Dan1jel
Contact: Twitter
Re: Image File Utilities
Wed Jul 14, 2021 9:08 am
RonR wrote:
Wed Jul 14, 2021 2:38 am
Dan1jel wrote:
Tue Jul 13, 2021 8:47 pm
So is there any way I could change the start location from /mnt or /media to /server instead? I have my Plex library and everything (3tb of 6tb) in /server drive so this is not working out that great for me atm :/
Simply make a symbolic link in /mnt or /media that points to /server. For example:
sudo ln -s /server /mnt/server
Then references to /mnt/server will be equivalent to /server.
You will also need to add an exclusion option for the /server directory or image-backup will try to include it in the backups:
sudo image-backup --options --exclude-from=/home/pi/exclude.txt
In /home/pi/exclude.txt put:
/server
And i would like to do a cronjob, would it get stuck when image-backup is prompting some questions?
image-backup has a number of options to aid scripting (no interactive prompting needed).
See the description of image-backup in the first post of this topic.
Thank you for the clarification and helping me get a hold of this, i tried a simple backup script and it work, now my main backup script is ready, if curious, see my first post about my "issue" here - viewtopic.php?t=315698
Edit: is there a page or GitHub where we could get t any updates of image-utils or is it just by zip file when available? Was thinking if apt maybe could have it, we get the updated version when "apt update" is done?
RonR
Wed Jul 14, 2021 6:57 pm
I update the ZIP file attached to the first post of this topic whenever any problems are found or enhancements are made. Fortunately, the scripts are pretty mature at this point and haven't required any changes in a while.
Dan1jel
Contact: Twitter
Wed Jul 14, 2021 9:36 pm
Ah i see, then i just need to keep eye on updates from this post then :) thank you for this great app btw and keep up the good work!
pidd
Wed Jul 14, 2021 10:01 pm
One minor change I would suggest to image-backup is that it excludes /var/swap by default, the swap file has no purpose in the image file and it increases both the initial and incremental backup times.
RonR
Wed Jul 14, 2021 10:43 pm
That's a good idea. I've added that to my TODO list. Thanks!
In the meantime, you can exclude it manually with an rsync option on the command line:
image-backup --options --exclude=/var/swap ...
Kitulous
Sun Jul 18, 2021 5:11 pm
Hi, sorry if it's written somewhere in this chat already, but I'm new to Raspberry Pi backing up (or backupping, idk), and I have a couple of questions
1. I have a 32 GB MicroSD card that the Pi is running off of. Is the command
sudo ./image-backup --initial {{FILENAME}},32000,0
sufficient? What exactly do these two parameters after the name mean? I suppose the first one is the target ISO size (and if it's smaller than the used space on an SD card it will fail)
I want to point out that I will not be using the incremental updates of image-backup.
2. Can I gzip-compress the backup right when it is being done, not afterwards?
npaisnel
Sun Jul 18, 2021 5:55 pm
Just sudo ./ image-backup will work too, and it goes interactive and asks you file name to save as/ size/extra space etc
I never use the options , I just do as I posted above
RonR
Sun Jul 18, 2021 7:57 pm
Is the command
sufficient?
Actually,
sudo ./image-backup --initial IMAGE_FILENAME
should be sufficient for non-interactive mode.
image-backup usage is described in the first post of this topic. If you need further clarification about some item, let me know.
No, gzip-compress will need to be a separate pass.
typxxi
Wed Jul 21, 2021 8:47 pm
I had tried to shrink an image I had created before using dd but I got an error while shrinking
sudo ./image-shrink /media/pi/Backup-20210505-200000.img 100
Shrink /media/pi/Backup-20210505-200000.img [Additional MB = 100] (y/n)? y
e2fsck 1.44.5 (15-Dec-2018)
Warning: skipping journal recovery because doing a read-only filesystem check.
Pass 1: Checking inodes, blocks, and sizes
Deleted inode 3772 has zero dtime.  Fix? no
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Block bitmap differences:  +342212 +570128 -570129 +570271 -570272 -1191013
Fix? no
Free blocks count wrong for group #17 (1343, counted=1345).
Fix? no
Free blocks count wrong for group #36 (5660, counted=5657).
Fix? no
Free blocks count wrong (173062, counted=315868).
Fix? no
Inode bitmap differences:  -3772
Fix? no
Free inodes count wrong for group #16 (49, counted=48).
Fix? no
Free inodes count wrong (223495, counted=223411).
Fix? no
rootfs: ********** WARNING: Filesystem still has errors **********
rootfs: 220025/443520 files (0.4% non-contiguous), 1651706/1824768 blocks
Filesystem appears corrupted before resize2fs
I do not get it why it should be corrupted if it is working quite well if I use an imager to create a new sd card from it.
I need a solution to reduce my current 32 GB SD card partition to a 15 GB partition to get that onto a 16 GB SD card as target.
My old 8 GB one had died and my spare ones where all a few bytes smaller so I had to use the smallest other I had which was bigger than 8 GB and ended up using a a 32 GB with just 6 GB being used. Now I want to go for a 16 GB card using just 15 GB partition to avoid any hazzles of having a different just few bytes to small spare SD card.
And looking for such a solution I came across this solution which unfortunatelly does not work.
WOLF
RonR
Thu Jul 22, 2021 3:41 am
Was the image file created by using dd to copy a running system? If so, that is likely the cause of the corrupted image file.
I just created an image file of a 32GB SD card that was offline (not mounted) using dd and image-shrink worked perfectly on it.
image-shrink runs fsck on an image file before it does anything else to ensure it's not corrupted. Proceeding with shrinking a corrupted image file would most likely only make the corruption worse.
The bottom line is: image-shrink isn't the problem.
RonR
Thu Jul 22, 2021 4:57 am
RonR
Sun Jul 25, 2021 11:34 pm
image-utils.zip (in the first post of this topic) has been updated.
This update adds image-chroot.
image-chroot performs a linux 'chroot' to an image file. The current user will be 'root' and the current directory will be '/' in the image file. The host's root filesystem will be available at /host-root-fs. Use exit or ^D to terminate chroot. Usage is:
image-chroot [imagefile]
This utility allows you to do things things such as updating an image file's Raspberry Pi OS (use image-shrink before and after to add and remove additional space to the image file for the update to take place in):
pi@raspberrypi:~# sudo image-shrink 2021-05-07-raspios-buster-armhf.img 1000
Shrink 2021-05-07-raspios-buster-armhf.img [Additional MB = 1000] (y/n)? y
pi@raspberrypi:~# sudo image-chroot 2021-05-07-raspios-buster-armhf.img
chroot to 2021-05-07-raspios-buster-armhf.img (y/n)? y
Attempting to chroot to 2021-05-07-raspios-buster-armhf.img
Host root filesystem is available at /host-root-fs
root@raspberrypi:/# apt -y update && apt -y full-upgrade
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@raspberrypi:/# exit
exit
Exited chroot to 2021-05-07-raspios-buster-armhf.img
pi@raspberrypi:~# sudo image-shrink 2021-05-07-raspios-buster-armhf.img 0
Shrink 2021-05-07-raspios-buster-armhf.img [Additional MB = 0] (y/n)? y
pi@raspberrypi:~#
Return to “Advanced users”
