul 28 05:59 /dev/kvm
kvm appears to be available, so just use qemu with kvm as normal
Gavinmc42
Fri Jul 30, 2021 1:24 am
QEMU runs on Pi4's, default is 3.1
I compiled 6.0.9 and it runs small Arm VMs on Raspberry Pi OS on Pi 400 too.
No idea what Aan-RM is, how big is it?
I'm dancing on Rainbows.
trejan
Fri Jul 30, 2021 1:53 am
I think it is a typo for "an ARM-VM".
Gavinmc42
Fri Jul 30, 2021 4:28 am
Hmm , probably why a googoo search could not find it :lol:
I use QEMU for Ultibo VMs running on Windows 10, Linux Intel x86-64 and Pi 32 bit OS.
Not perfect but it works for some things.
Framebuffer graphics works.
Used it to run a PiCore boot partition, but still need to figure out intramfs.
The start.elf can load kernel and an initramfs.
The aarch64 version can load zipped files
If only I could figure out how to get VM access to GPIO pins and accelerated graphics.
One day maybe
https://virgil3d.github.io/
Plug a Zero into a QEMU box and get real GPIO via USB gadget mode?
https://www.linux-kvm.org/page/USB_Host ... d_to_Guest
Gavinmc42
Sun Aug 01, 2021 2:36 am
Seven VM's running on a Pi400 in QEMU 6.0.0.
Number 7 took some time to load, Chromium was open too.
CPU limited, not memory limited.
Wonder if 32bit VM's will run on 64bit Raspberry OS?
Return to “Advanced users”
