bigcrater
dual monitor; use each screen to display 1 output each
Thu Jul 22, 2021 8:54 pm
Ahem!! I'm convinced that I do not know the proper terms for what I'm talking about.
Pi 4, two monitors. The monitors are not the same physical size.
uname -a
Linux jupiter 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux
Both monitors are working -- I can set different backgrounds, etc., for each.
I'd like HDMI-1 to be the traditional monitor.
I'd like HDMI-2 to show the output of a program. In this case, it's one based on the opencv
library. Ultimately, I'd like to turn on the 2nd monitor with a relay (I know how to do that) and
run the opencv program, such that the output shows up kind of like a warning sign. I'll handle
the screen content -- I'm convinced that I can get my program to display what I want it to.
What I can't presently do is get my opencv program to open the ... what would it be?
the second monitor? second framebuffer? or do I have the opencv program run and simply
put the opened window in a specific place on the screen/desktop? I don't know how to do
that.
aBUGSworstnightmare
Re: dual monitor; use each screen to display 1 output each
Fri Jul 23, 2021 5:39 am
Jupiter? Which platform do you work with? It's not a Raspbian OS, isn't it? Make sure to update/upgrade as it's for sure not the latest kernel
Fri Jul 23, 2021 6:03 am
"jupiter" is the hostname. Not all Raspberry Pi systems are called "raspberrypi" ;)
"5.10.17-v7l+ #1403" looks like a standard Raspberry Pi 32-bit kernel, although I believe #1421 is the current build.
Unreadable squiggle
aBUGSworstnightmare
Fri Jul 23, 2021 10:38 am
I see, thanks! :oops:
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 5.10.52-v7+ #1 SMP Fri Jul 23 09:50:12 CEST 2021 armv7l GNU/Linux
This is the kernel build from latest sources (on a CM3 this morning). Don't remember what May 7th official image reported before installing the new modules.
OP needs to use latest sources as these have a HDMI hot-plug detect feature included. Old Feb image will need to have the monitors connected on boot, or with a forced resolution in config.txt at least.
bigcrater
Sat Jul 24, 2021 8:25 pm
(I'm the OP.) Doing the upgrade now.
Any recommendation on what s/w I should consider?
I know about opencv, which is probably what I'll try first.
Return to “Advanced users”
