drtechno
How do you remove password-less sudo from PI installation
Wed Jun 16, 2021 5:08 pm
Hello, I'm a linux user for many years, and know that the policy of password-less sudo is a bad security policy, as it makes the machine susceptible to malware.
So, How do I get the standard security that I know that is the correct way to run linux on something?
trejan
Re: How do you remove password-less sudo from PI installation
Wed Jun 16, 2021 5:14 pm
Delete /etc/sudoers.d/010_pi-nopasswd
Wed Jun 16, 2021 6:24 pm
That will leave you with no user that can run sudo.
Change the contents of 010_pi-nopasswd to
pi ALL=(ALL) PASSWD: ALL
pasman1
Wed Jun 16, 2021 6:31 pm
you are wrong. look at /etc/sudoers
Pi4 RaspbOS 64+LXQT, linux 5.10.52-v8
bjtheone
Thu Jun 17, 2021 2:45 pm
Do you want to remove just the "passwordless" part of sudo, or remove sudo? Either way you will also need to add a root password, which I suspect you already know.
thagrol
Thu Jun 17, 2021 3:07 pm
Nope. Sudo asks for the password of the user invoking it not for root's password. A root password is only needed when you have no users capable of running su or sudo.
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
drtechno
Thu Jun 17, 2021 5:46 pm
Just removing the security flaw: "Passwordless" So it will be just like my other Linux machines I own.
Would be nice if someone's PI image didn't have this security compromise from the beginning, but I have to deal with what I am working with.
These OS on this platform also suck in a different way because there is no grub to toggle kernel versions and OS boot.
pasman1
Thu Jun 17, 2021 7:35 pm
try ubuntu or manjaro.
KeithMck
Fri Jun 18, 2021 9:44 am
.....or Devuan - (Debian without systemd).
pi-anazazi
Mon Jun 21, 2021 8:28 am
And to add some security, require root password for sudo
https://superuser.com/questions/161593/ ... t-password
...take answer by SRDC as the solution.
Kind regards
anazazi
Milliways
Tue Jun 22, 2021 2:07 am
Is it called this because it is antediluvian?
Return to “Advanced users”
