Soulex
How much gpu memory should i use
Thu Jun 17, 2021 8:10 pm
hello, I have been using raspian for the past few months and am trying to get the best performance out of it. I was wondering what i should set the gpu_mem to be? some articals say go as high as to can (1024mb) , which i have tried and it is stable and some say dont go above 256mb or above 512mb. I have a 8GB raspberry pi 4.
Thank you :D
trejan
Re: How much gpu memory should i use
Thu Jun 17, 2021 8:12 pm
The best option for nearly everybody is to use the default. Increasing the allocation doesn't improve performance.
Soulex
Thu Jun 17, 2021 8:15 pm
What is the default?
trejan
Thu Jun 17, 2021 8:21 pm
Don't set any gpu_mem= line in /boot/config.txt and it'll use the default.
https://www.raspberrypi.org/documentation/configuration/config-txt/memory.md wrote:For Pis with less than 1GB of memory, the default is 64; for Pis with 1GB or more of memory the default is 76.
Soulex
Thu Jun 17, 2021 8:23 pm
oh ok thank you
What would happen if i use like 1024 gpu mem
trejan
Thu Jun 17, 2021 8:25 pm
It won't boot.
Read https://www.raspberrypi.org/documentati ... /memory.md
Soulex
Thu Jun 17, 2021 8:26 pm
It won't boot.
is that with all pis or just most of them because i can boot with 1024
trejan
Thu Jun 17, 2021 8:29 pm
It won't boot.
If it does boot then they've changed the firmware to either clamp it at a lower value or it is ignoring your attempt to set to 1GB. Either way, it will be decreasing available resources as it will be taking away memory from Linux. Go read https://www.raspberrypi.org/documentati ... /memory.md as it answers all of these questions...
Soulex
Thu Jun 17, 2021 8:30 pm
It won't boot.
ok thank you
kerry_s
Fri Jun 18, 2021 3:06 am
ok thank you
doesn't matter how much ram there is over all, it shares 1024 between cpu & gpu, so for example you set to 512gpu, cpu only gets 512 to use, your basically slowing things down. you should not need to go higher than 128, for normal use, you can also set it lower giving cpu more, i've gone down to 24 without issues.
Imperf3kt
Contact: Twitter
Fri Jun 18, 2021 8:04 am
viewtopic.php?t=249122#p1534581
There were seversl posts around the time this post was created that explain the issue better, but essentially you only need more than the default memory if you're using things like the camera. The Pi can only access the first GB of RAM for certain uses, and some of that is lost to overhead as it is.
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
LTolledo
Fri Jun 18, 2021 10:11 am
I set mine at 192MB.... its required by Kodi..
no arguments there.... just works!
Some people be like:
Soulex
Fri Jun 18, 2021 6:01 pm
ok thank you
ok thank you for explaining that
Soulex
Fri Jun 18, 2021 6:02 pm
Thanks i shall have a read of that forum
Return to “Advanced users”
