wyan
Adding an audio output to RPi 400?
Sat Jun 12, 2021 2:00 pm
I've recently purchased a RPi 400, and sadly have no HDMI devices that can play audio. I'm also having a terrible time getting Bluetooth sound to work at all. So I was wondering if someone with decent soldering skills might be able to add the audio output connection that's missing on the 400 vs the 4 and previous models. I've no idea if additional hardware would be needed or perhaps it's just a matter of soldering the jack socket to a not connected test point.
Has anyone done any research on this?
Re: Adding an audio output to RPi 400?
Sat Jun 12, 2021 2:03 pm
Just use a USB Sound Card they are only a couple of ££s
wyan
Sat Jun 12, 2021 2:20 pm
Guess I'll have to... it'd still be nice to know if it's possible to add a jack socket to the 400 :)
Sat Jun 12, 2021 2:30 pm
Only via the GPIO, like one does for a RPI Zero, which you must of missed on you forum search:
viewtopic.php?t=290182
wyan
Sat Jun 12, 2021 2:55 pm
Totally missed it, thank you!
Geek3579
Sun Jun 13, 2021 8:34 am
Using a cheap USB audio sound card as an output device works well, and many now have a built-in volume control. The output level is adequate for headphone use. Yes it uses a precious USB port, but worth the effort to get clean sound.
Return to “Advanced users”
